thank you for your replay!
i dont think your code will help because i want him to enter some loop with the terminal and then enter new data…
my entire code:
- This example runs directly on ESP8266 chip.
- You need to install this for ESP8266 development:
- https://github.com/esp8266/Arduino
- Please be sure to select hte right ESP8266 module
- in the Tools -> Board menu!
- Change WiFi ssid, pass, and Blynk auth token to run
char auth[] = “xxxxxxxxxxxxxxxxx”;
int led = 13;
int state = 0;
int past_state = 1;
String mypassword = “0000”;
uint16_t node_address = 02;
String tmp = “7”;
String tmp1 = “9”;
// Attach virtual serial terminal to Virtual Pin V1
WidgetTerminal terminal(V1);
pinMode(led,OUTPUT);
digitalWrite(led,HIGH);
delay(2000);
digitalWrite(led,LOW);
Blynk.begin(auth, “shtainer”, “yoav1234”);
// Wait until connected
// This will print Blynk Software version to the Terminal Widget when
// your hardware gets connected to Blynk Server
terminal.println(F(“Blynk v” BLYNK_VERSION “: Device started”));
terminal.println("-------------");
//terminal.println(“Type ‘Marco’ and get a reply, or type”);
//terminal.println(“anything else and get it printed back.”);
terminal.flush();
// You can send commands from Terminal to your hardware. Just use
// the same Virtual Pin as your Terminal Widget
BLYNK_WRITE(V1)
// // if you type “Marco” into Terminal Widget - it will respond: “Polo:”
// if (String(“Marco”) == param.asStr()) {
// terminal.println(“You said: ‘Marco’”) ;
// terminal.println(“I said: ‘Polo’”) ;
// } else {
// // Send it back
// terminal.print(“You said:”);
// terminal.write(param.getBuffer(), param.getLength());
// terminal.println();
if(mypassword == param.asStr())
mypassword="";
char c;
for(int i=0;i<8;i++)
c = char(random(120));
mypassword+=c;
terminal.println("my new password is: "+mypassword);
Serial.println("my new password is: "+mypassword);
if(String(“node”) == param.asStr()){
terminal.println("please enter my new node_address: ");
delay(5000);
// Ensure everything is sent
terminal.flush();
tmp1 = param.asStr();
Serial.println(“my tmp1:”);
Serial.println(tmp1);
node_address = (uint16_t) tmp1.toInt();
Serial.println(“my node_address:”);
Serial.println(node_address);
terminal.flush();
state = digitalRead(led);
if(mypassword==“0000”){
terminal.println("please enter my password: ");delay(500);}
if(state!=past_state)
if(state==1)
Serial.println(“1”);
Serial.println(“0”);
past_state = state;
