@Gunner this example is blocking and completely unacceptable in JS world. you should use setTimeout/setInterval/clearInterval API
@Gunner - you are amazing. This post is incredibly helpful. My only request is a Bridge example
@vshymanskyy - Thanks for making the note on timers- the setInterval and setTimeout functions are super intuitive/easy to use, but are there ANY sort of clash issues with Blynk when using these built-in JS timer functions you describe above- similar to the issues one would see when using the ‘delay’ function in C++?
Wow, OK, thanks for the heads up… And here I found it on a JS teaching page that was all about timing options ![]()
I will checkout the others… I think I saw them referenced there as well… but at the ‘time’, I just needed something for a quick 1 second delay… and it DID work at least for that
Time to learn more and update my post ![]()
exactly opposite
