Gunner Thanks for all your help!! I think I finally got it figured out I will post the updated code with no delay to get your thoughts on anything else i could do to make it better. The sketch compiles and everything is working as intended
http://twitter.com/blynk_app
You’ll need:
- Blynk App (download from AppStore or Google Play)
- Arduino Ethernet board
example.
#include <Ethernet.h>
#include <OneWire.h>
// Date and time functions using a DS3231 RTC connected via I2C and Wire lib
#include <Wire.h>
#include "RTClib.h"
LiquidCrystal_I2C lcd(0x27,16,2); // set the LCD address to 0x27 for a 16 chars and 2 line display
#define ONE_WIRE_BUS 7 //Arduino Mega Digital Pin 7
RTC_DS3231 rtc;
char auth[] = "***********************";
#define W5100_CS 10
#define SDCARD_CS 4
/*-----( Declare Constants )-----*/
#define RELAY_ON 0
#define RELAY_OFF 1
/*-----( Declare objects )-----*/
/*-----( Declare Variables )-----*/
#define Relay_1 40 // Arduino Digital I/O pin number
#define Relay_2 41
#define Relay_3 42
#define Relay_4 43
int displayState = 0;
int GreenhouseTemp; // Greenhouse temperature in F
unsigned long previousMillis1 = 0; // will store last time Display was updated
long interval = 3000; // m
//int timeState = LOW;
unsigned long previousMillis2 = 0; // will store last time Time was updated
long OnTime = 100; // milliseconds of on-time
long OffTime = 200; // milliseconds of off-time
int sensorPin = 0; // select the input pin for the potentiometer
int sensorValue = 0; // variable to store the value coming from the sensor
pinMode(SDCARD_CS, OUTPUT);
digitalWrite(SDCARD_CS, HIGH); // Deselect the SD card
//Blynk.begin(auth);
Blynk.begin(auth, "blynk-cloud.com", 8442);
//Blynk.begin(auth, IPAddress(192,168,10,222), 8442);
// Send e-mail when your hardware gets connected to Blynk Server
// Just put the recepient's "e-mail address", "Subject" and the "message body"
Blynk.email("***********************", "Subject", "Greenhouse is online.");
lcd.init(); // initialize the lcd
lcd.backlight(); // Turn on LCD Backlight
// Uncomment to set time to PC time
//rtc.begin();
//rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
if (! rtc.begin()) {
Serial.println("Couldn't find RTC");
while (1);
if (rtc.lostPower()) {
//Serial.println("RTC lost power, lets set the time!");
// following line sets the RTC to the date & time this sketch was compiled
rtc.adjust (DateTime(F(__DATE__), F(__TIME__)));
// This line sets the RTC with an explicit date & time, for example to set
// January 21, 2014 at 3am you would call:
// Adjust Time on line Below
//rtc.adjust(DateTime(2017, 8, 23, 10, 36, 0));
//---( THEN set pins as outputs )----
pinMode(Relay_1, OUTPUT);
pinMode(Relay_2, OUTPUT);
pinMode(Relay_3, OUTPUT);
pinMode(Relay_4, OUTPUT);
//delay(1000); //Check that all relays are inactive at Reset
//-------( Initialize Pins so relays are inactive at reset)----
digitalWrite(Relay_1, RELAY_OFF);
digitalWrite(Relay_2, RELAY_OFF);
digitalWrite(Relay_3, RELAY_OFF);
digitalWrite(Relay_4, RELAY_OFF);
timer.setInterval(1000L, Date_Time );
timer.setInterval(1000L, sendTemps );
timer.setInterval(3000L, LCDdisplay );
timer.setInterval(1000L, Temp );
timer.setInterval(1000L, sendTime );
// to avoid delay() function!
void sendTemps()
sensors.requestTemperatures(); // Polls the sensors.
GreenhouseTemp = sensors.getTempFByIndex(0); // Stores temperature. Change to getTempCByIndex(0) for celcius.
Blynk.virtualWrite(V5, GreenhouseTemp); // Send temperature to Blynk app virtual pin 1.
void sendTime()
DateTime now = rtc.now();
char dateBuffer[12];
sprintf(dateBuffer,"%02u:%02u ",now.hour(),now.minute());
Serial.println(dateBuffer);
Blynk.virtualWrite(V1,dateBuffer);
void LCDdisplay()
// check to see if it's time to change the state of the LED
unsigned long currentMillis = millis();
if((displayState == 0) && (currentMillis - previousMillis1 >= interval))
displayState = 1; // Turn it off
// set up the LCD's number of columns and rows:
// Print a message to the LCD.
lcd.clear ();
lcd.setCursor(0, 0);
lcd.print ("Windy Ridge Farm");
else if ((displayState == 1) && (currentMillis - previousMillis1 >= interval))
displayState = 2; // turn it on
previousMillis1 = currentMillis; // Remember the time
lcd.clear ();
lcd.print("Greenhouse Temp:" );
// set the cursor to column 0, line 1
// (note: line 1 is the second row, since counting begins with 0):
lcd.setCursor(0, 1);
lcd.print(GreenhouseTemp);
lcd.print((char)223);
lcd.print ("F");
else if((displayState == 2) && (currentMillis - previousMillis1 >= interval))
displayState = 0; // Turn it off
//Print Second Line
lcd.clear ();
lcd.print ("Eastern Time:");
lcd.print(dateBuffer);
void Date_Time ()
sprintf(dateBuffer,"%02u-%02u-%04u ",now.month(),now.day(),now.year());
Serial.print(dateBuffer);
sprintf(dateBuffer,"%02u:%02u:%02u ",now.hour(),now.minute(),now.second());
// ********Watering Schedule***********
int SchOn1 = (now.hour() == 8 & now.minute() == 30 & now.second() <= 10);
int SchOff1= (now.hour() == 8 & now.minute() == 33 & now.second() <= 10);
int SchOn2 = (now.hour() == 17 & now.minute() == 30 & now.second() <= 10);
int SchOff2= (now.hour() == 17 & now.minute() == 33 & now.second() <= 10);
if((SchOn1) && (currentMillis - previousMillis2 >= OnTime))
Blynk.notify("Plants Just Watered!");
Blynk.email("***********************", "Subject: Greenhouse", "Plants Just Watered!");
digitalWrite(Relay_2, RELAY_ON);// Turn the Watering Relay ON
else if ((SchOff1) && (currentMillis - previousMillis2 >= OffTime))
previousMillis2 = currentMillis; // Remember the time
digitalWrite(Relay_2, RELAY_OFF);// Turn the Watering Relay OFF
if((SchOn2) && (currentMillis - previousMillis2 >= OnTime))
else if ((SchOff2) && (currentMillis - previousMillis1 >= OffTime))
void Temp()
//***********Cooling Code***************
if (GreenhouseTemp >= 85)
{ digitalWrite (Relay_1, RELAY_ON);}//Greenhouse Temp Control Fan ON Above 85 Degrees
else if ((GreenhouseTemp > 73) && (GreenhouseTemp< 75))
{ digitalWrite (Relay_1, RELAY_OFF);} //Greenhouse Temp Control coolingFan OFF Below 75 Degrees
bool tempflag = true;
if ((GreenhouseTemp >= 95) && (tempflag == true))
Blynk.notify("GREENHOUSE OVERHEATING!!!");
tempflag = false;
if (GreenhouseTemp < 95)
tempflag = true;
//*************Heating Code****************
if ((GreenhouseTemp > 55) && (GreenhouseTemp< 57))
{ digitalWrite (Relay_3, RELAY_OFF);} //Greenhouse Temp Control Heater Fan OFF Above 55 Degrees F
if (GreenhouseTemp <= 45.00)
{ digitalWrite (Relay_3, RELAY_ON);} //Greenhouse Temp Control Heater Fan ON Below 45 Degrees F
