IOS and web app
Setup a virtual pin to trigger a script, the script simply sends the terminal clear command terminal.clear(); via the BLYNK_WRITE.
Using a button set to the virtual pin in the IOS app the terminal is cleared as expected, however in the web app the terminal does not clear but displays <clr instead.
I had to use an image button in the web app as there is no simple button available as in the IOS version, not sure why.
