Thanks for making this!
Is it possible to get this sent to a computer and not a phone app? I want to datalog on an excel spreadsheet and output to a simple microcontroller.
Is there a simple way to do this?
You can export the history in CSV format from the graph in the app.
Dave,
Thanks for your reply. This still requires a phone to perform the request. Is there anyway to just send this information to a PC or other separate logging device?
Yes, search for āthingspeakā
This seems to send to a cloud and only has a free evaluation period. I just want to send the signal directly to an offline laptop/pc.
Sorry for my lack of experience here. Iām sure thereās a ālanguage barrierā not allowing to to communicate well with you.
I think youāre just asking the wrong part of the internetā¦
Do you mean without going through the internet? If it is just you donāt have a phone I have used it on an android emulator on my pc. (Free)
Dave, I mainly want the data input into a host file (like excel) and not on the internet.
Maybe try local server (I havenāt used local server yet) put the data in a super chart. Click the three dots. There is option to export to excel.
I didnāt know of this feature. Iām going to build this, this weekend. I just wish there was an automatic data capture on a PC. Oh well, this is where the fun begins!
Also seeā¦
Line 278 Iām getting āāNO_MAX31855ā was not declared in this scopeā
All libraries are installed not sure what the issue is⦠Help?
@ Dave Blynk are you using Blynk as a crock pot monitor!
You donāt have this library installed properly:
The .zip file you download from GitHub wonāt install using the add.ZIP library option in the Arduino IDE - you have to manually unzip it and drag the MAX31855 to your Arduino libraries folder.
Pete, thanks for your reply.
I deleted the previous library and installed (manually) the one you attached and Iām getting the dreaded āMAX31855.h: No such file or directory.ā I looked in the folder just to make sure the .h file was named correctly and it does indeed match MAX31855.h
Any ideas? Itās manually installed in my libraries folder (and showing up) but itās not showing up in my contributed libraries on the IDEā¦
I figured it out. That library needs to have the .h file moved forward. I moved it from the subfolder to the front and now it recognizes itā¦
Anyone ever try the MAX31856 folder?
I did mention that in my post.
Newest addition. Mind you Iām using a dedicated PC in the garage. I didnāt have any of this last night.
c:/users/lance/appdata/local/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-3-20ed2b9/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: sketch\WiFi_Dual_TC.ino.cpp.o: in function `checkHeatTemp()':
C:\Users\Lance\Documents\Arduino\WiFi_Dual_TC/WiFi_Dual_TC.ino:322: undefined reference to `MAX31855::readThermocouple(unit_t)'
c:/users/lance/appdata/local/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-3-20ed2b9/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: C:\Users\Lance\Documents\Arduino\WiFi_Dual_TC/WiFi_Dual_TC.ino:322: undefined reference to `MAX31855::readThermocouple(unit_t)'
c:/users/lance/appdata/local/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-3-20ed2b9/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: sketch\WiFi_Dual_TC.ino.cpp.o: in function `readMAX31855FoodProbe()':
C:\Users\Lance\Documents\Arduino\WiFi_Dual_TC/WiFi_Dual_TC.ino:298: undefined reference to `MAX31855::readThermocouple(unit_t)'
c:/users/lance/appdata/local/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-3-20ed2b9/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: sketch\WiFi_Dual_TC.ino.cpp.o: in function `loop':
C:\Users\Lance\Documents\Arduino\WiFi_Dual_TC/WiFi_Dual_TC.ino:528: undefined reference to `MAX31855::MAX31855(int, int, int)'
c:/users/lance/appdata/local/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-3-20ed2b9/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: sketch\WiFi_Dual_TC.ino.cpp.o: in function `_GLOBAL__sub_I_Blynk':
C:\Users\Lance\Documents\Arduino\WiFi_Dual_TC/WiFi_Dual_TC.ino:535: undefined reference to `MAX31855::MAX31855(int, int, int)'
c:/users/lance/appdata/local/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-3-20ed2b9/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: C:\Users\Lance\Documents\Arduino\WiFi_Dual_TC/WiFi_Dual_TC.ino:536: undefined reference to `MAX31855::MAX31855(int, int, int)'
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compiling for board Generic ESP8266 Module.
What version of the Arduino Core do you have installed on that PC?
The newest I believe. 1.8.8.
