Can anyone help me to figure out where is the problem when i programm a virtual pin to control a LED ON/OFF state. I use a Button widget and set to V1 pin . The circuit connection : D7 connect to a LED anode with a resistor in series. Cathode of the LED back to GND. Below is the sketch:
const int led = 7;
BLYNK_WRITE(V1)
int ledState = param.asInt();
digitalWrite(7,ledState);
pinMode(7,OUTPUT);
They can be very confusing… or simple, depending on how you look at it and code for it.
For example this code, while using two different pin designations, will work just fine as both are referring to the same WEMOS pin. And as long as your IDE knows it is programming a Wemos D1 or D1 Mini, it will compile and work properly.
// BOTH are not required - only the last one takes precedence, but either of these will work as they are both referring to the same pin
pinMode(D4, OUTPUT); // NOTE, must have the D or it will be referenced to the Arduino 4 pin (GPIO4 AKA D2) confused yet?
pinMode(2, OUTPUT); // NOTE also called GPIO2
// Turn ON and OFF the same pin - which is the built in LED on a Wemos D1/D1 Mini board
digitalWrite(2, LOW); // 2 being the GPIO/Arduino designated pin number
delay(500);
digitalWrite(D4, HIGH); // D4 being the silkscreened Wemos designated pin number
delay(500);
But as a rule here… always best to use the GPIO designated numbers (referenced with most ESPs as the full GIOx and just as x on the Arduino) as they generally work in the IDE for programming the differing types of boards (Arduino and ESP).
