@AbuJarrah Have you tried the example programs? They work well. Have you registered the device with the blynk server and obtained the token? That token has to be pasted here without any padding or additions. All the config files are created automatically by WiFiManager.
Here is code that I use regularly.
#include <FS.h> //this needs to be first, or it all crashes and burns...
//needed for library
#include <DNSServer.h>
#include <ESP8266WebServer.h>
#include <WiFiManager.h> //https://github.com/tzapu/WiFiManager
#include <EEPROM.h>
#include <TimeLib.h>
#include <time.h>
//#include <WidgetRTC.h>
//define colours needed
#define BLYNK_GREEN "#23C48E"
#define BLYNK_BLUE "#04C0F8"
#define BLYNK_YELLOW "#ED9D00"
#define BLYNK_RED "#D3435C"
#define BLYNK_DARK_BLUE "#5F7CD8"
#define PURPLE "#800080"
#define BLUE_VIOLET "#8A2BE2"
#define BROWN "#A52A2A"
#define DARK_CYAN "#008B8B"
#define DARK_MAGENTA "#8B008B"
#define DARK_ORCHID "#9932CC"
#define FUCHSIA "#FF00FF"
#define MAROON "#800000"
#define TEAL "#008080"
/******************* Begin general declarations Section *******/
char auth[] = "yourtoken";
char firmware_ver_date[] = "NodeMCU1.0 ESP8266 Prodn v2.0.1 dtd 17 Feb 2018 ";
char device_type[] = "Device: Wifi 4 switch SSRD";
/******************* end general declarations Section *******/
/***************** Begin Terminal declarations Section **********/
// Attach virtual serial terminal to Virtual Pin V9. Common for
// 4 and 8 switch versions
WidgetTerminal terminal(V9);
char termtxt[12]=" ";
char prevcmd[12]=" ";
/****************** end Terminal declarations Section ***********/
/*************** Begin Timer/RTC declarations Section *******/
//WidgetRTC rtc;
char Date[16];
char Time[16];
long startsecondswd; // start time in seconds
long stopsecondswd; // stop time in seconds
long nowseconds; // time now in seconds
int IsFirstConnect=1;
long FirstConnectTime;
String firstconnect_ts;
char time_stamp[80];
struct tm * ts;
time_t rawtime;
char dayname[4];
char monthname[4];
long uptime_secs=millis()/1000;
String last_check_time;
String current_check_time;
/* Vn_Sxhour/min. n is relay number. x is T for start and P for stop */
int V1_SThour, V1_STmin, V1_SPhour, V1_SPmin;
int V2_SThour, V2_STmin, V2_SPhour, V2_SPmin;
int V3_SThour, V3_STmin, V3_SPhour, V3_SPmin;
int V4_SThour, V4_STmin, V4_SPhour, V4_SPmin;
void requestTime() {
Blynk.sendInternal("rtc", "sync");
BLYNK_WRITE(InternalPinRTC) {
long t = param.asLong();
setTime(t);
Serial.print("\nUnix time: ");
Serial.print(t);
Serial.println();
rawtime=t;
char daystr[3]="";
char timestr[6]="";
char yearstr[5] = "";
if (IsFirstConnect)
FirstConnectTime=t;
IsFirstConnect=0;
Serial.print("First Connect: ");
Serial.print(t);
Serial.print(" :: ");
/* Needs <time.h> to be included. Can give out formatted time.*/
ts = localtime ( &rawtime );
strftime (time_stamp,80,"%a %I:%M %p %d %b %G %Z.",ts);
Serial.println(time_stamp);
firstconnect_ts=time_stamp;
/*Routine to check schedules and act accordingly */
// call with timer every 30 seconds
void schedule_check() {
rawtime=now();
//check all starts
if ((hour() == V1_SThour) && (minute() == V1_STmin) && !(last_check_time == time_stamp)) {
digitalWrite(14,1);
Blynk.virtualWrite(V1,1);
Serial.println("Switch 1 started by timer");
terminal.println(time_stamp);
terminal.println("Switch 1 started by timer");
terminal.flush();
if ((hour() == V2_SThour) && (minute() == V2_STmin) && !(last_check_time == time_stamp)) {
digitalWrite(12,1);
Blynk.virtualWrite(V2,1);
Serial.println("Switch 2 started by timer");
terminal.println("Switch 2 started by timer");
terminal.flush();
if ((hour() == V3_SThour) && (minute() == V3_STmin) && !(last_check_time == time_stamp)) {
digitalWrite(4,1);
Blynk.virtualWrite(V3,1);
Serial.println("Switch 3 started by timer");
terminal.println("Switch 3 started by timer");
terminal.flush();
if ((hour() == V4_SThour) && (minute() == V4_STmin) && !(last_check_time == time_stamp)) {
digitalWrite(13,1);
Blynk.virtualWrite(V4,1);
Serial.println("Switch 4 started by timer");
terminal.println("Switch 4 started by timer");
terminal.flush();
//check all stops
if ((hour() == V1_SPhour) && (minute() == V1_SPmin) && !(last_check_time == time_stamp)) {
digitalWrite(14,0);
Blynk.virtualWrite(V1,0);
Serial.println("Switch 1 stopped by timer");
terminal.println("Switch 1 stopped by timer");
terminal.flush();
if ((hour() == V2_SPhour) && (minute() == V2_SPmin) && !(last_check_time == time_stamp)) {
digitalWrite(12,0);
Blynk.virtualWrite(V2,0);
Serial.println("Switch 2 stopped by timer");
terminal.println("Switch 2 stopped by timer");
terminal.flush();
if ((hour() == V3_SPhour) && (minute() == V3_SPmin) && !(last_check_time == time_stamp)) {
digitalWrite(4,0);
Blynk.virtualWrite(V3,0);
Serial.println("Switch 3 stopped by timer");
terminal.println("Switch 3 stopped by timer");
terminal.flush();
if ((hour() == V4_SPhour) && (minute() == V4_SPmin) && !(last_check_time == time_stamp)) {
digitalWrite(13,0);
Blynk.virtualWrite(V4,0);
Serial.println("Switch 4 stopped by timer");
terminal.println("Switch 4 stopped by timer");
terminal.flush();
last_check_time=time_stamp;
/**************** end Timer/RTC declarations Section ********/
/***************** Begin WiFi declarations Section **********/
WiFiManager wifiManager;
WiFiClient wifiClient;
/****************** end WiFi declarations Section ***********/
/********************** Begin EEPROM Section *****************/
#define EEPROM_SALT 12664
typedef struct {
int salt = EEPROM_SALT;
char blynkToken[33] = "yourtoken";
char blynkServer[33] = "blynk-cloud.com";
char blynkPort[6] = "8442";
} WMSettings;
WMSettings settings;
void eeprom_read()
Serial.print("Values before reading EEPROM\n");
Serial.print(settings.salt);
Serial.print("::");
Serial.print(settings.blynkToken);
Serial.print("::");
Serial.print(settings.blynkServer);
Serial.print("::");
Serial.print(settings.blynkPort);
Serial.print("\n");
//custom params
EEPROM.begin(512);
EEPROM.get(0, settings);
EEPROM.end();
Serial.print("Values after reading EEPROM\n");
Serial.print("::");
Serial.print("::");
Serial.print("::");
Serial.print("\n");
Serial.println(settings.blynkToken);
Serial.println(settings.blynkServer);
Serial.println(settings.blynkPort);
void eeprom_saveconfig()
//save the custom parameters to FS
Serial.println("Saving config to EEPROM");
EEPROM.begin(512);
EEPROM.put(0, settings);
EEPROM.commit();
EEPROM.end();
/********************** end EEPROM Section *****************/
/********************** Begin LED Section *****************/
int BlynkLED=LED_BUILTIN;
int wifiLED=2;
int BlynkLEDstate=HIGH;
int wifiLEDstate=HIGH;
void wifiLEDoff()
digitalWrite(wifiLED, HIGH);
void wifiLEDon()
digitalWrite(wifiLED, LOW);
void BlynkLEDoff()
digitalWrite(BlynkLED, HIGH);
void BlynkLEDon()
digitalWrite(BlynkLED, LOW);
void BlynkLEDtoggle()
digitalWrite(BlynkLED, !BlynkLEDstate);
BlynkLEDstate=!BlynkLEDstate;
void wifiLEDtoggle()
digitalWrite(wifiLED, !wifiLEDstate);
wifiLEDstate=!wifiLEDstate;
/********************** end LED Section *****************/
BUTTONS HANDLING SECTION:
Map virtual pins to actual GPIOs. Helps abstract across boards to a common interface
V0 is for all relays to turn on/off
Vn is for nth relay to turn on/off
BLYNK_WRITE(V0)
int pinValue = param.asInt(); // assigning incoming value from pin V0 to a variable
Serial.print("\nV0 is set to ");
Serial.println(pinValue);
if (pinValue)
digitalWrite(14, HIGH);
digitalWrite(4, HIGH);
digitalWrite(12, HIGH);
digitalWrite(13, HIGH);
digitalWrite(14, LOW);
digitalWrite(4, LOW);
digitalWrite(12, LOW);
digitalWrite(13, LOW);
Blynk.virtualWrite(V1, pinValue);
Blynk.virtualWrite(V2, pinValue);
Blynk.virtualWrite(V3, pinValue);
Blynk.virtualWrite(V4, pinValue);
BLYNK_WRITE(V1)
digitalWrite(14, pinValue); // GPIO2
Serial.print("\nV1 is set to ");
BLYNK_WRITE(V2)
int pinValue = param.asInt(); // assigning incoming value from pin V2 to a variable
digitalWrite(12, pinValue); // GPIO2
Serial.print("\nV2 is set to ");
BLYNK_WRITE(V3)
int pinValue = param.asInt(); // assigning incoming value from pin V3 to a variable
digitalWrite(4, pinValue);
Serial.print("\nV3 is set to ");
BLYNK_WRITE(V4)
int pinValue = param.asInt(); // assigning incoming value from pin V4 to a variable
digitalWrite(13, pinValue);
Serial.print("\nV4 is set to ");
TIMER BUTTONS HANDLING SECTION:
V1n is for nth relay to turn on/off by timer imput
BLYNK_WRITE(V11)
TimeInputParam t(param);
V1_SThour = t.getStartHour();
V1_STmin = t.getStartMinute();
V1_SPhour = t.getStopHour();
V1_SPmin = t.getStopMinute();
Serial.print(hour());
Serial.print(":");
Serial.print(minute());
Serial.print("\nRelay 1 turn on @");
Serial.print(V1_SThour);
Serial.print(":");
Serial.print(V1_STmin);
Serial.print(" and off @");
Serial.print(V1_SPhour);
Serial.print(":");
Serial.println(V1_SPmin);
BLYNK_WRITE(V12)
V2_SThour = t.getStartHour();
V2_STmin = t.getStartMinute();
V2_SPhour = t.getStopHour();
V2_SPmin = t.getStopMinute();
Serial.print(":");
Serial.print("\nRelay 2 turn on @");
Serial.print(V2_SThour);
Serial.print(":");
Serial.print(V2_STmin);
Serial.print(V2_SPhour);
Serial.print(":");
Serial.println(V2_SPmin);
BLYNK_WRITE(V13)
V3_SThour = t.getStartHour();
V3_STmin = t.getStartMinute();
V3_SPhour = t.getStopHour();
V3_SPmin = t.getStopMinute();
Serial.print(":");
Serial.print("\nRelay 3 turn on @");
Serial.print(V3_SThour);
Serial.print(":");
Serial.print(V3_STmin);
Serial.print(V3_SPhour);
Serial.print(":");
Serial.println(V3_SPmin);
BLYNK_WRITE(V14)
V4_SThour = t.getStartHour();
V4_STmin = t.getStartMinute();
V4_SPhour = t.getStopHour();
V4_SPmin = t.getStopMinute();
Serial.print(":");
Serial.print("\nRelay 4 turn on @");
Serial.print(V4_SThour);
Serial.print(":");
Serial.print(V4_STmin);
Serial.print(V4_SPhour);
Serial.print(":");
Serial.println(V4_SPmin);
CONNECTION SECTION:
Has both Wifi and Blynk server connection segments
//WiFi connection segment
void configModeCallback (WiFiManager *myWiFiManager) {
Serial.println("Entered config mode");
Serial.println(WiFi.softAPIP());
String ssid = "Mo4W-" + String(ESP.getChipId());
Serial.print("\nSet up device as passwordless AP called ");
Serial.println(ssid);
Serial.print("Blue LED next to ESP8266 will be lit in this phase");
Serial.print("\nTurns off once configured WiFi connection is successfully established\n");
//Serial.println(myWiFiManager->getConfigPortalSSID());
// This function tries to connect to the Blynk cloud using TCP if not connected
void connectBlynk()
wifiClient.stop();
//All LEDs off in this routine
wifiLEDoff();
BlynkLEDoff();
if(!Blynk.connected() )
Serial.print("\nReconnecting to Blynk server");
BlynkLEDoff();
wifiClient.connect(settings.blynkServer, atoi(settings.blynkPort));
wifiLEDoff();
BlynkLEDon();
BLYNK_CONNECTED() {
Serial.print("\nConnected to server");
Blynk.syncVirtual(V1, V2, V3, V4, V11, V12, V13, V14);
Serial.print("\nSyncAll done");
wifiLEDoff();
BlynkLEDon();
requestTime();
//Clear terminal
terminal.println("\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\nReady");
terminal.flush();
Blynk.setProperty(V4, "color", FUCHSIA);
TERMINAL INTERACTION SECTION
Attached to Virtual Pin V9
Commands supported are help, info, time, upime, wifi, ver, ip, name, reboot, erase
BLYNK_WRITE(V9)
int j=0;
//convert keyed in text to lower case
strcpy(termtxt,param.asStr());
for(int i = 0; termtxt[i]; i++){
termtxt[i] = tolower(termtxt[i]);
Serial.println(termtxt);
if (String("help") == termtxt) {
terminal.println("\nCommands are not case sensitive");
terminal.println("Supported commands: help, info, time, uptime, wifi, ip, name, ver");
j=1;
strcpy(prevcmd,termtxt);
terminal.flush();
if (String("info") == termtxt) {
terminal.print(device_type);
terminal.println();
j=1;
terminal.flush();
if (String("time") == termtxt) {
terminal.print("\nTime: ");
rawtime=now();
j=1;
terminal.flush();
if (String("uptime") == termtxt) {
int x, days, hours, minutes, months = 0;
x=(millis()/1000);
Serial.println(x);
days = x / 60 / 60 / 24;
hours = (x / 60 / 60) % 24;
minutes = (x / 60) % 60;
terminal.print("\nUp since ");
terminal.println(firstconnect_ts);
terminal.flush();
terminal.print("Uptime: " );
terminal.print(days);
terminal.print("d:");
terminal.print(hours);
terminal.print("h:");
terminal.print(minutes);
terminal.println("m");
j=1;
terminal.flush();
if (String("wifi") == termtxt) {
terminal.print("\nSSID: ");
terminal.println(WiFi.SSID());
j=1;
terminal.flush();
if (String("ip") == termtxt) {
terminal.print("\nName: ");
terminal.println(WiFi.hostname());
terminal.print("Device ip: ");
terminal.println(WiFi.localIP());
j=1;
terminal.flush();
if (String("name") == termtxt) {
j=1;
terminal.flush();
if (String("clear") == termtxt) {
for (int i = 0; i <= 50; i++)
terminal.println(""); // "clear screen" in app.
j=1;
terminal.flush();
if (String("reboot") == termtxt) {
terminal.println("\npassword:");
j=1;
terminal.flush();
if (String("erase") == termtxt) {
j=1;
terminal.flush();
if ((String("mohan") == termtxt) && (String("reboot") == prevcmd)) {
ESP.reset();
if ((String("maple") == termtxt) && (String("erase") == prevcmd)) {
wifiManager.resetSettings();
ESP.reset();
if (String("ver") == termtxt) {
terminal.print("\nVer: ");
terminal.println(firmware_ver_date);
j=1;
terminal.flush();
if (!j) {terminal.println("\nInvalid command");
terminal.flush();
Serial.print("prevcmd: ");
Serial.println(prevcmd);
//exit point of BLYNK_WRITE(V9) Terminal section
/**************************** SETUP and LOOP Sections *******************************/
Serial.println();
//set all pinmodes to output for relay control
pinMode(14, OUTPUT);
pinMode(13, OUTPUT);
pinMode(12, OUTPUT);
pinMode(4, OUTPUT);
pinMode(2, OUTPUT);
pinMode(16, OUTPUT);
Serial.print("\nBooting firmware ");
Serial.println(firmware_ver_date);
Serial.print(device_type);
Serial.print("\nModified by Mohan Sundaram\n");
Serial.print("\nSetup done\n");
wifiLEDon();
//WiFiManager
//Local intialization. Once its business is done, there is no need to keep it around
//WiFiManager wifiManager;
//Pass on to callback to denote entering webconfig portal mode
wifiManager.setAPCallback(configModeCallback);
//exit after config instead of connecting
wifiManager.setBreakAfterConfig(true);
//for testing only
//wifiManager.resetSettings();
eeprom_read();
if (settings.salt != EEPROM_SALT) {
Serial.println("Invalid settings in EEPROM, trying with defaults");
WMSettings defaults;
settings = defaults;
Serial.println("Settings after EEPROM SALT check");
//Set hostname for easy identification.
WiFi.hostname(ssid);
WiFiManagerParameter custom_blynk_text("<br/><B/>Blynk configuration.");
wifiManager.addParameter(&custom_blynk_text);
WiFiManagerParameter custom_blynk_token("blynk-token", "blynk token", settings.blynkToken, 33);
wifiManager.addParameter(&custom_blynk_token);
//WiFiManagerParameter custom_blynk_server("blynk-server", "blynk server", settings.blynkServer, 33);
//wifiManager.addParameter(&custom_blynk_server);
//WiFiManagerParameter custom_blynk_port("blynk-port", "blynk port", settings.blynkPort, 6);
//wifiManager.addParameter(&custom_blynk_port);
//tries to connect to last known settings
//if it does not connect it starts an access point with the specified name
//here "Mo4W-xxxxxx" with no password
//and goes into a blocking loop awaiting configuration
if (!wifiManager.autoConnect(ssid.c_str(), NULL)) {
Serial.println("failed to connect, we should reset and see if it connects");
delay(3000);
ESP.reset();
delay(5000);
strcpy(settings.blynkToken, custom_blynk_token.getValue());
//strcpy(settings.blynkServer, custom_blynk_server.getValue());
//strcpy(settings.blynkPort, custom_blynk_port.getValue());
eeprom_saveconfig();
wifiLEDoff();
Serial.print("connected to wifi Access Point configured....");
Serial.print(WiFi.SSID());
Serial.print("\nlocal ip: ");
Serial.print(WiFi.localIP());
Serial.print("\n");
Blynk.config(settings.blynkToken);
//check Blynk connect every 1 secnd
timer.setInterval(1000L, connectBlynk);
//check schedule every 30 seconds
timer.setInterval(30000L, schedule_check);
//Sync time every hour
timer.setInterval(3600000L, requestTime);
