Hi guys, I have two problems, all of them after the last update, I use the joystick with one axis, however update after it was removed, I started using the joystick two axes however after the last update the auto return started giving problems
Hello. Please provide more info. iOS, Android? What exactly do you mean by āgiving problemsā?
My system is Android 5.1, the auto return function do not return the joystick for center, this trouble It started to occur after update, before update run normally
Hi @BlynkAndroidDev!
Iāve got same issues so I did a video to show you the strange things it does.
Even the slider is not working properly. Please, see below:
The autoreturn in āONā and the Rotate on Tilt āOFFā
Thanks for your help and support!!!
thanks for video!
I see that joystick is not returning to a center and returns to a smaller value? will try to reproduce this issue
Also we have heard about issues with slider - but i could not reproduce it on my device. will try again.
It does the same, no matter if I move the joystick to 255 or to 0, it should go directly to the center and sometimes it goes a bit crazyā¦
iāve created the same project and doesnāt see such issues. are you sure it is not an issue with touch on your device?
i could prepare some debug build with logging this issues on your devices to understand what happens.
My touch screen works fine⦠Iāve installed a āScreen Touch Testā and the result is OK
My smartphone is a LG G3 (8 monthsā¦) It works fine
ok, when iāll have time - iāll attach here a logging build, if it is possible for you to install it and send me the log of the application work.
thanks
Yes, no worries, but you will have to tell me step by step what I have to doā¦
Edit:
If you need more details, you will find them here:
This is my project. The only difference is the two axis joystick instead the single one⦠(I miss the āsingle axisāā¦
We have decided to remove one axis joystick, thatās why itās missing now.
Yes, I know it, itās a pityā¦
I did a suggestion for a new designā¦
The main concern was the space at the dashboard if Iām not wrong
guys, please, try this build - https://www.dropbox.com/s/657wxqod3qb4ydn/blynk_app-log.apk?dl=0
it should fix sliderās issue, and it will log joystickās updates. to send them to me - just long press the text on a green titlebar and it will show āsend logā dialog, select your email client and add my email: alexkipar@gmail.com
Hi!
Iām sorry but I canāt try this build⦠Iām not able to install the APK⦠I donāt know whyā¦
I click on install and after 3 seconds a message appears saying the āthe application is not installedā. Ideas?
I can install APK from unknown sources⦠I donāt understand why I canāt do itā¦
Maybe just not enough space?
Almost 3 Gb free space⦠Iāll try tomorrow again⦠Time to sleep at Spainā¦
Thanks @BlynkAndroidDev I did it!!
Your new build works perfect now!!! The joystick goes straight to the center without strange movements and the slider is also fine.
Check your inbox with the log file.
Kind regards
@BlynkAndroidDev,
What do I have to do now? Should I delete your build and install the oficial one? Let me know. Thanks.
As the issue has been solved, Iāll delete the video at YouTube⦠Itās not necessary to keep it anymoreā¦
