Terminal Widget doesn`t work
El Terminal Widget no conserva el rastro de los últimos 25 eventos registrados. Aparecen solo durante la sesión, pero cuando se reinicia de nuevo se borran y no permite visualizar que ha pasado.
Legacy or 2.0? In legacy you need to do a Blynk.syncVirtual(TerminalPin) when starting up or connecting.
if you’re talking about Blynk IoT then retaining the history after exiting and re-entering the mobile app has not yet been implemented.
More info here:
If your issue is different to this then I’d suggest you create a new “Need help with my project” topic and provide ALL of the information that is requested when your start that topic, as well as any other information that may be of use.
In the meantime, I’m closing this topic.
