I’m trying to build a project to turn on a relay for 10 seconds when a virtual (push type) button on v0 is pressed
hardware - ESP8266
relay is connected to GPIO16(D0)
im using the blynk Edgent_ESP8266 code
You should read this…
And this…
and pay particular attention to the bit about timeout timers.
thanks for the help.
I read the articles, and this was what i came up with
#define BLYNK_TEMPLATE_ID ""
#define BLYNK_DEVICE_NAME ""
#define BLYNK_FIRMWARE_VERSION "1.0"
//#define BLYNK_DEBUG
#define APP_DEBUG
int wifists=2;
#include "BlynkEdgent.h"
#define USE_NODE_MCU_BOARD
BLYNK_WRITE(V0)
int pin = param.asInt();
if (param.asInt()){
digitalWrite(16, LOW);
timer.setTimeout(10000L, [] () {digitalWrite(16, HIGH);} );
delay(100);
pinMode(16, OUTPUT);
pinMode(wifists, OUTPUT);
digitalWrite(16,HIGH);
BlynkEdgent.begin();
BLYNK_CONNECTED()
BlynkEdgent.run();
if (Blynk.connected()) {
digitalWrite(wifists, HIGH);//turn on wifi status led if device isconnected to internet
digitalWrite(wifists, LOW);
the code works fine now, just that the button stays on even after 10 secs;though the relay turns off at 10 secs
i need the relay to stay on for 10 secs no matter how long i press the button for
TIA
You should update the button status using the Blynk.virtualWrite function.
You can also try automation
Thanks, works now :). Is there any way to adjust the time interval of the delay of the timer using any widgets on the dashboard?
TIA
Yes, you can use a parameter as the timeout period, maybe set from a slider or numeric input widget.
any example code for this?
There’s a snippet of code in the BltnkTimer link I provided earlier.
BLYNK_WRITE(V0)
if (param.asInt()){
timer.setTimeout(10000L, [] () {digitalWrite(16, HIGH);Blynk.virtualWrite(V0,LOW);} ); //<--- What is the purpose of the "L" after timer.setTimeout(10000
What is the purpose of the “L” after timer.setTimeout(10000
It defines it as a long Integer.
i had tried it without the L and it worked the same way ; does it make any difference
#define APP_DEBUG
int wifists=2;
BLYNK_WRITE(V7)
int slider = param.asInt();
BLYNK_WRITE(V0)
if (param.asInt()){
timer.setTimeout(slider, [] () {digitalWrite(16, HIGH);Blynk.virtualWrite(V0,LOW);} );
delay(100);
BLYNK_CONNECTED()
BlynkEdgent.run();
This is my updated code.... it doesnt compile and gives the error " 'slider' was not declared in this scope"
int typically stores integers in the range of -2147483648 to 2147483647 and requires 4 bytes (32 bits) of memory.
long int can store integers in the range of -9223372036854775808 to 9223372036854775807 and requires 8 bytes (64 bits) of memory.
The slider is a local variable. A local variable is a variable that is declared inside a function or a block of code, and it can only be accessed within that function or block. You should use global variable instead.
soo… where should i include the slider variable
Outside the function.
can you please explain further
sorry im new to these stuff
Declaring this as an integer within a function means that its value will always be zero outside of that function, because it’s a local variable.
What is this doing in your void loop?
Int slider;
BLYNK_WRITE(V7)
Thats to turn on a led if the esp is connected to the server
