@vshymanskyy confirmation of the bug. Pressing V1 button turns the LED on and off, pressing V41 button doesn’t.
// Buttons in Switch mode on V1 and V41, LED on V2
char auth[] = "xxxxxxxxxxxxxxxxxx";
Blynk.begin(auth, "Office", "xxxxxxxxxx");
// Wait until connected
Blynk.syncAll();
BLYNK_WRITE(V1)
int V1test = param.asInt();
if (V1test == 1){
Blynk.virtualWrite(V2, 255);
else{
Blynk.virtualWrite(V2, 0);
// V2 LED
BLYNK_WRITE(V41)
int V41test = param.asInt();
if (V41test == 1){
else{
@vshymanskyy not sure where you want that line but changing V2 to ‘42’ gives the same results, V1 ok to LED on V42 but nothing from V41 button.
If I use V42 the sketch fails to comply with ‘V42’ was not declared in this scope so I have to use 42 and from my main sketch I can do virtualWrite’s to 42 for Value Displays (but all the other widget types I have tried fail, including syncing).
// Buttons on V1 and V41, LED on "42"
char auth[] = "xxxxxxxxxxxxxxxxx";
Blynk.begin(auth, "Office", "xxxxxxxxxxxxx");
Blynk.syncAll();
BLYNK_WRITE(V1)
if (V1test == 1){
Blynk.virtualWrite(42, 255);
else{
Blynk.virtualWrite(42, 0);
// V42 LED
BLYNK_WRITE(V41)
if (V41test == 1){
else{
@Dave1829 tried changing from SWITCH to PUSH and back again numerous times and still no joy.
Are you using an Android device and which hardware are you connecting to the Blynk server?
@vshymanskyy
I think my problem relates to the fact that I can’t compile a sketch if I refer to a virtual pin over 31 with the V prefix.
I have the latest libraries as confirmed by Serial Monitor and I have tried with board settings in the app of Wemos D1 Mini and ESP8266. Serial Monitor output with debug messages below.
[6246] Connected to WiFi
[6246] IP: 192.168.10.178
[6246] Blynk v0.3.6 on ESP8266
[6246] Connecting to blynk-cloud.com:8442
[6408] <[02|00|01|00] xxxxxxxxxxxxxxx
[6563] >[00|00|01|00]È
[6563] Ready (ping: 2ms).
[6563] <[11|00|01|00]Gver[00]0.3.6[00]h-beat[00]10[00]buff-in[00]256[00]dev[00]ESP8266[00]build[00]May 23 2016 13:56:10[00]
[6752] <[10|00|02|00|00]
[7513] >[00|00|01|00]È
[7514] >[14|00|02|00|06]
[7514] >vw[00]1[00]0
[7515] <[14|00|02|00|06]vw[00]2[00]0
[7662] <[14|00|02|00|0C]vw[00]43[00]V1 OFF
V2 OFF from V1 BUTTON
[7810] >[14|00|02|00|07]
[7810] >vw[00]41[00]0
[17811] <[06|00|03|00|00]
[17975] >[00|00|03|00]È
[21763] >[14|01]Ô[00|06]
[21763] >vw[00]1[00]1
[21764] <[14|01]Ô[00|08]vw[00]2[00]255
[22072] <[14|01]Ô[00|0B]vw[00]43[00]V1 ON
V2 ON from V1 BUTTON
[25021] >[14|01]Õ[00|06]
[25021] >vw[00]1[00]0
[25021] <[14|01]Õ[00|06]vw[00]2[00]0
[25170] <[14|01]Õ[00|0C]vw[00]43[00]V1 OFF
[27145] >[14|01]Ö[00|07]
[27145] >vw[00]41[00]1
[29852] >[14|01]×[00|07]
[29852] >vw[00]41[00]0
[35321] <[06|00|04|00|00]
[35480] >[00|00|04|00]È
[45477] <[06|00|05|00|00]
[45828] >[00|00|05|00]È
[55828] <[06|00|06|00|00]
[56068] >[00|00|06|00]È
[66069] <[06|00|07|00|00]
[66308] >[00|00|07|00]È
Latest sketch which allows me to write to pin 43 from pin 1 but not pin 44 from 41.
// Buttons on V1 and V41, LED's on V2 for V1 button and V42 for V41 button
// Value displays on V43 for V1 and V44 for V41 button
#define BLYNK_DEBUG
char auth[] = "xxxxxxxxxxxxxxxx";
BLYNK_WRITE(V1)
if (V1test == 1){
Blynk.virtualWrite(43, "V1 ON");
Serial.println("V2 ON from V1 BUTTON");
else{
Blynk.virtualWrite(43, "V1 OFF");
Serial.println("V2 OFF from V1 BUTTON");
// V2 LED
BLYNK_WRITE(V41)
if (V41test == 1){
Blynk.virtualWrite(44, "V41 ON");
Serial.println("V42 ON from V41 BUTTON");
else{
Blynk.virtualWrite(44, "V41 OFF");
Serial.println("V42 OFF from V41 BUTTON");
// V42 LED
Blynk.begin(auth, "Office", "xxxxxxxxx");
Blynk.syncAll();
Is anyone successfully using an ‘ESP’ with more than 32 virtual pins for anything more than the Value Display widget?
@vshymanskyy when it was announced that virtual pins had been extended to 128 there was an indication that is might not initially be available for “ESP’s”. This infers that it might only initially be for Arduino’s like @Dave1829’s Mega even though most ESP’s are MUCH more ‘powerful’ than the Arduino’s.
Can you confirm 128 virtual pins are fully functional, sliders, button, Timer widgets etc, for ESP’s as the only widget that works for me is the Value Display.
When I say unstable I mean dropping the connection to the Blynk cloud server and reconnecting.
Initially I just removed the 3 or 4 lines from BlynkSimpleEsp8266.h to get the virtual pins > 31 working rather than using the full master branch. Same result of constant disconnects with the latest full master branch.
A few observations for you:
A. When the WeMos D1 Mini connects it now states:
Blynk v0.3.7 on NodeMCU
With earlier versions it was just Blynk v0.3.X and then Blynk v0.3.X ESP8266
I have the WeMos D1 Mini selected from the board manager. Is the reference to NodeMCU the problem as the WeMos is quite different to a NodeMCU?
B. I have noticed that if the Blynk app is ‘running’ in the background the disconnects from the server stop. This is a temporary fix for the project to continue processing the sketch but as soon as I return to the Blynk app the disconnects restart. The disconnects occur without any buttons being pressed in the app. When I refer to running in the background I mean simply going to the Android home page, not stopping the app.
@psoro does your Mini now join the server as an NodeMCU?
