Hey there,
I have really gone through all of the threads pertaining to my issue, have read all of the documentation provided and yet cannot solve my possibly very silly mistake i am doing. This is the only comment that might have shown me i am doing something wrong, so I really hope you can help me.
I have added this bit of code to my script :
BLYNK_READ(V5) // Display Widget set to reading rate frequency
Blynk.virtualWrite(V5, analogRead(A0)); // Send analog pin value to display Widget at set frequency
I have added a gauge that is perfectly reading moisture levels when set to V5, and a set frequency (1 sec)
My Eventor conditions work perfectly as long as I am inside the app, just like you said, but I can’t for the life of me, understand what I have to do to have the conditions constantly working.
Would really appreciate any help with that
cpp
#include <SPI.h>;
#include <ESP8266WiFi.h>;
#include <BlynkSimpleEsp8266.h>;
#include <SimpleTimer.h>;
#include <DHT.h>;
char auth[] = "";
char ssid[] = "";
char pass[] = "";
BLYNK_READ(V5)
#define DHTPIN 4 // What digital pin we're connected to
//#define DHTTYPE DHT22 // DHT 22, AM2302, AM2321
//#define DHTTYPE DHT21 // DHT 21, AM2301
DHT dht(DHTPIN, DHTTYPE);
// This function sends Arduino's up time every second to Virtual Pin (5, 6, 7 &amp;amp;amp;amp;amp; 8).
void sendSensor()
float h = dht.readHumidity();
if (isnan(h) || isnan(t)) {
return;
Blynk.virtualWrite(V4, h); // Humidity for gauge
Blynk.virtualWrite(V6, t); // Temperature for gauge
Serial.begin(115200); // See the connection status in Serial Monitor
dht.begin();
