BLYNK
Time problem on my project
Hi guys, i got big troubles with my project and i really need your help, i’m goin’ crazy!!
i’m creating a small greenhouse with a light control and a water pump control. i’m using a local server.
To create the code i’ve used an old project found here called “4 way control relay”. untill i’ve used this to control only one relay, everythig was ok. the problems started when i’ve changed the code to introduce a second relay control.
If i reset the board and set the time for on and off to check it, everything works, but after 7-8 hours when the relay has to start again, never start. i can’t understand where is the error.
here’s code and screenshots.
Please help me!!
sorry but i have trouble uploading my code…
OMG… you need to put your code in proper formatting…
enclosure it with ``` (If you had read the “how to post” you would know) Edit your first post and delete the others… and with a correct formatted code maybe someone can help you… after seeing your code published that way … everyone will lose the impulse to read it
Take a look at this project as well Simple 4 relay irrigation scheduler
Please repost your code properly… Thank you.
Blynk - FTFC
ok, I had not read the post …,i’m really sorry guys.
here is the code:
#include <Ethernet.h>
#include <DHT.h>
#include <TimeLib.h>
#include <WidgetRTC.h>
#define DHTPIN 4
#define DHTTYPE DHT22   // DHT 22 Change this if you have a DHT11
DHT dht(DHTPIN, DHTTYPE);
#define TRIGGER 1
#define ECHO    5
#define server "192.168.178.55"
#define LAMP 6
#define PUMP 8
char Date[16];
char Time[16];
char auth[] = "xxxxxxxxxxxxxxxxxxxxxxxxxxxxx";
long startsecondswd;            // weekday start time in seconds
long stopsecondswd;             // weekday stop  time in seconds
long nowseconds;                // time now in seconds
bool isFirstConnect = true;
String displaycurrenttime;
int manualLAMP=0;
int oldstatusLAMP;
int manualPUMP=0;
int oldstatusPUMP;
int stepone;
int steptwo;
int stepthree;
int uptoyou;
int everyday;
int fourweek;
int twoweek;
int oneweek;
// the timer object
WidgetRTC rtc;
WidgetTerminal terminalLAMP(V23);
WidgetTerminal terminalPUMP(V43);
float humidity, temp_f;  // Values read from sensor
//#define W5100_CS  10
//#define SDCARD_CS 4
BLYNK_WRITE(V15) //ultrasonic
  // process received value
  pinMode(LAMP, OUTPUT);
  pinMode(PUMP, OUTPUT);
  pinMode(TRIGGER, OUTPUT);
  pinMode(ECHO, INPUT);
  digitalWrite(LAMP, LOW); // set LED OFF
  digitalWrite(PUMP, LOW); // set LED OFF
  Serial.begin(9600); // Debug console
  Serial.println("Starting");
  Blynk.begin(auth, server, 8080);
  int mytimeout = millis() / 1000;
  while (Blynk.connect() == false) { // try to connect to server for 10 seconds
    if((millis() / 1000) > mytimeout + 8){ // try local server if not connected within 9 seconds
       break;
  rtc.begin();
  timer.setInterval(10000L, activetoday);  // check every 10 SECONDS if schedule should run today
  timer.setInterval(30000L, reconnectBlynk);  // check every 30s if still connected to server
  timer.setInterval(5000L, clockvalue);  // check value for time
  timer.setInterval(1000, sendData);
BLYNK_CONNECTED() {
if (isFirstConnect) {
  Blynk.syncAll();
  Blynk.notify("TIMER STARTING!!!!");
isFirstConnect = false;
void clockvalue() // Digital clock display of the time
 int gmthour = hour();
  if (gmthour == 24){
     gmthour = 0;
  String displayhour =   String(gmthour, DEC);
  int hourdigits = displayhour.length();
  if(hourdigits == 1){
    displayhour = "0" + displayhour;
  String displayminute = String(minute(), DEC);
  int minutedigits = displayminute.length();
  if(minutedigits == 1){
    displayminute = "0" + displayminute;
  displaycurrenttime = "                                          Clock:  " + displayhour + ":" + displayminute + "                                ";
  Blynk.setProperty(V23,"label", displaycurrenttime);
void activetoday(){        // check if schedule should run today
  if(year() != 1970){
   if (stepone==1) {
    Blynk.syncVirtual(V24); // sync timeinput widget
   if (steptwo==1) {
    Blynk.syncVirtual(V26); // sync timeinput widget
   if (stepthree==1) {
    Blynk.syncVirtual(V28); // sync timeinput widget
   if (uptoyou==1) {
    Blynk.syncVirtual(V30); // sync timeinput widget
   if (everyday==1) {
    Blynk.syncVirtual(V44); // sync timeinput widget
   if (fourweek==1) {
    Blynk.syncVirtual(V46); // sync timeinput widget
   if (twoweek==1) {
    Blynk.syncVirtual(V48); // sync timeinput widget
   if (oneweek==1) {
    Blynk.syncVirtual(V50); // sync timeinput widget
void checklastbuttonpressedLAMP (){
    if(stepone==1){ oldstatusLAMP=1; }
    if(steptwo==1){ oldstatusLAMP=2; }
    if(stepthree==1){ oldstatusLAMP=3; }
    if(uptoyou==1){ oldstatusLAMP=4; }
    if((stepone==0)&&(steptwo==0)&&(stepthree==0)&&(uptoyou==0)){ oldstatusLAMP=5; }
void checklastbuttonpressedPUMP (){
    if(everyday==1){ oldstatusPUMP=1; }
    if(fourweek==1){ oldstatusPUMP=2; }
    if(twoweek==1){ oldstatusPUMP=3; }
    if(oneweek==1){ oldstatusPUMP=4; }
    if((everyday==0)&&(fourweek==0)&&(twoweek==0)&&(oneweek==0)){ oldstatusPUMP=5; }
void restorelastbuttonpressedLAMP (){
    if(oldstatusLAMP==1){ stepone=1; Blynk.virtualWrite(V25, 1);}
    if(oldstatusLAMP==2){ steptwo=1; Blynk.virtualWrite(V27, 1);}
    if(oldstatusLAMP==3){ stepthree=1; Blynk.virtualWrite(V29, 1);}
    if(oldstatusLAMP==4){ uptoyou=1; Blynk.virtualWrite(V31, 1);}
    if(oldstatusLAMP==5){
      stepone=0;
      steptwo=0;
      stepthree=0;
      uptoyou=0;
      Blynk.virtualWrite(V25, 0);
      Blynk.virtualWrite(V27, 0);
      Blynk.virtualWrite(V29, 0);
      Blynk.virtualWrite(V31, 0);
void restorelastbuttonpressedPUMP (){
    if(oldstatusPUMP==1){ everyday=1; Blynk.virtualWrite(V45, 1);}
    if(oldstatusPUMP==2){ fourweek=1; Blynk.virtualWrite(V47, 1);}
    if(oldstatusPUMP==3){ twoweek=1; Blynk.virtualWrite(V49, 1);}
    if(oldstatusPUMP==4){ oneweek=1; Blynk.virtualWrite(V51, 1);}
    if(oldstatusPUMP==5){
      everyday=0;
      fourweek=0;
      twoweek=0;
      oneweek=0;
      Blynk.virtualWrite(V45, 0);
      Blynk.virtualWrite(V47, 0);
      Blynk.virtualWrite(V49, 0);
      Blynk.virtualWrite(V51, 0);
BLYNK_WRITE(V21)  // Manual/Auto selection LAMP
  if (param.asInt()==1) {
    manualLAMP=1;
    terminalLAMP.println();
    terminalLAMP.println("Manual MODE is ON");
    terminalLAMP.println("Press ON/OFF button if required");
    terminalLAMP.flush();
    checklastbuttonpressedLAMP ();
    stepthree=0;
    uptoyou=0;
    stepone=0;
    steptwo=0;
    restorelastbuttonpressedLAMP ();
    manualLAMP=0;
    terminalLAMP.println("Manual MODE is OFF");
    terminalLAMP.println("Auto MODE restored from last status");
    terminalLAMP.println("Wait for update (10 seconds as maximum)");
BLYNK_WRITE(V41)  // Manual/Auto selection PUMP
    manualPUMP=1;
    terminalPUMP.println();
    terminalPUMP.println("Manual MODE is ON");
    terminalPUMP.println("Press ON/OFF button if required");
    terminalPUMP.flush();
    checklastbuttonpressedPUMP ();
    everyday=0;
    fourweek=0;
    twoweek=0;
    oneweek=0;
    restorelastbuttonpressedPUMP ();
    manualPUMP=0;
    terminalPUMP.println("Manual MODE is OFF");
    terminalPUMP.println("Auto MODE restored from last status");
    terminalPUMP.println("Wait for update (10 seconds as maximum)");
void resetterminalLAMP()
    terminalLAMP.println("New MODE has been selected");
void resetterminalPUMP()
    terminalPUMP.println("New MODE has been selected");
void resetManualLAMP()
Blynk.virtualWrite(V21, 0);   //Turn OFF Manual Mode Widget
Blynk.virtualWrite(V22, 0);   //Turn OFF Button Widget Device
void resetManualPUMP()
Blynk.virtualWrite(V41, 0);   //Turn OFF Manual Mode Widget
Blynk.virtualWrite(V42, 0);   //Turn OFF Button Widget Device
BLYNK_WRITE(V22)  // ON-OFF Manual LAMP
    if (param.asInt()==1) {  // boton encendido
    terminalLAMP.println("Device is ON");
        if (manualLAMP==0){  //está en modo automático
         manualLAMP=1;
         stepone=0;
         steptwo=0;
         stepthree=0;
         uptoyou=0;
         Blynk.virtualWrite(V21, 1);
         digitalWrite(LAMP, HIGH); // set LED ON
         Blynk.virtualWrite(V22, 1);   //Turn ON Button Widget
         } else {             //está en modo manual
         stepone=0;
         steptwo=0;
         stepthree=0;
         uptoyou=0;
    }else {
    terminalLAMP.println("Device is OFF");
        if (manualLAMP==0){      //modo automático
         manualLAMP=1;
         stepone=0;
         steptwo=0;
         stepthree=0;
         uptoyou=0;
         stepone=0;
         steptwo=0;
         stepthree=0;
         uptoyou=0;
BLYNK_WRITE(V42)  // ON-OFF Manual PUMP
    terminalPUMP.println("Device is ON");
        if (manualPUMP==0){  //está en modo automático
         manualPUMP=1;
         everyday=0;
         fourweek=0;
         twoweek=0;
         oneweek=0;
         Blynk.virtualWrite(V41, 1);
         digitalWrite(PUMP, HIGH); // set LED ON
         Blynk.virtualWrite(V42, 1);   //Turn ON Button Widget
         everyday=0;
         fourweek=0;
         twoweek=0;
         oneweek=0;
    }else {
    terminalPUMP.println("Device is OFF");
        if (manualPUMP==0){      //modo automático
         manualPUMP=1;
         everyday=0;
         fourweek=0;
         twoweek=0;
         oneweek=0;
         everyday=0;
         fourweek=0;
         twoweek=0;
         oneweek=0;
BLYNK_WRITE(V25)  // Step One selected LAMP
    timer.setTimeout(50, resetterminalLAMP);
    timer.setTimeout(50, resetManualLAMP);
    timer.setTimeout(50, checklastbuttonpressedLAMP);
    stepone=1;
    steptwo=0;
    stepthree=0;
    uptoyou=0;
    stepone=0;
BLYNK_WRITE(V45)  // everyday selected PUMP
    timer.setTimeout(50, resetterminalPUMP);
    timer.setTimeout(50, resetManualPUMP);
    timer.setTimeout(50, checklastbuttonpressedPUMP);
    everyday=1;
    fourweek=0;
    twoweek=0;
    oneweek=0;
    everyday=0;
BLYNK_WRITE(V27)  // Step Two selected LAMP
    stepone=0;
    steptwo=1;
    stepthree=0;
    uptoyou=0;
    steptwo=0;
BLYNK_WRITE(V47)  // fourweek selected PUMP
    everyday=0;
    fourweek=1;
    twoweek=0;
    oneweek=0;
    fourweek=0;
BLYNK_WRITE(V29)  // Step Three selected LAMP
    stepone=0;
    steptwo=0;
    stepthree=1;
    uptoyou=0;
    stepthree=0;
BLYNK_WRITE(V49)  // twoweek selected PUMP
    everyday=0;
    fourweek=0;
    twoweek=1;
    oneweek=0;
    twoweek=0;
BLYNK_WRITE(V31)  // Up to you selected LAMP
    stepone=0;
    steptwo=0;
    stepthree=0;
    uptoyou=1;
    uptoyou=0;
BLYNK_WRITE(V51)  // oneweek selected PUMP
    everyday=0;
    fourweek=0;
    twoweek=0;
    oneweek=1;
    oneweek=0;
BLYNK_WRITE(V24)//Step One LAMP
  if (stepone==1) {
    sprintf(Date, "%02d/%02d/%04d",  day(), month(), year());
    TimeInputParam t(param);
    terminalLAMP.print("M-F Checked schedule at: ");
    terminalLAMP.println(Time);
    int dayadjustment = -1;
    if(weekday() == 1){
      dayadjustment =  6; // needed for Sunday, Time library is day 1 and Blynk is day 7
    if(t.isWeekdaySelected(weekday() + dayadjustment)){ //Time library starts week on Sunday, Blynk on Monday
    terminalLAMP.println("Step One ACTIVE today");
    if (t.hasStartTime())
      terminalLAMP.println(String("Start: ") + t.getStartHour() + ":" + t.getStartMinute());
    if (t.hasStopTime())
      terminalLAMP.println(String("Stop : ") + t.getStopHour() + ":" + t.getStopMinute());
    // Display timezone details, for information purposes only
    terminalLAMP.println(String("Time zone: ") + t.getTZ());
     for (int i = 1; i <= 7; i++) {  // Process weekdays (1. Mon, 2. Tue, 3. Wed, ...)
        if (t.isWeekdaySelected(i)) {
        terminalLAMP.println(String("Day ") + i + " is selected");
    nowseconds = ((hour() * 3600) + (minute() * 60) + second());
    startsecondswd = (t.getStartHour() * 3600) + (t.getStartMinute() * 60);
    //Serial.println(startsecondswd);  // used for debugging
    if(nowseconds >= startsecondswd){
      terminalLAMP.print("Step One STARTED at");
      terminalLAMP.println(String(" ") + t.getStartHour() + ":" + t.getStartMinute());
      if(nowseconds <= startsecondswd + 90){    // 90s on 60s timer ensures 1 trigger command is sent
        // code here to switch the relay ON
    else{
      terminalLAMP.println("Step One Device NOT STARTED today");
    stopsecondswd = (t.getStopHour() * 3600) + (t.getStopMinute() * 60);
    if(nowseconds >= stopsecondswd){
      terminalLAMP.print("Step One STOPPED at");
      terminalLAMP.println(String(" ") + t.getStopHour() + ":" + t.getStopMinute());
      if(nowseconds <= stopsecondswd + 90){   // 90s on 60s timer ensures 1 trigger command is sent
        // code here to switch the relay OFF
    else{
        digitalWrite(LAMP, HIGH); // set LED ON    test
        terminalLAMP.println("Step One is ON");
  else{
    terminalLAMP.println("Step One INACTIVE today");
BLYNK_WRITE(V44) //everyday PUMP
  if (everyday==1) {
    terminalPUMP.print("M-F Checked schedule at: ");
    terminalPUMP.println(Time);
    if(weekday() == 1){
    terminalPUMP.println("Everyday ACTIVE today");
      terminalPUMP.println(String("Start: ") + t.getStartHour() + ":" + t.getStartMinute());
      terminalPUMP.println(String("Stop : ") + t.getStopHour() + ":" + t.getStopMinute());
    terminalPUMP.println(String("Time zone: ") + t.getTZ());
        terminalPUMP.println(String("Day ") + i + " is selected");
      terminalPUMP.print("Everyday STARTED at");
      terminalPUMP.println(String(" ") + t.getStartHour() + ":" + t.getStartMinute());
    else{
      terminalPUMP.println("Everyday Device NOT STARTED today");
      terminalPUMP.print("Everyday STOPPED at");
      terminalPUMP.println(String(" ") + t.getStopHour() + ":" + t.getStopMinute());
    else{
        digitalWrite(PUMP, HIGH); // set LED ON    test
        terminalPUMP.println("Everyday is ON");
  else{
    terminalPUMP.println("Everyday INACTIVE today");
 BLYNK_WRITE(V26) //Step Two
  if (steptwo==1) {
    terminalLAMP.print("S-S Checked schedule at: ");
    if(weekday() == 1){
    dayadjustment =  6;
    terminalLAMP.println("Step Two ACTIVE today");
      terminalLAMP.print("Step Two STARTED at");
    else{
      terminalLAMP.println("Step Two NOT STARTED today");
    //Serial.println(stopsecondswd);
      terminalLAMP.print("Step Two STOPPED at");
    else{
        digitalWrite(LAMP, HIGH); // set LED ON  TEST
        terminalLAMP.println("Step Two is ON");
  else{
    terminalLAMP.println("Step Two INACTIVE today");
BLYNK_WRITE(V46) //fouweek PUMP
  if (fourweek==1) {
    terminalPUMP.print("S-S Checked schedule at: ");
    if(weekday() == 1){
    dayadjustment =  6;
    terminalPUMP.println("4 for week ACTIVE today");
      terminalPUMP.print("4 for week STARTED at");
    else{
      terminalPUMP.println("4 for week NOT STARTED today");
      terminalPUMP.print("4 for week STOPPED at");
    else{
        digitalWrite(PUMP, HIGH); // set LED ON  TEST
        terminalPUMP.println("4 for week is ON");
  else{
    terminalPUMP.println("4 for week INACTIVE today");
BLYNK_WRITE(V28)//Step Three
  if (stepthree==1) {
    terminalLAMP.print("Step Three Checked schedule at: ");
    if(weekday() == 1){
      dayadjustment =  6;
    terminalLAMP.println("Step Three ACTIVE today");
      terminalLAMP.print("Step Three STARTED at");
    else{
      terminalLAMP.println("All Day Device NOT STARTED today");
      terminalLAMP.print("All day STOPPED at");
    else{
        terminalLAMP.println("All day is ON");
  else{
    terminalLAMP.println("All day INACTIVE today");
BLYNK_WRITE(V48) //twoweek PUMP
  if (twoweek==1) {
    terminalPUMP.print("2 for week Checked schedule at: ");
    if(weekday() == 1){
      dayadjustment =  6;
    terminalPUMP.println("2 for week ACTIVE today");
      terminalPUMP.print("2 for week STARTED at");
    else{
      terminalPUMP.println("2 for week Device NOT STARTED today");
      terminalPUMP.print("2 for week STOPPED at");
    else{
        terminalPUMP.println("2 for week is ON");
  else{
    terminalPUMP.println("2 for week INACTIVE today");
BLYNK_WRITE(V30)//Up to you
  if (uptoyou==1) {
    terminalLAMP.print("Up to you Checked schedule at: ");
    if(weekday() == 1){
      dayadjustment =  6;
    terminalLAMP.println("Up to you ACTIVE today");
    if (t.hasStartTime()) // Process start time
    if (t.hasStopTime()) // Process stop time
    terminalLAMP.println("At least ONE day MUST be selected");
      terminalLAMP.print("Up to you STARTED at");
    else{
      terminalLAMP.println("UP to you Device NOT STARTED today");
    //Serial.println(stopsecondswd);  // used for debugging
      terminalLAMP.print("Up to you STOPPED at");
    else{
        terminalLAMP.println("Up to you is ON");
  else{
    terminalLAMP.println("Up to you INACTIVE today");
BLYNK_WRITE(V50) // oneweek PUMP
  if (oneweek==1) {
    terminalPUMP.print("1 for week Checked schedule at: ");
    if(weekday() == 1){
      dayadjustment =  6;
    terminalPUMP.println("1 for week ACTIVE today");
    terminalPUMP.println("At least ONE day MUST be selected");
      terminalPUMP.print("1 for week STARTED at");
    else{
      terminalPUMP.println("1 for week Device NOT STARTED today");
      terminalPUMP.print("1 for week STOPPED at");
    else{
        terminalPUMP.println("1 for week is ON");
  else{
    terminalPUMP.println("1 for week INACTIVE today");
void reconnectBlynk() {
  if (!Blynk.connected()) {
    if(Blynk.connect()) {
     BLYNK_LOG("Reconnected");
      BLYNK_LOG("Not reconnected");
void sendData()
  float h = dht.readHumidity();
//Write values to V08 and V09
  Blynk.virtualWrite(8, h);
  Blynk.virtualWrite(9, t);
  if (Blynk.connected()) {
  long duration, distance;
  digitalWrite(TRIGGER, LOW);
  delayMicroseconds(2);
  digitalWrite(TRIGGER, HIGH);
  delayMicroseconds(10);
  duration = pulseIn(ECHO, HIGH);
  distance = (duration/2) / 29.1;
  Blynk.virtualWrite(V15, distance);
  delay(200);
sorry but there are a lot of println, i had cut it in two.
wow!! thanks, is really cool.
hi guys, some news on the project. The project works, but i can use time input only between 10-23 :open_mouth: Doesn’t work from 0-9… i think is a problem of time format between rtc and time input.
Any idea about?
try 0:01 instead of 0:00
:wink:
Hi Alexis, I’ve try also that but thi problem is in time format. I need to understand how to change format from 9.00 to 09.00… I don’t know how do that…
I assume you want formatted clock display ?
this is :
void clockDisplay()
  String my_h = MyPrintDigits(hour());
  String my_m = MyPrintDigits(minute());
  String my_s = MyPrintDigits(second());
  currentTime = my_h+ my_m + my_s;
//fonction
String MyPrintDigits(int digits) { // -- Utility function for digital clock display: prints preceding colon and leading 0
  String new_digits = ":";
  if (digits < 10) new_digits += "0";
  new_digits += String(digits);
  return new_digits;
… or try simply something like this:
void clockDisplay()
  sprintf(currentTime,"%02u:%02u:%02u",hour(),minute(),second());
