Master Controller Project for ESP32 and ESP8266
MasterController for ESP32/ESP8266, using Blynk Bridge to control slave controllers
In the sample project, you can use these features:
This example demontrates the use of a Master Controller (ESP32/ESP8266) to control 8 different Slave Controllers running Blynk/Alexa
- Each Slave Controller is doing diferent tasks inside an imaginary house.
- One of the Slave Controller is ESP8266-based RC-433MHz controller.
- 2 are SONOFF WiFi Smart SWs.
- 2 are ESP01 + Relay modules
- 3 are NodeMCU boards
This example uses 2-dimensional array of struct(ure)s to enable timers to control objects in Slave Controllers via Blynk Bridge.
The full code is posted in GitHub:
As you can see, the GUI design is barely acceptable, just enough to prove the concept.
If you need better GUI design, see the examples at:
