Hi, why in app in LED widget, I can select ONLY virtual pin?
It is not big difference with value reading at Value Display, where I can select any pin.
In my project there is lack of free space. So, I could not use Widget led class or virtualWrite.
I guess itâs because the LED widget does some PWM simulation in the background, so it requires a value of 255 to turn it on whereas a regular physical LED simply requires a HIGH or LOW (1 or 0) to turn it on/off - depending on how youâve wired the physical LED.
I assume that youâre using an Uno?
There are techniques for reducing memory usage when coding, such as taking care which variable types you use, which libraries you include, and use of the âFâ macro when doing serial prints.
However, youâre probably better-off using more appropriate hardware for your projectâŚ
HI, Peter. Thank you for your suggestions.
I run Arduino Nano and binded to it due to this nice shield ШиНд Arduino Nano + GSM SIM800 + 2ŃоНо ĐşŃпиŃŃ Đ˛ ĐŁĐşŃаино
It is silly but Blynk reboots Nano, when it could not get connection. Continue code if Register in network failed - #9 by Gunner
I had to use additional code to control Blynk connection to let sketch run without Blynk.
Nanoâs memory 98% full and when I use Widget Led class, Blynk connection becomes unstable.
But i found short code solution to use LED on app:
Blynk.virtualWrite(V23, (digitalRead(pinACsensor)*255));
But of course, it could be better if Blynk could arrange direct read of the physical pin for that. Led is most useful in simple indication. Why we need extra code for that?
From my experience, when you start to get above about 80% useage things can start to behave strangely sometimes, certainly when using an Uno.
If you post your code then Iâd be happy to take a look and see if there are any other shortcuts that might help reduce memory usage.
Thank you very much, Peter.
I will make comments to the code and put code on Github as well. Because i did not found solution at the web how to kill Blynk before it crash Nano.)
So, may be it could be useful for others.
Hi, Pete
My code worked for a week, but now lost control over Nano/SIM800))
I put it on Github https://github.com/CHE77/Power-monitoring-management-with-and-w-o-Blynk.-Arduino-Nano-SIM800l-
May be you could have a look. Pls, PM to me if any question arise.
Deleting #define BLYNK_PRINT Serial should help save memory.
Also, as you arenât using your serial port for debugging you could use it for your connecting your SIM800, so allowing you to remove the SoftwareSerial library, also saving memory.
If you arenât planning to regularly change the values that youâve parameterised in your settings.h file then it may be better to hard code them as this will save on memory.
Thank you for advises.
That do you mean âhard code valuesâ? - to make static? via define?
Or just to put all code in one file?
Youâre defining variables like this:
```int averageFactor = 10``
And the value of average factor doesnât change throughout the code so this:
* (averageFactor - 1) +
could be replaced with this:
* 9 +
and youâve saved yourself a variable and the storage space that goes with it.
This declaration:
#define PIN_Relay7 7 // Build-in relay - PIN 7 NANO
is unnecessary if you replace:
pinMode(PIN_Relay7, OUTPUT);
with:
pinMode(7, OUTPUT);
In addition you have variables that arenât used (the code that uses them is commented-out)âŚ
//#define VPIN_LabelValu V0
#define VPIN_TimeInput V1
#define VPIN_Button_Manual_Auto V2
#define VPIN_Button_On_Off_Relay5 V5
#define VPIN_Button_On_Off_Relay6 V6
