Hi everybody! I’m new in community forum. I’m developing a simple project with Blynk and Raspberry Pi Pico W. My idea is to turn on/off a led with Blynk via Wi-Fi. I installed via Thonny both official Blynk Micropython library (version 0.2.6) and Blynk Library by Volodymyr Shymanskyy (version 0.2.0). My Pi Pico W connected correctly to Wi-Fi but after it gives me error when connecting to Blynk servers. This is my code:
import network
import BlynkLib
from time import sleep
from machine import Pin
builtin_led = Pin('LED', Pin.OUT)
builtin_led.on()
# Connection to Wi-Fi
wlan = network.WLAN(network.STA_IF)
wlan.active(True)
wlan.connect(ssid, password)
# Wait for connect or fail
while not wlan.isconnected():
if wlan.status() < 0 or wlan.status() >= 3:
break
print("Waiting for connection...")
sleep(1)
# Handle connection error
if wlan.status() != 3:
print("Network connection failed")
else:
print("Connected")
status = wlan.ifconfig()
print("IP:", status[0])
# Initialize Blynk
print("Connection to Blynk...", end=" ")
blynk = BlynkLib.Blynk(token)
if blynk.connect():
print("done")
else:
print("failed")
white_led = Pin(15, Pin.OUT)
@blynk.handle_event('write V0')
def read_virtual_pin(pin, value):
print(f"Read from Virtual Pin V{pin} status {value}")
white_led.value(int(value))
while True:
blynk.run()
This is my output:
___ __ __
/ _ )/ /_ _____ / /__
/ _ / / // / _ \/ '_/
/____/_/\_, /_//_/_/\_\
/___/ for Python v0.2.0 (rp2)
Connected
IP: 192.168.1.32
Connection to Blynk... Traceback (most recent call last):
File "<stdin>", line 36, in <module>
File "/lib/BlynkLib.py", line 224, in __init__
File "/lib/BlynkLib.py", line 59, in __init__
File "/lib/BlynkLib.py", line 236, in connect
ValueError: Connection with the Blynk server blynk-cloud.com:80 failed
My region area is fra1. My plan is FREE. My operating system is MacOS Ventura 13.2.1.
