Congratulations for your platform! I have some issues though.
I use the blink example https://examples.blynk.cc/?board=Arduino%20Uno&shield=ESP8266%20WiFi%20Shield&example=GettingStarted%2FBlynkBlink
in the arduino nano, with the esp8266 esp01 and i have this issue; i upload this code and the arduino connects to my wifi network, but it cannot connect to blynk. is there a solution for that?
the code that i used
http://twitter.com/blynk_app
WARNING!
It's rather tricky to get it working, please read this article:
https://github.com/blynkkk/blynk-library/wiki/ESP8266-with-AT-firmware
You’ll need:
- Blynk App (download from AppStore or Google Play)
- Arduino Uno board
example.
#include <ESP8266_Lib.h>
char auth[] = "97175df40818441db1431c48dbdde088";
char ssid[] = "Xaratsi";
char pass[] = "xxxxxxxxxxx";
//#define EspSerial Serial1
// Your ESP8266 baud rate:
#define ESP8266_BAUD 9600
ESP8266 wifi(&EspSerial);
// Set ESP8266 baud rate
//Blynk.begin(auth, wifi, ssid, pass, "blynk-cloud.com", 8442);
//Blynk.begin(auth, wifi, ssid, pass, IPAddress(192,168,1,100), 8442);
// to avoid delay() function!
in this photo shows my circuit, the esp01 is fed with 5V and is regulated through the adater that is shon in the picture.
in the serial monitor only this is printed, and it’s seen that it has the flash that refers to the docs.
in this picture appears that the circuit is not connected to the blynk , although I use the same authorative.
Thank you in advance
