My project is taking answer of riddle and giving marbles on every correct answer…how to take text input in blynk
Can you post your code?
Remember:
Ah, are you asking how to completely delete or clear the terminal display when you need to?
I don’t believe there is currently a way to completely clear the display (meaning you can always “scroll” up to see previous prints). I use a series of terminal.println(); to make the terminal appear cleared.
Yes, that’s correct per How do I clear the terminal screen on Android app?.
Ha! Well good!
Depending on how many combinations of questions and answers you have, the code may get pretty complicated.
Have you seen this example sketch? https://github.com/blynkkk/blynk-library/blob/master/examples/Widgets/Terminal/Terminal.ino
Might be a good place to start… then work on making that more complicated as needed.
