So, long time ago since I asked a question, but I was fiddling with my lights and I have some issues.
Situation:
V1 = Timer set from 18.00 - 22.30 (6pm - 10.30pm for you non-Europeans :P)
V2 = Timer set from 06.00 - 07.00 (6am - 7am)
V24 = relay on/off on ESP
V22 = PWM mosfet 0 ~ 1023 on ESP
Eventor widget:
IF V1 = 1 (e.g. on) set vPin 22 to 1 and vPin 24 to 1023
IF V1 = 0 (e.g. on) set vPin 22 to 0 and vPin 24 to 0
IF V2 = 1 (e.g. on) set vPin 22 to 1 and vPin 24 to 1023
IF V2 = 0 (e.g. on) set vPin 22 to 0 and vPin 24 to 0
However, it doesn’t work … the lights will not go on. You guys have any insights on how the Timer behaves in this case? Is it because I explicitly defined the Timer = 0 options in Eventor?
