1st part: nextion display, standalone mode
Scheduler
Fan / Pump
Blink Led
Boiler
Temp setting
Season
Wifi signal
Display on/off
Alert / lock
Setup and boiler control
Scheduler
Fan / Pump
Blink Led
Boiler
Temp setting
Season
Wifi signal
Display on/off
Alert / lock
BT18 Display on/off , touch press event
if(va2.val==255)
va2.val=0
dim=va2.val // backlight off
page 3 // goto page 3
page 3 touch press event
dim=255 // backlight on
page 0 // return to first page
How to animate Fan ?
I’ve created One timer tm0 and one Variable va0
this is timer event :
bt12.pic=va0.val //bt12 is fan
va0.val=va0.val+1
if(va0.val>38) //36 to 38 are the png fan pic, corresponding to the 3 fan pics positions to make it turn.
va0.val=36
Last graphic release
signal strength
Next step, the sketch
Yes, I saw it.
The mine is home made
