Hello Community,
I would like to ask about any possible solution on “Switching Internet Access Method” between WiFi, Ethernet and GSM.
• Hardware model + communication type: Arduino MEGA2560; with Arduino Ethernet Shield 2 + Sim900 GSM Module + ESP8266 Module.
Problem: I try to design a IoT gateway with 3 different internet access, i.e., Ethernet, WiFi and GSM, wish to program it to behave like a mobile phone, for example, auto detect ethernet then use ethernet, if ethernet is not available, then use wifi, if wifi is not available then use GSM.
The issue comes to the blynk library, if all library included at the same time, then using blynk.begin will cause errors.
//WiFi Library
#include <ESP8266_Lib.h>
char ssid[] = "xxx";
char pass[] = "xxx";
//Ethernet Library
#include <Ethernet2.h>
#include <BlynkSimpleEthernet2.h>
char auth[] = "xxxxxxxxxxxxxxxxxxxxxxx";
SoftwareSerial EspSerial(50,51); // RX, TX
// Your ESP8266 baud rate:
#define ESP8266_BAUD 9600
ESP8266 wifi(&EspSerial);
Blynk.begin(auth);
if(blynk.connected()==1){
serial.println("Ethernet Connected to Blynk");}
else {Blynk.begin(auth, wifi, ssid, pass);
if (blynk.connected()==1){serial.println("WiFi Connected to Blynk");}
// to avoid delay() function!
The error showing : “no matching function for call to ‘BlynkWifi::begin(char [33])’”
The code is just an example for what I tried, I also tried serval other ways but found out the library would conflict.
So I would like to ask community if anyone did similar project, could you please offer me an idea for what direction I should look at.
Many thanks in advance.
