Hello, I wanted to try to integrate blynk BLE (HM-10) to control some MIDI control changes (value) with the help of “virtual” buttons from the blynk app. But as soon as I tried integrating it to my button sketch that send MIDI to USB the buttons stopped working (They are not sending anything). I am using a pro micro (clone) which sends MIDIUSB to my computer (main Serial. stream) when a button is pressed. The problem is that as soon as I integrate the “Blynk.begin(SerialBLE, auth)” line into the setup the buttons stop working. I have tried removing parts of the blynk code for troubleshooting what causes it and I ended up with the “Blynk.begin” line to be causing the problem. IT works perfectly when I remove only the Blynk.begin line. I tried looking in the “SerialBLE” scripts from blynks source but I didn’t find anything that would cancel out my buttons function in there? Thanks for taking your time
Code below (The commented things etc you can skip since this is a big work of progress with different functions):
#include <MIDIUSB.h>
//#include <MIDI.h>
//#include <midi_UsbTransport.h>
char auth[] = "57828136a344445eb1631b89cb79ac5a";
#define BLYNK_INFO_CONNECTION "SerialBLE"
//static const unsigned sUsbTransportBufferSize = 16;
//typedef midi::UsbTransport<sUsbTransportBufferSize> UsbTransport;
//UsbTransport sUsbTransport;
//MIDI_CREATE_INSTANCE(UsbTransport, sUsbTransport, MIDI);
//int incomingByte = 0;
SoftwareSerial SerialBLE(14, 15);
#define NUM_BUTTONS 8
int defaultkey = 60; //48
int Currentroot = 60;
int keyroot1 = Currentroot;
int keyroot2 = keyroot1 + 2;
int keyroot3 = keyroot2 + 2;
int keyroot4 = keyroot3 + 1;
int keyroot5 = keyroot4 + 2;
int keyroot6 = keyroot5 + 2;
int keyroot7 = keyroot6 + 2;
int keyroot8 = keyroot7 + 2;
//int keyroot1 = 36; //Kick
//int keyroot2 = 38; //Snare
//int keyroot3 = 57; //Crash
//int keyroot4 = 48; //Hi-mid tom
//int keyroot5 = 45; //LOW-FLOOR-TOM
//int keyroot6 = 42; //closed hi hat
//int keyroot7 = 46; //open HH
//int keyroot8 = 59; //RIDE CYMBAL
const uint8_t button1 = 2;
const uint8_t button2 = 3;
const uint8_t button3 = 4;
const uint8_t button4 = 5;
const uint8_t button5 = 6;
const uint8_t button6 = 7;
const uint8_t button7 = 8;
const uint8_t button8 = 9;
//const uint8_t intensityPot = 0; //A0 input
const uint8_t buttons[NUM_BUTTONS] = {button1, button2, button3, button4, button5, button6, button7, button8};
const byte noteFunction[NUM_BUTTONS] = {keyroot1, keyroot2, keyroot3, keyroot4, keyroot5, keyroot6, keyroot7, keyroot8}; // Indicator LED
uint8_t notesTime[NUM_BUTTONS];
uint8_t pressedButtons = 0x00;
uint8_t previousButtons = 0x00;
uint8_t intensity = 127;
uint8_t prevChange = 0x00;
int transpose = 0;
int pitchbendPot = 5;
//struct MySettings : public midi::DefaultSettings
// static const bool Use1ByteParsing = false;
// static const unsigned SysExMaxSize = 1026; // Accept SysEx messages up to 1024 bytes long.
// static const long BaudRate = 31250;
//#define DBGSERIAL if (0) SERIAL_PORT_MONITOR
//#ifdef USBCON
//#define MIDI_SERIAL_PORT Serial1
//#else
//#endif
//MIDI_CREATE_CUSTOM_INSTANCE(HardwareSerial, MIDI_SERIAL_PORT, MIDIUART, MySettings);
void BLE(const char * command) {
Serial.print("Command send :");
Serial.println(command);
SerialBLE.println(command);
//wait some time
delay(600);
char reply[100];
int i = 0;
while (SerialBLE.available()) {
reply[i] = SerialBLE.read();
i += 1;
//end the string
reply[i] = '\0';
Serial.print(reply);
Serial.println("Reply end");
//void USBSystemExclusive(unsigned size, byte *data, bool markersIncluded) {
// uint8_t bytesOut;
// midiEventPacket_t evt;
// while (size > 0) {
// bytesOut = min(3, size);
// evt.byte1 = *data++;
// size -= bytesOut;
// switch (bytesOut) {
// case 1:
// evt.header = 0x05;
// evt.byte2 = evt.byte3 = 0;
// break;
// case 2:
// evt.header = 0x06;
// evt.byte2 = *data++;
// evt.byte3 = 0;
// break;
// case 3:
// evt.header = (size > 0) ? 0x04 : 0x07;
// evt.byte3 = *data++;
// break;
// default:
// break;
// MidiUSB.sendMIDI(evt);
//inline uint8_t writeUARTwait(uint8_t *p, uint16_t size)
// // Apparently, not needed. write blocks, if needed
// // while (MIDI_SERIAL_PORT.availableForWrite() < size) {
// // delay(1);
// return MIDI_SERIAL_PORT.write(p, size);
//uint16_t sysexSize = 0;
//void sysex_end(uint8_t i)
// sysexSize += i;
// DBGSERIAL.print(F("sysexSize="));
// DBGSERIAL.println(sysexSize);
// sysexSize = 0;
//void readIntensity()
// int val = analogRead(intensityPot);
// intensity = (int) (map(val, 0, 1023, 0, 127));
//void pitchBend()
// playMidi(0xE0, low, high);
//void convUsb(byte channelx, byte pitchx, byte velocityx) {
// midiEventPacket_t xx = {0x09, 0x90 | channelx, pitchx, velocityx};
// if (xx.header != 0) {
// switch (xx.header & 0x0F) {
// case 0x00: // Misc. Reserved for future extensions.
// break;
// case 0x01: // Cable events. Reserved for future expansion.
// break;
// case 0x02: // Two-byte System Common messages
// case 0x0C: // Program Change
// case 0x0D: // Channel Pressure
// writeUARTwait(&xx.byte1, 2);
// break;
// case 0x03: // Three-byte System Common messages
// case 0x08: // Note-off
// case 0x09: // Note-on
// case 0x0A: // Poly-KeyPress
// case 0x0B: // Control Change
// case 0x0E: // PitchBend Change
// writeUARTwait(&xx.byte1, 3);
// break;
// case 0x04: // SysEx starts or continues
// sysexSize += 3;
// break;
// case 0x05: // Single-byte System Common Message or SysEx ends with the following single byte
// sysex_end(1);
// writeUARTwait(&xx.byte1, 1);
// break;
// case 0x06: // SysEx ends with the following two bytes
// sysex_end(2);
// break;
// case 0x07: // SysEx ends with the following three bytes
// sysex_end(3);
// break;
// case 0x0F: // Single Byte, TuneRequest, Clock, Start, Continue, Stop, etc.
// break;
void readButtons()
for (int i = 0; i < NUM_BUTTONS; i++)
if (digitalRead(buttons[i]) == LOW)
bitWrite(pressedButtons, i, 1);
delay(50);
bitWrite(pressedButtons, i, 0);
void playNotes()
if (bitRead(pressedButtons, i) != bitRead(previousButtons, i))
if (bitRead(pressedButtons, i))
bitWrite(previousButtons, i , 1);
Serial.print("Pressed");
noteOn(0, noteFunction[i], intensity);
MidiUSB.flush();
// convUsb(0, noteFunction[i], intensity);
bitWrite(previousButtons, i , 0);
noteOff(0, noteFunction[i], 0);
MidiUSB.flush();
// convUsb(0, noteFunction[i], 0);
Serial.print("Pressed off");
//void pitchwheelChange(int value) {
// unsigned int change = 0x2000 + value; // 0x2000 == No Change
// unsigned char lowValue = change & 0x7F; // Low 7 bits
// unsigned char highValue = (change >> 7) & 0x7F; // High 7 bits
// midiEventPacket_t event = {0x0E, 0xE0 | 0, lowValue, highValue};
// MidiUSB.sendMIDI(event);
//void readPitchbend() {
// pitchwheelChange(map(analogRead(pitchbendPot), 0, 1023, -8000, 8000));
// // } if pitchwheelChange(change != prevChange
void noteOn(byte channel, byte pitch, byte velocity) {
midiEventPacket_t noteOn = {0x09, 0x90 | channel, pitch, velocity};
MidiUSB.sendMIDI(noteOn);
void noteOff(byte channel, byte pitch, byte velocity) {
midiEventPacket_t noteOff = {0x08, 0x80 | channel, pitch, velocity};
MidiUSB.sendMIDI(noteOff);
void controlChange(byte channel, byte control, byte value)
{ midiEventPacket_t event = {0x0B, 0xB0 | channel, control, value};
//void handleNoteOn(byte inChannel, byte inNumber, byte inVelocity)
//void handleNoteOff(byte inChannel, byte inNumber, byte inVelocity)
//BLYNK_WRITE(V1)
// int pinValue = param.asInt(); // assigning incoming value from pin V1 to a variable
// // You can also use:
// // String i = param.asStr();
// // double d = param.asDouble();
// Serial.print("V1 Slider value is: ");
// Serial.println(pinValue);
//DBGSERIAL.begin(115200);
SerialBLE.begin(9600);
// BLE("AT+NAMEBROR");
// BLE("AT+ROLE0");
// BLE("AT+BAUD4");
Blynk.begin(SerialBLE, auth);
// while (!Serial);
// MIDI.begin();
// MIDI.setHandleNoteOn(handleNoteOn);
// MIDI.setHandleNoteOff(handleNoteOff);
pinMode(buttons[i], INPUT_PULLUP);
// MIDIUART.begin(MIDI_CHANNEL_OMNI);
// MIDIUART.turnThruOff();
/* MIDI UART -> MIDI USB */
// if (MIDIUART.read()) {
// midi::MidiType msgType = MIDIUART.getType();
// DBGSERIAL.print(F("UART "));
// DBGSERIAL.print(msgType, HEX);
// DBGSERIAL.print(' ');
// DBGSERIAL.print(MIDIUART.getData1(), HEX);
// DBGSERIAL.println(MIDIUART.getData2(), HEX);
// switch (msgType) {
// case midi::InvalidType:
// break;
// case midi::NoteOff:
// case midi::NoteOn:
// case midi::AfterTouchPoly:
// case midi::ControlChange:
// case midi::ProgramChange:
// case midi::AfterTouchChannel:
// case midi::PitchBend:
// midiEventPacket_t tx = {
// (byte)(msgType >> 4),
// (byte)((msgType & 0xF0) | ((MIDIUART.getChannel() - 1) & 0x0F)), /* getChannel() returns values from 1 to 16 */
// MIDIUART.getData1(),
// MIDIUART.getData2()
// MidiUSB.sendMIDI(tx);
// MidiUSB.flush();
// break;
// case midi::SystemExclusive:
// USBSystemExclusive(MIDIUART.getSysExArrayLength(),
// (byte *)MIDIUART.getSysExArray(), true);
// MidiUSB.flush();
// break;
// case midi::TuneRequest:
// case midi::Clock:
// case midi::Start:
// case midi::Continue:
// case midi::Stop:
// case midi::ActiveSensing:
// case midi::SystemReset:
// midiEventPacket_t tx = { 0x0F, (byte)(msgType), 0, 0 };
// MidiUSB.flush();
// break;
// case midi::TimeCodeQuarterFrame:
// case midi::SongSelect:
// midiEventPacket_t tx = { 0x02, (byte)(msgType), MIDIUART.getData1(), 0 };
// MidiUSB.flush();
// break;
// case midi::SongPosition:
// midiEventPacket_t tx = { 0x03, (byte)(msgType), MIDIUART.getData1(), MIDIUART.getData2() };
// MidiUSB.flush();
// break;
// default:
// break;
// /* MIDI USB -> MIDI UART */
// midiEventPacket_t rx = MidiUSB.read();
// if (rx.header != 0) {
// DBGSERIAL.print(F("USB "));
// DBGSERIAL.print(rx.header, HEX);
// DBGSERIAL.print(rx.byte1, HEX);
// DBGSERIAL.print(rx.byte2, HEX);
// DBGSERIAL.println(rx.byte3, HEX);
// switch (rx.header & 0x0F) {
// break;
// break;
// writeUARTwait(&rx.byte1, 2);
// break;
// writeUARTwait(&rx.byte1, 3);
// break;
// sysexSize += 3;
// break;
// sysex_end(1);
// writeUARTwait(&rx.byte1, 1);
// break;
// sysex_end(2);
// break;
// sysex_end(3);
// break;
// break;
readButtons();
playNotes();
// mySerial.println();
