[SOLVED] Using DNS for local server
When logging on in the app, to use a local server I must enter the IP address. However I do not have a static IP address. One option I have found to overcome this is to use No-IP. Is it possible to enter a DNS name in the login screen instead of an IP address?
Yes, you can do that. I use a custom DNS too, works fine!
Yes, you can use a name.
@Dmitriy, please confirm
@Pavlo @Lichtsignaal is answering on all my questions :grinning:. I have nothing to add here :wink:
Duckdns is a free DNS service. It’s easy to install and available for most popular OS platforms.
You never worry about your WAN IP address anymore.
https://www.duckdns.org/
A post was split to a new topic: Local Server acces both in network and via DNS redirect
