hi, title tells the tale. I’ve tried several methods of flashing a esp8266 blynk script onto my Sonoff TH10 (thats the one with the T and humid. sensor), but each time the sonoff becomes unresponsive. When I flash it with the original software it comes alive again. I don’t know what more to post, so let me know what else I can provide to get this solved.
used:
IDE Arduino on windows 10
Flashed with DOUT setting and SPIFFS 1Mb (64k).
well it turns out that its less bricked than I thought…but not by much. I thought to check the serial montor and lo and behold:
Failed to read from DHT sensor!
etc etc etc etc
But essentially its still not working. No LED, no readout no switch not connection and even the button on the sonoff does not work!
Code:
Blynk Bridge - Communication between ESP8266
Sketch code for the master module (module which will command others) www.geekstips.com
**************************************************************/ #define BLYNK_PRINT Serial
#include <DHT.h>
char auth[] = "CENSORED";
char ssid[] = "CENSORED";
char pass[] = "CENSORED";
#define DHTPIN 2 // What digital pin we're connected to
//#define DHTTYPE DHT11 // DHT 11
#define DHTTYPE DHT22 // DHT 22, AM2302, AM2321
//#define DHTTYPE DHT21 // DHT 21, AM2301
DHT dht(DHTPIN, DHTTYPE);
void sendSensor(){
// get readings from the DHT22 sensor
float h = dht.readHumidity();
if (isnan(h) || isnan(t)) {
return;
// Send command to the second ESP
// WHEN Temperature IS OVER 28 C
// in order to open the 220V Relay
// Also update the VIRTUAL port 5
// on the second ESP
if(t > 28){
Serial.println("temperature is higher than 28");
}else{
Serial.println("temperature is lower than 28");
// Send temperature and humidity to Blynk App
// on VIRTUAL ports 5 and 6 in order to
// display on Gauge Widget
Blynk.virtualWrite(V5, h);
Blynk.virtualWrite(V6, t);
void setup(){
dht.begin();
void loop(){
digitalWrite(LED_BUILTIN, HIGH); // turn the LED on (HIGH is the voltage level)
digitalWrite(13, HIGH); // turn the LED on (HIGH is the voltage level)
delay(1000); // wait for a second
digitalWrite(LED_BUILTIN, LOW); // turn the LED off by making the voltage LOW
digitalWrite(13, LOW); // turn the LED off by making the voltage LOW
}lockquote
good point! I just grabbed that part from somewhere else but indeed yesterday ive seen a youtube tut that explained that its 4 and 14. This however does NOT explain why the leds are not flahsing!! Ill update as soon as ive updated the flash
Well, that is true, but as you see the device is working “correctly”, as it throws proper serial comm.
Perhaps you should declare the pin as output? (as initially they are inputs) pinMode (pin, OUTPUT)
Indeed that worked! Its finally flashing. However I don’t get a readout. It remains nan. Ive first added:
pinMode (DHTPIN, INPUT);
and then tried: #define DHTPIN 2 #define DHTPIN 4
and #define DHTPIN 14
all give nothing.
You’re trying to read your DHT sensor far too often. Every 5 seconds is about as often as you’ll be able to read it without problems. For most practical situations, there’s no logical reason to read the temperature this often anyway.
Also, the golden rule of Blynk is not to use delays and that your void loop shouldn’t have anything other than Blynk.run; and timer.run;
Everything else should be in a function that’s called with a timer.
I assume that this:
at the end of your code is something you copied by mistake?
@PeteKnight, I’ve been reading those at 1s interval once, but that might be their limit, as anything lower and it fails too often. The other question is: Why one need to measure air temperature so often? As an environment sensor even 1minute isn’t too small frequency.
OK, noted. Then You have an answer, why it is not working. The DHT22 is a “WIRE” sensor, and I2C has nothing common with it. You need to find another library and use TWO PINS, as required by I2C
it appears so. This is all new to me so not everything is clear. Ive read about i2c somewhere else too and recall it requires an address which dht.h clearly is not asking for. It at least is good to know that everything ‘basically’ works, but I require more advanced libraries to fully use the sonoff.
So now its time to get sonoff-tasmota compiled…sigh…( been trying that for 3 days now, but I’ve finally found a good tutorial so who knows)
What Ive got that down im gonna try to insert blynk back in. Quite the project for a n00b, slightly bit more than I can chew
Anyway thank you for the swift replies, that helped quite a bit!
Personally, I don’t like that route, mostly for the reasons that you’ve already discovered.
If you want to work on trying to get the Si7021 working with the Sonoff then here’s some info i found when doing a bit of research…
Although the Si7021 is an I2C device, the TH10 doesn’t have enough connectors in its external sensor socket to support I2C. Sonoff have therefore added an MCU to the Si7021 package to convert it into a one wire package which emulates the AM2301 sensor.
If you change this bit of your code:
to enable the DHT21/AM2301 instead of DHT22 it should work.
Are you testing this by powering it with your FTDI programmer from a USB port?
If so, then it’s probably not able to provide enough current to pull the relay in which may make you think that it’s not working.
Some people (who will remain anonymous to protect the guilty) think that the best solution is to power the Sonoff with mains power whilst keeping it connected to your PC with the FTDI programmer. PLEASE DONT DO THIS!!!
Disconnect the 4-pin FTDI connection to the board then connect the Sonoff to the mains and see if the relay works.
A bit of googling should show which GPIOs are used by the TH10.
no I connect to mains and then press the button: not working. Then again I don’t have any code added to imply the working of it. The code so far is generic esp8266 and im fairly clueless how to implement the relay part .
they’re galvanically separated so there’s little harm. The biggest danger is the open lines of the board itself, so yes anyone not knowing what they’re doing should not be doing that. (granted a bit strange to hear this from a n00b, but the n00b part doesn’t really apply to basic electricity and electronics, its the IC’s that drive me bonkers.)
yeah I thought so, but I ended up trying to read the pdf I’ve linked earlier, I can’t find anything on this. I’ll let you know if I get the sensor to work later, I’ve bot install issues with ide, so reinstalling the lot. (windows default vs windows store install…)
