Soil moisture value opposite
My soil moisture reading give 1024 when dry.
I am using nodemcu. I tried remap (0,1023,1023,0). I also tried moist = !analogRead(A0)
#include <Blynk.h>
#include <SimpleDHT.h>
char auth[]="47f5d05f740a411380aff7ae68e0dc9";
char ssid[]="iPhone";
char pass[]="1234567899";
int fan = D0;
int valve = D1;
int dht = D2;
int moist = analogRead(A0);
SimpleDHT11 dht11(dht);
pinMode(fan,OUTPUT);
pinMode(valve,OUTPUT);
pinMode(moist,INPUT);
 byte temperature = 0;
  byte humidity = 0;
  int err = SimpleDHTErrSuccess;
  if ((err = dht11.read(&temperature, &humidity, NULL)) != SimpleDHTErrSuccess) {
    Serial.print("Read DHT11 failed, err="); Serial.println(err);delay(1000);
    return;
  Serial.print("Current temperature: ");
  Serial.print((int)temperature); Serial.print(" *C, ");
  Serial.print("Current Moisture: ");
  Serial.println(analogRead(A0));
Blynk.virtualWrite(V1, temperature);
if (temperature <= 30){
  digitalWrite(fan,LOW);
  delay(100);
if (temperature >= 31){
  digitalWrite(fan,HIGH);
  delay(100);
if (temperature >= 35){
  Blynk.notify("Temperature Too High,FAN ON");
  delay(100);
Blynk.virtualWrite(V2,moist);
if (moist >= 800){
  digitalWrite(valve,HIGH);
  delay(100);
else {
  digitalWrite(valve,LOW);
  delay(100);
delay(5000);
Hello, Please do not post a new issue into an old topic (that one was 2 years old!!)… I moved your post into your own current topic.
Please also properly format all posted code, as required and demonstrated in the Welcome Topic along with solid details of your issue and what you have been trying
Very bad void loop()
On an ESP8266, the analog pin range is 0v-3.3v (or debatibly 3.1v or 3.2v at the high end) What is the voltage output of your moisture sensor?
the spec: operating voltage 3.3v to 5v
digital output of (0v or operating voltage)
Then i recommend you test it first with a basic, non-Blynk, sketch to confirm it is working correctly with your ESP… then it is easy to port that code function over to Blynk.
hi @Gunner I have tried with basic, non blynk. Now the sensor working correctly. now the problem is Blynk.virtualWrite (V5,moisture_percentage); not working in blynk app. But Blynk.virutalWrite(V1,temperature); is working fine in the app.
#include <Blynk.h>
char auth[]="8e6dd1bed4d44071a156d4490160885";
const int moist_pin =A0;
int fan = D0;
int valve = D1;
int dht = D2;
int SensorValuePercent = 0;
pinMode(moist_pin,INPUT);
  byte humidity = 0;
  byte moiture_percentage = 0;
    return;
  delay(100);
  delay(100);
  delay(100);
float moisture_percentage;
int moist_analog;
Blynk.virtualWrite(V5,moisture_percentage);
moist_analog = analogRead(moist_pin);
moisture_percentage = (100 - ( (moist_analog/1024.00) * 100));
Serial.print(moisture_percentage);
Serial.print("%\n\n");
if (moisture_percentage >= 20){
  delay(100);
else {
  delay(100);
delay(5000);
Did you actually read, and understand the “keep your void loop() clean” document that @Gunner provided a link to?
You certainly haven’t re-written your code in the way suggested by that document, which is why it’s not working.
You also need to move the Blynk.virtualwrite to after where you update the variable.
Before:
int moist_analog;
After:
int moist_analog;
I have already done that before, but cannot upload to board (error: espcomm_upload_mem failed). compiled without error. already googled the soloution, still dont know. here is the coding. thats why I still using the very bad void loop coding. pls help. thanks
#include <Blynk.h>
char auth[]="8e6dd1bed4d44071a156d44901608855";
int fan = D0;
int valve = D1;
int dht = D2;
void temperature(){
  byte humidity = 0;
  return;
  delay(100);
  delay(100);
  delay(100);
void soilMoisture() {
  int moist_analog;
  delay(100);
  else {
  delay(100);
  timer.setInterval(1000, temperature);
  timer.setInterval(1000, soilMoisture);
Whenever I get that message I just try to upload again and usually works the second/third time around.
not working for me, as I already tried many times. It working fine when i upload other code.
Ok now it can be upload, but still no value of Blynk.virtualWrite(V5,moisture_percentage); in blynk app, A0 pin is working. :disappointed_relieved:
Both of these are trying to run at the exact same time… either combine them into one function or put a small delay in between so that both timers are offset.
timer.setInterval(1000, temperature);  // Starts a timer to call function every second
delay(100);
timer.setInterval(1000, soilMoisture);  // Starts a timer to call function every second, but with a starting gap of 100ms after the previous timer
What is this??
First, you should learn to avoid repetitive delays in your running code… use timers instead.
Secondly, no fan or valve is going to start up and run for only 100ms… it wouldn’t do more than twitch at best.
Still not working, am i supposed to set other thing on the widget other than setting the pin?
#include <Blynk.h>
int fan = D0;
int valve = D1;
int dht = D2;
void temperature(){
  byte humidity = 0;
  return;
  int moist_analog;
  if (moisture_percentage <= 20){
  else {
  delay(100);
I don’t understand this question.
never mind, now its work.
changed from this
to this
  moist_analog = map(moist_analog, 0, 1023, 100, 0);
  Blynk.virtualWrite(V5,moist_analog);
one more thing, if else condition not working, but it work when i use the very bad void loop coding. do u know why?
This is a foundational code that will work just fine in a timed loop.
sorry, not if else, digitalWrite problem.
only Blynk.notify works, other not working.
