I’ve been tinkering again  , had other codes running on them but I’ll set it all back up this evening and let it run for a couple of days …
What does the event log in your BT Hub 6 say? Are there any events that correspond to what you’re seeing in the Superchart?
Good idea, I never thought to check. But, and its a big BUT …
17:03:28, 27 Mar.
ppp1: Allocated prefix = 2a00:23c5:7d5a:8200::/56 (valid time = 2026291200 / preferred time = 2026291200)
17:03:28, 27 Mar.
ppp1: Allocated address = 2a00:23c5:7d5a:8201:8aa6:c6ff:fe1c:28d5 (valid time = 2026291200 / preferred time = 2026291200)
17:03:28, 27 Mar.
ppp1: Allocated prefix = 2a00:23c5:7d5a:8201::/64 (valid time = 2026291200 / preferred time = 2026291200)
17:03:28, 27 Mar.
17:03:28, 27 Mar.
17:03:27, 27 Mar.
ppp1:TR69 sending Inform message
17:03:26, 27 Mar.
ppp1:The WAN DHCPv6 Client Process has successfully been launched on Vlan 36
00:02:13, 01 Jan.
ppp1:TR69 creating new session with ACS
00:01:55, 01 Jan.
ppp1:WAN DHCPv6 Mode : Statefull
00:01:55, 01 Jan.
ppp1:New DYN ROUTE is added [::/0 hop fe80::ea4:2ff:fed3:c15b]
00:01:55, 01 Jan.
ppp1:New DYN ROUTE is added [81.139.56.100/32 gw ]
00:01:55, 01 Jan.
ppp1:New DYN ROUTE is added [81.139.57.100/32 gw ]
00:01:55, 01 Jan.
ppp1:WAN Router Discovery Setting Updated : M_flag = 1, O_flag = 0
00:01:55, 01 Jan.
ppp1:PPP: PPP INFO 81.139.57.100,81.139.56.100
00:01:48, 01 Jan.
:WAN: SENSING AUTO VDSL
Something very strange happened to my router that night, check out the log. An update perhaps, but wouldn’t that have effected all the devices equally ? …
2 months log missing …
I think the recent messages are to do with a different public IPv6 address being allocated to your router, but it only takes a second to implement and the time isn’t close to when you had the Wi-Fi issues (assuming the timestamps are correct).
Are there any Android apps that will log Wi-Fi signal strength on your phone? It would be interesting to see what’s happening there - although you’d need your phone connected to the 2.4Ghz network rather than the 5Ghz one, as its the 2.4 network that the Weemooses (is that the correct plural?) will be using.
WeMos’.
Looks about right to me …
Well the wife arranged a surprise Easter trip to see friends in the North of Scotland so I didn’t get chance to do it. However I will do it later this week once I’ve caught up on some other stuff. And see if I can find an Android app to monitor the 2Ghz signal.
So did you see and ‘Wee Mooses’ while you were up there?
A bit off topic but …
Actually the place is over run with deer(a bit moose looking). There’s so many up that way they’re culling them, huge amazing looking stags being shot with high power rifles.
I’m sure some Billionaire land owner is planning to reintroduce Wolves up there.
Wolves in the UK were wiped out hundreds of years ago, being the only big predator deer have since flourished. But the damage they do to the habitat and other species is mind blowing, hence the reintroduction of their natural predator, Wolves.
EDIT.
Just found this.
http://www.wolvesandhumans.org/wolves/wolf_reintroduction_to_scotland.htm
There was a TV documentary about this a while ago, which was repeated recently. The landowner is facing lots of opposition from his neighbours and is having lots of problems because the authorities want to classify him as a zoo, and you have to protect the animals in a zoo from eating each other - which is exactly what he doesn’t want to do.
The documentary was made a while ago and I wasn’t able to find any real updates on the project.
