Yes, the business trip to UK/Lingfield and then the short vacations both are ended…
khoih
22
HI,
I just ordered and received a Teensy 4.0 because of the amazing speed, thanks to your OP.
I just began the work 15 mins, and already made it connected OK to Blynk (just via Serial/USB) to local as well as Cloud Blynk SSL/TCP).
I believe there will be no issue to make it working with Blynk. Will post update library, if necessary later.
EPV77
23
Thanks for your confirmation on this khoih .
khoih
24
Made some good progress on Teensy 4.0. It now can connect to Blynk via ESP8266 using AT command.
This is the debug terminal output, so far so good
Will post more info with library changes later.
Update Jan 29th 2020
Just posted Blynk_Teensy library mod on GitHub
Update Feb 17th 2020
Three more libraries to support Teensy, especially Teensy 4.0
