Hello, thanks for the reply I want use 5 sensors, Iâm following the of the guy in this video. Caixa de ĂĄgua, I managed to copy the code, but in the end give me a error.
Blockquote
exit status 1 âblinkLedWidgetâ was not declared in this scope
Blockquote
http://twitter.com/blynk_app
This sketch shows how to write values to Virtual Pins
NOTE:
BlynkTimer provides SimpleTimer functionality:
http://playground.arduino.cc/Code/SimpleTimer
App project setup:
Value Display widget attached to Virtual Pin V5
int sensor1 = 27;
int sensor2 = 26;
int sensor3 = 25;
int sensor4 = 33;
int sensor5 = 32;
int nivel, diferente;
int lersensor1, lersensor2, lersensor3, lersensor4, lersensor5;
int ant_sensor1, ant_sensor2, ant_sensor3, ant_sensor4, ant_sensor5;
String nivel_display; //Sobe ou Desce
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
#include <Blynk.h>
char auth[] = "F31oHir6Q4qt-xnKaJjUfKQ2Kndcz3jK";
char ssid[] = "Vodafone-26EFC3";
char pass[] = "74aYpEqGU8";
WidgetLED led1(V16);
WidgetLED led2(V15);
WidgetLED led3(V14);
WidgetLED led4(V13);
WidgetLED led5(V12);
WidgetTerminal terminal(V3);
void myTimerEvent()
// Serial.printIn (nivel);
// Blynk.virtualWrite(V1, nivel);
pinMode(sensor1, INPUT);
pinMode(sensor2, INPUT);
pinMode(sensor3, INPUT);
pinMode(sensor4, INPUT);
pinMode(sensor5, INPUT);
// digitalWrite (sensor1, HIGH);
// digitalWrite (sensor2, HIGH);
// digitalWrite (sensor3, HIGH);
// digitalWrite (sensor4, HIGH);
// digitalWrite (sensor5, HIGH);
// Clear the terminal content
terminal.clear();
terminal.println(F("Monitorização do Nivel de Ăgua"));
terminal.println(F("------------------------------"));
terminal.println(F("Digite 'status' e receba os valores dos sensores"));
terminal.flush();
nivel_display = "Desconhecido";
