Below is my code and it is a pre-canned example which I cannot get working.
I believe the code below works based on what I posted above therefore I guess the problem is on the app?
But, it is so simple I don’t know what it might be?
http://twitter.com/blynk_app
This example shows how to send values to the Blynk App,
when there is a widget, attached to the Virtual Pin and it
is set to some frequency
Project setup in the app:
Value Display widget attached to V5. Set any reading
frequency (i.e. 1 second)
#define BLYNK_DEBUG // Optional, this enables lots of prints
char auth[] = “61e36646377b4d91a79db935b8db229c”;
// Set password to “” for open networks.
char ssid[] = “???”;
char pass[] = “1234”;
// Use Virtual pin 5 for uptime display
#define PIN_UPTIME V5
// This function tells Arduino what to do if there is a Widget
// which is requesting data for Virtual Pin (5)
BLYNK_READ(PIN_UPTIME)
// This command writes Arduino’s uptime in seconds to Virtual Pin (5)
Blynk.virtualWrite(PIN_UPTIME, millis() / 1000);
//Blynk.begin(auth, ssid, pass);
Blynk.begin(auth, ssid, pass, “blynk-cloud.com”, 80);
