Hi Guys,
can someone help me out. I use a TTGO-T-Call board with GSM capability.
I was able to connect a temperature sensor to the board. So far everything works well with Blynk.
Now I would like to connect an additional GPS sensor via the TX and RX interface.
The pinouts show that, for example, the TX / RX (26/27) are already used by the modem
I connected simple the Neo-GPS module to the Serial TX and RX pins, but that in turn causes conflict
with the USB port.
My question here would be which pin can I use or would it be even not better to go through the hardware serial Port?
The instructions show that this is an ESP32 can handle “Hardware serial”.
Markus
//Definition Hardware Interface
HardwareSerial Serial1(1);
//Starten der Schnittstellen
//Serial1 auf Pin 34 und 35
Serial1.begin(9600,SERIAL_8N1,34,35);
