This project works quite similiar to mine. So i follow what he wrote and auto-mode work like a charm. i delete the timer so it wont overflow to the next timer which caused an infinite cycle. YAY! Phew, after so many hours.
Yeah. Thanks Gunner and sorry
Another question, Can hardware receive sensor data from blynk uploaded by another device? through this method (with same auth token)
No apologies necessary! Glad you got it doing what you want it to [quote=“Wesley, post:23, topic:13752”]
[/quote]
Not quite that method (but you can control multiple devices from the app with same or different auth codes) … but yes, sharing data from device to device can be done via bridge command:
Ay the variable name is just a way to call an object of the type Simpletimer, every simpletimer object can hold 10 timed events, and every event has its specific ID for manipulation
The type is SimpleTimer
You are a human
You call an object of Simpletimer, timer1
You are called doktor Emmet Brown
Timer1 can run ten timers
Emmet Brown can move ten fingers
