the table widget is great !
But it would be nice to be able to adjust the width of the columns!
the value is truncated, so it’s unusable
I worked around the problem by inverting the columns
My question is why the degree symbol ‘N°’ is wrong ?
I depends on how you send the character value…
like this
String Col = "| Test N°" + String(Count);
so I will try
String Col = "| Test N"+ "\u00B0C" + String(Count);
I think it’s the same for French é è ç à ù
but why ?
Not a clue… perhaps something about how Blynk uses strings to send widget data… a conversion issue perhaps?
Where is my mistake ?
String Col = “| Test N” + “\u00B0C”+ String(Count);
exit status 1
invalid operands of types ‘const char [9]’ and ‘const char [4]’ to binary ‘operator+’
Missing some brackets perhaps?
String Col = (“| Test N” + “\u00B0C”+ String(Count));
nope ![]()
setup:104:32: error: invalid operands of types ‘const char [9]’ and ‘const char [4]’ to binary ‘operator+’
String Col = ("| Test N" + "\u00B0C"+ String(Count));
exit status 1
You can always switch values for name and value columns in your Table add/update calls.
1 décembre !!!
