i have an issue on my device timeline, as confirmed there is a limitation timeline event per day, i have set up limit period for 30 minutes and event counter is 1. For my understand, on 30 minutes i will get only 1 message on my timeline. But on practically it is not.
You’re getting confused between notifications (which pop-up on the Home Screen of your mobile device) and the timeline.
If, in the other tab of your event settings, you’ve selected “Send event to timeline” then every event generated will appear on the timeline.
The first event should also create a notification on your mobile device.
If you still have events available in your daily event limit after 30 minutes (there was a limit of 1 event per minute, but it appears from your screenshot that this has now been removed) then you’ll get another notification.
