I using adafruit lib for dht11 and whenever I compile the programming, Example code generated by sketch builder , it error:
Error running c:\users\joão gabriel\appdata\local\arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2\bin…/lib/gcc/avr/4.9.2/…/…/…/…/avr/bin/ar.exe: CreateProcess
exit status 1
Erro compilando para a placa Arduino/Genuino Uno
“error compiling for arduino/genuino uno board ”
Gunner
May 16, 2017, 11:43pm
2
This Forum is for Blynk related use, not a faulty code repair depot
You have some form of poor syntax in your sketch, but unless you post your code here, we can’t see it.
Or check with https://forums.adafruit.com/ (if your sensor came from them)
Gunner:
my code is example made by blynk:
> Download latest Blynk library here:
> https://github.com/blynkkk/blynk-library/releases/latest
> Blynk is a platform with iOS and Android apps to control
> Arduino, Raspberry Pi and the likes over the Internet.
> You can easily build graphic interfaces for all your
> projects by simply dragging and dropping widgets.
> Downloads, docs, tutorials: http://www.blynk.cc
> Sketch generator: http://examples.blynk.cc
> Blynk community: http://community.blynk.cc
> Follow us: http://www.fb.com/blynkapp
> http://twitter.com/blynk_app
> Blynk library is licensed under MIT license
> This example code is in public domain.
> This example shows how value can be pushed from Arduino to
> the Blynk App.
> WARNING :
> For this example you'll need Adafruit DHT sensor libraries:
> https://github.com/adafruit/Adafruit_Sensor
> https://github.com/adafruit/DHT-sensor-library
> App project setup:
> Value Display widget attached to V5
> Value Display widget attached to V6
> /* Comment this out to disable prints and save space */
> #define BLYNK_PRINT Serial
> #include <SPI.h>
> #include <Ethernet.h>
> #include <BlynkSimpleEthernet.h>
> #include <DHT.h>
> // You should get Auth Token in the Blynk App.
> // Go to the Project Settings (nut icon).
> char auth[] = "YourAuthToken";
> #define DHTPIN 2 // What digital pin we're connected to
> // Uncomment whatever type you're using!
> #define DHTTYPE DHT11 // DHT 11
> //#define DHTTYPE DHT22 // DHT 22, AM2302, AM2321
> //#define DHTTYPE DHT21 // DHT 21, AM2301
> DHT dht(DHTPIN, DHTTYPE);
> BlynkTimer timer;
> // This function sends Arduino's up time every second to Virtual Pin (5).
> // In the app, Widget's reading frequency should be set to PUSH. This means
> // that you define how often to send data to Blynk App.
> void sendSensor()
> float h = dht.readHumidity();
> float t = dht.readTemperature(); // or dht.readTemperature(true) for Fahrenheit
> if (isnan(h) || isnan(t)) {
> Serial.println("Failed to read from DHT sensor!");
> return;
> // You can send any value at any time.
> // Please don't send more that 10 values per second.
> Blynk.virtualWrite(V5, h);
> Blynk.virtualWrite(V6, t);
> void setup()
> // Debug console
> Serial.begin(9600);
> Blynk.begin(auth);
> dht.begin();
> // Setup a function to be called every second
> timer.setInterval(1000L, sendSensor);
> void loop()
> Blynk.run();
> timer.run();
Gunner
May 16, 2017, 11:48pm
4
Did you properly install these libraries?
Gunner
May 16, 2017, 11:50pm
5
This sketch also looks to be for an Arduino with Ethernet shield… can you confirm the exact hardware you are using.
I went to the generator of codes here of the site, I put my board and the ethernet shield, I installed the libiotecas
The exact code is this:
the Blynk App.
WARNING :
App project setup:
#include <DHT.h>
#define W5100_CS 10
#define SDCARD_CS 4
void sendSensor()
return;
pinMode(SDCARD_CS, OUTPUT);
digitalWrite(SDCARD_CS, HIGH); // Deselect the SD card
Blynk.begin(auth);
//Blynk.begin(auth, "blynk-cloud.com", 8442);
//Blynk.begin(auth, IPAddress(192,168,1,100), 8442);
dht.begin();
Gunner
May 16, 2017, 11:58pm
8
The sketch is fine, however you still need to have all the correct libraries installed in your IDE and properly set up for your hardware… just like any other sketch you find on the internet.
Gunner
May 17, 2017, 12:00am
9
Can you copy the full error and show it here. Thanks.
The libraries are installed and working correctly, the IDE board is like UNO and everything is correct COM port and everything, I send the basic code of Blynk and it works, but I add the DHT11 code I showed above, and that error appears, I tried With numerous DHT libraries but apparently none works.
Gunner
May 17, 2017, 12:07am
11
Well, what little I can read of your error, you have something wrong in your IDE, libraries or settings.
Is your IDE up to date and as well as all libraries and boards?
Can you copy/paste the full error here please… I will try to translate it
Gunner:
error is this nothing more, nothing less,
My IDE is 1.8.2
Gunner
May 17, 2017, 12:25am
13
There must be a bit more… try to compile again and use the copy button on the lower right of the IDE, then paste it all here (I will edit it to format properly)
Arduino: 1.8.2 (Windows 10), Board: “Arduino/Genuino Uno”
exit status 1
Error compiling for board Arduino/Genuino Uno.
“Show verbose output during compilation”
Costas
May 17, 2017, 10:14pm
15
Action this and paste the verbose compiler error.
Arduino: 1.8.2 (Windows 10), Board: "Arduino/Genuino Uno"
D:\Arquivos de Programas\Arduino\arduino-builder -dump-prefs -logger=machine -hardware D:\Arquivos de Programas\Arduino\hardware -hardware C:\Users\João Gabriel\AppData\Local\Arduino15\packages -tools D:\Arquivos de Programas\Arduino\tools-builder -tools D:\Arquivos de Programas\Arduino\hardware\tools\avr -tools C:\Users\João Gabriel\AppData\Local\Arduino15\packages -built-in-libraries D:\Arquivos de Programas\Arduino\libraries -libraries C:\Users\João Gabriel\Documents\Arduino\libraries -fqbn=arduino:avr:uno -ide-version=10802 -build-path C:\Users\JOOGAB~1\AppData\Local\Temp\arduino_build_869974 -warnings=none -build-cache C:\Users\JOOGAB~1\AppData\Local\Temp\arduino_cache_747773 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9 -prefs=runtime.tools.avr-gcc.path=C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2 -prefs=runtime.tools.arduinoOTA.path=C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.1.1 -verbose C:\Users\JOOGAB~1\AppData\Local\Temp\arduino_modified_sketch_947039\sketch_may17a.ino
D:\Arquivos de Programas\Arduino\arduino-builder -compile -logger=machine -hardware D:\Arquivos de Programas\Arduino\hardware -hardware C:\Users\João Gabriel\AppData\Local\Arduino15\packages -tools D:\Arquivos de Programas\Arduino\tools-builder -tools D:\Arquivos de Programas\Arduino\hardware\tools\avr -tools C:\Users\João Gabriel\AppData\Local\Arduino15\packages -built-in-libraries D:\Arquivos de Programas\Arduino\libraries -libraries C:\Users\João Gabriel\Documents\Arduino\libraries -fqbn=arduino:avr:uno -ide-version=10802 -build-path C:\Users\JOOGAB~1\AppData\Local\Temp\arduino_build_869974 -warnings=none -build-cache C:\Users\JOOGAB~1\AppData\Local\Temp\arduino_cache_747773 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9 -prefs=runtime.tools.avr-gcc.path=C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2 -prefs=runtime.tools.arduinoOTA.path=C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.1.1 -verbose C:\Users\JOOGAB~1\AppData\Local\Temp\arduino_modified_sketch_947039\sketch_may17a.ino
Using board 'uno' from platform in folder: C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18
Using core 'arduino' from platform in folder: C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18
Detecting libraries used...
"C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\variants\standard" "C:\Users\JOOGAB~1\AppData\Local\Temp\arduino_build_869974\sketch\sketch_may17a.ino.cpp" -o "nul"
"C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\variants\standard" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\libraries\SPI\src" "C:\Users\JOOGAB~1\AppData\Local\Temp\arduino_build_869974\sketch\sketch_may17a.ino.cpp" -o "nul"
"C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\variants\standard" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\libraries\SPI\src" "-ID:\Arquivos de Programas\Arduino\libraries\Ethernet\src" "C:\Users\JOOGAB~1\AppData\Local\Temp\arduino_build_869974\sketch\sketch_may17a.ino.cpp" -o "nul"
"C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\variants\standard" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\libraries\SPI\src" "-ID:\Arquivos de Programas\Arduino\libraries\Ethernet\src" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\Blynk\src" "C:\Users\JOOGAB~1\AppData\Local\Temp\arduino_build_869974\sketch\sketch_may17a.ino.cpp" -o "nul"
"C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\variants\standard" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\libraries\SPI\src" "-ID:\Arquivos de Programas\Arduino\libraries\Ethernet\src" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\Blynk\src" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\DHT_sensor_library" "C:\Users\JOOGAB~1\AppData\Local\Temp\arduino_build_869974\sketch\sketch_may17a.ino.cpp" -o "nul"
"C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\variants\standard" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\libraries\SPI\src" "-ID:\Arquivos de Programas\Arduino\libraries\Ethernet\src" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\Blynk\src" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\DHT_sensor_library" "C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\libraries\SPI\src\SPI.cpp" -o "nul"
"C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\variants\standard" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\libraries\SPI\src" "-ID:\Arquivos de Programas\Arduino\libraries\Ethernet\src" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\Blynk\src" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\DHT_sensor_library" "D:\Arquivos de Programas\Arduino\libraries\Ethernet\src\Dhcp.cpp" -o "nul"
"C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\variants\standard" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\libraries\SPI\src" "-ID:\Arquivos de Programas\Arduino\libraries\Ethernet\src" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\Blynk\src" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\DHT_sensor_library" "D:\Arquivos de Programas\Arduino\libraries\Ethernet\src\Dns.cpp" -o "nul"
"C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\variants\standard" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\libraries\SPI\src" "-ID:\Arquivos de Programas\Arduino\libraries\Ethernet\src" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\Blynk\src" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\DHT_sensor_library" "D:\Arquivos de Programas\Arduino\libraries\Ethernet\src\Ethernet.cpp" -o "nul"
"C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\variants\standard" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\libraries\SPI\src" "-ID:\Arquivos de Programas\Arduino\libraries\Ethernet\src" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\Blynk\src" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\DHT_sensor_library" "D:\Arquivos de Programas\Arduino\libraries\Ethernet\src\EthernetClient.cpp" -o "nul"
"C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\variants\standard" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\libraries\SPI\src" "-ID:\Arquivos de Programas\Arduino\libraries\Ethernet\src" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\Blynk\src" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\DHT_sensor_library" "D:\Arquivos de Programas\Arduino\libraries\Ethernet\src\EthernetServer.cpp" -o "nul"
"C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\variants\standard" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\libraries\SPI\src" "-ID:\Arquivos de Programas\Arduino\libraries\Ethernet\src" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\Blynk\src" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\DHT_sensor_library" "D:\Arquivos de Programas\Arduino\libraries\Ethernet\src\EthernetUdp.cpp" -o "nul"
"C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\variants\standard" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\libraries\SPI\src" "-ID:\Arquivos de Programas\Arduino\libraries\Ethernet\src" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\Blynk\src" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\DHT_sensor_library" "D:\Arquivos de Programas\Arduino\libraries\Ethernet\src\utility\socket.cpp" -o "nul"
"C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\variants\standard" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\libraries\SPI\src" "-ID:\Arquivos de Programas\Arduino\libraries\Ethernet\src" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\Blynk\src" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\DHT_sensor_library" "D:\Arquivos de Programas\Arduino\libraries\Ethernet\src\utility\w5100.cpp" -o "nul"
"C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\variants\standard" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\libraries\SPI\src" "-ID:\Arquivos de Programas\Arduino\libraries\Ethernet\src" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\Blynk\src" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\DHT_sensor_library" "C:\Users\João Gabriel\Documents\Arduino\libraries\Blynk\src\utility\BlynkDebug.cpp" -o "nul"
"C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\variants\standard" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\libraries\SPI\src" "-ID:\Arquivos de Programas\Arduino\libraries\Ethernet\src" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\Blynk\src" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\DHT_sensor_library" "C:\Users\João Gabriel\Documents\Arduino\libraries\Blynk\src\utility\BlynkHandlers.cpp" -o "nul"
"C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\variants\standard" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\libraries\SPI\src" "-ID:\Arquivos de Programas\Arduino\libraries\Ethernet\src" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\Blynk\src" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\DHT_sensor_library" "C:\Users\João Gabriel\Documents\Arduino\libraries\Blynk\src\utility\BlynkTimer.cpp" -o "nul"
"C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\variants\standard" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\libraries\SPI\src" "-ID:\Arquivos de Programas\Arduino\libraries\Ethernet\src" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\Blynk\src" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\DHT_sensor_library" "C:\Users\João Gabriel\Documents\Arduino\libraries\Blynk\src\utility\utility.cpp" -o "nul"
"C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\variants\standard" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\libraries\SPI\src" "-ID:\Arquivos de Programas\Arduino\libraries\Ethernet\src" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\Blynk\src" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\DHT_sensor_library" "C:\Users\João Gabriel\Documents\Arduino\libraries\DHT_sensor_library\DHT.cpp" -o "nul"
"C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\variants\standard" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\libraries\SPI\src" "-ID:\Arquivos de Programas\Arduino\libraries\Ethernet\src" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\Blynk\src" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\DHT_sensor_library" "C:\Users\João Gabriel\Documents\Arduino\libraries\DHT_sensor_library\DHT_U.cpp" -o "nul"
"C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\variants\standard" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\libraries\SPI\src" "-ID:\Arquivos de Programas\Arduino\libraries\Ethernet\src" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\Blynk\src" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\Adafruit_Sensor" "C:\Users\João Gabriel\Documents\Arduino\libraries\DHT_sensor_library\DHT_U.cpp" -o "nul"
Generating function prototypes...
part 1
"C:\Users\JOOGAB~1\AppData\Local\Temp\arduino_build_869974\sketch\sketch_may17a.ino.cpp" -o "C:\Users\JOOGAB~1\AppData\Local\Temp\arduino_build_869974\preproc\ctags_target_for_gcc_minus_e.cpp"
"D:\Arquivos de Programas\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\JOOGAB~1\AppData\Local\Temp\arduino_build_869974\preproc\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\variants\standard" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\libraries\SPI\src" "-ID:\Arquivos de Programas\Arduino\libraries\Ethernet\src" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\Blynk\src" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\Adafruit_Sensor" "C:\Users\JOOGAB~1\AppData\Local\Temp\arduino_build_869974\sketch\sketch_may17a.ino.cpp" -o "C:\Users\JOOGAB~1\AppData\Local\Temp\arduino_build_869974\sketch\sketch_may17a.ino.cpp.o"
Compiling libraries...
Compiling library "SPI"
"C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\variants\standard" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\libraries\SPI\src" "-ID:\Arquivos de Programas\Arduino\libraries\Ethernet\src" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\Blynk\src" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\Adafruit_Sensor" "C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\libraries\SPI\src\SPI.cpp" -o "C:\Users\JOOGAB~1\AppData\Local\Temp\arduino_build_869974\libraries\SPI\SPI.cpp.o"
Compiling library "Ethernet"
"C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\variants\standard" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\libraries\SPI\src" "-ID:\Arquivos de Programas\Arduino\libraries\Ethernet\src" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\Blynk\src" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\Adafruit_Sensor" "D:\Arquivos de Programas\Arduino\libraries\Ethernet\src\Dhcp.cpp" -o "C:\Users\JOOGAB~1\AppData\Local\Temp\arduino_build_869974\libraries\Ethernet\Dhcp.cpp.o"
"C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\variants\standard" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\libraries\SPI\src" "-ID:\Arquivos de Programas\Arduino\libraries\Ethernet\src" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\Blynk\src" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\Adafruit_Sensor" "D:\Arquivos de Programas\Arduino\libraries\Ethernet\src\Dns.cpp" -o "C:\Users\JOOGAB~1\AppData\Local\Temp\arduino_build_869974\libraries\Ethernet\Dns.cpp.o"
"C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\variants\standard" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\libraries\SPI\src" "-ID:\Arquivos de Programas\Arduino\libraries\Ethernet\src" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\Blynk\src" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\Adafruit_Sensor" "D:\Arquivos de Programas\Arduino\libraries\Ethernet\src\Ethernet.cpp" -o "C:\Users\JOOGAB~1\AppData\Local\Temp\arduino_build_869974\libraries\Ethernet\Ethernet.cpp.o"
"C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\variants\standard" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\libraries\SPI\src" "-ID:\Arquivos de Programas\Arduino\libraries\Ethernet\src" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\Blynk\src" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\Adafruit_Sensor" "D:\Arquivos de Programas\Arduino\libraries\Ethernet\src\EthernetClient.cpp" -o "C:\Users\JOOGAB~1\AppData\Local\Temp\arduino_build_869974\libraries\Ethernet\EthernetClient.cpp.o"
"C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\variants\standard" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\libraries\SPI\src" "-ID:\Arquivos de Programas\Arduino\libraries\Ethernet\src" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\Blynk\src" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\Adafruit_Sensor" "D:\Arquivos de Programas\Arduino\libraries\Ethernet\src\EthernetServer.cpp" -o "C:\Users\JOOGAB~1\AppData\Local\Temp\arduino_build_869974\libraries\Ethernet\EthernetServer.cpp.o"
"C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\variants\standard" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\libraries\SPI\src" "-ID:\Arquivos de Programas\Arduino\libraries\Ethernet\src" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\Blynk\src" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\Adafruit_Sensor" "D:\Arquivos de Programas\Arduino\libraries\Ethernet\src\EthernetUdp.cpp" -o "C:\Users\JOOGAB~1\AppData\Local\Temp\arduino_build_869974\libraries\Ethernet\EthernetUdp.cpp.o"
"C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\variants\standard" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\libraries\SPI\src" "-ID:\Arquivos de Programas\Arduino\libraries\Ethernet\src" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\Blynk\src" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\Adafruit_Sensor" "D:\Arquivos de Programas\Arduino\libraries\Ethernet\src\utility\socket.cpp" -o "C:\Users\JOOGAB~1\AppData\Local\Temp\arduino_build_869974\libraries\Ethernet\utility\socket.cpp.o"
"C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\variants\standard" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\libraries\SPI\src" "-ID:\Arquivos de Programas\Arduino\libraries\Ethernet\src" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\Blynk\src" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\Adafruit_Sensor" "D:\Arquivos de Programas\Arduino\libraries\Ethernet\src\utility\w5100.cpp" -o "C:\Users\JOOGAB~1\AppData\Local\Temp\arduino_build_869974\libraries\Ethernet\utility\w5100.cpp.o"
Compiling library "Blynk"
"C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\variants\standard" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\libraries\SPI\src" "-ID:\Arquivos de Programas\Arduino\libraries\Ethernet\src" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\Blynk\src" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\Adafruit_Sensor" "C:\Users\João Gabriel\Documents\Arduino\libraries\Blynk\src\utility\BlynkDebug.cpp" -o "C:\Users\JOOGAB~1\AppData\Local\Temp\arduino_build_869974\libraries\Blynk\utility\BlynkDebug.cpp.o"
"C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\variants\standard" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\libraries\SPI\src" "-ID:\Arquivos de Programas\Arduino\libraries\Ethernet\src" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\Blynk\src" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\Adafruit_Sensor" "C:\Users\João Gabriel\Documents\Arduino\libraries\Blynk\src\utility\BlynkHandlers.cpp" -o "C:\Users\JOOGAB~1\AppData\Local\Temp\arduino_build_869974\libraries\Blynk\utility\BlynkHandlers.cpp.o"
"C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\variants\standard" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\libraries\SPI\src" "-ID:\Arquivos de Programas\Arduino\libraries\Ethernet\src" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\Blynk\src" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\Adafruit_Sensor" "C:\Users\João Gabriel\Documents\Arduino\libraries\Blynk\src\utility\BlynkTimer.cpp" -o "C:\Users\JOOGAB~1\AppData\Local\Temp\arduino_build_869974\libraries\Blynk\utility\BlynkTimer.cpp.o"
"C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\variants\standard" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\libraries\SPI\src" "-ID:\Arquivos de Programas\Arduino\libraries\Ethernet\src" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\Blynk\src" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\Adafruit_Sensor" "C:\Users\João Gabriel\Documents\Arduino\libraries\Blynk\src\utility\utility.cpp" -o "C:\Users\JOOGAB~1\AppData\Local\Temp\arduino_build_869974\libraries\Blynk\utility\utility.cpp.o"
Compiling library "DHT_sensor_library"
"C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\variants\standard" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\libraries\SPI\src" "-ID:\Arquivos de Programas\Arduino\libraries\Ethernet\src" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\Blynk\src" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\Adafruit_Sensor" "C:\Users\João Gabriel\Documents\Arduino\libraries\DHT_sensor_library\DHT.cpp" -o "C:\Users\JOOGAB~1\AppData\Local\Temp\arduino_build_869974\libraries\DHT_sensor_library\DHT.cpp.o"
"C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\variants\standard" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\libraries\SPI\src" "-ID:\Arquivos de Programas\Arduino\libraries\Ethernet\src" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\Blynk\src" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\João Gabriel\Documents\Arduino\libraries\Adafruit_Sensor" "C:\Users\João Gabriel\Documents\Arduino\libraries\DHT_sensor_library\DHT_U.cpp" -o "C:\Users\JOOGAB~1\AppData\Local\Temp\arduino_build_869974\libraries\DHT_sensor_library\DHT_U.cpp.o"
Compiling library "Adafruit_Sensor"
Compiling core...
"C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-gcc" -c -g -x assembler-with-cpp -flto -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\variants\standard" "C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino\wiring_pulse.S" -o "C:\Users\JOOGAB~1\AppData\Local\Temp\arduino_build_869974\core\wiring_pulse.S.o"
"C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\variants\standard" "C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino\WInterrupts.c" -o "C:\Users\JOOGAB~1\AppData\Local\Temp\arduino_build_869974\core\WInterrupts.c.o"
"C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\variants\standard" "C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino\hooks.c" -o "C:\Users\JOOGAB~1\AppData\Local\Temp\arduino_build_869974\core\hooks.c.o"
"C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\variants\standard" "C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino\wiring.c" -o "C:\Users\JOOGAB~1\AppData\Local\Temp\arduino_build_869974\core\wiring.c.o"
"C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\variants\standard" "C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino\wiring_analog.c" -o "C:\Users\JOOGAB~1\AppData\Local\Temp\arduino_build_869974\core\wiring_analog.c.o"
"C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\variants\standard" "C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino\wiring_digital.c" -o "C:\Users\JOOGAB~1\AppData\Local\Temp\arduino_build_869974\core\wiring_digital.c.o"
"C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\variants\standard" "C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino\wiring_pulse.c" -o "C:\Users\JOOGAB~1\AppData\Local\Temp\arduino_build_869974\core\wiring_pulse.c.o"
"C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\variants\standard" "C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino\wiring_shift.c" -o "C:\Users\JOOGAB~1\AppData\Local\Temp\arduino_build_869974\core\wiring_shift.c.o"
"C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\variants\standard" "C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino\CDC.cpp" -o "C:\Users\JOOGAB~1\AppData\Local\Temp\arduino_build_869974\core\CDC.cpp.o"
"C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\variants\standard" "C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino\HardwareSerial.cpp" -o "C:\Users\JOOGAB~1\AppData\Local\Temp\arduino_build_869974\core\HardwareSerial.cpp.o"
"C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\variants\standard" "C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino\HardwareSerial0.cpp" -o "C:\Users\JOOGAB~1\AppData\Local\Temp\arduino_build_869974\core\HardwareSerial0.cpp.o"
"C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\variants\standard" "C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino\HardwareSerial1.cpp" -o "C:\Users\JOOGAB~1\AppData\Local\Temp\arduino_build_869974\core\HardwareSerial1.cpp.o"
"C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\variants\standard" "C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino\HardwareSerial2.cpp" -o "C:\Users\JOOGAB~1\AppData\Local\Temp\arduino_build_869974\core\HardwareSerial2.cpp.o"
"C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\variants\standard" "C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino\HardwareSerial3.cpp" -o "C:\Users\JOOGAB~1\AppData\Local\Temp\arduino_build_869974\core\HardwareSerial3.cpp.o"
"C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\variants\standard" "C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino\IPAddress.cpp" -o "C:\Users\JOOGAB~1\AppData\Local\Temp\arduino_build_869974\core\IPAddress.cpp.o"
"C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\variants\standard" "C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino\PluggableUSB.cpp" -o "C:\Users\JOOGAB~1\AppData\Local\Temp\arduino_build_869974\core\PluggableUSB.cpp.o"
"C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\variants\standard" "C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino\Print.cpp" -o "C:\Users\JOOGAB~1\AppData\Local\Temp\arduino_build_869974\core\Print.cpp.o"
"C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\variants\standard" "C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino\Stream.cpp" -o "C:\Users\JOOGAB~1\AppData\Local\Temp\arduino_build_869974\core\Stream.cpp.o"
"C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\variants\standard" "C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino\Tone.cpp" -o "C:\Users\JOOGAB~1\AppData\Local\Temp\arduino_build_869974\core\Tone.cpp.o"
"C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\variants\standard" "C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino\USBCore.cpp" -o "C:\Users\JOOGAB~1\AppData\Local\Temp\arduino_build_869974\core\USBCore.cpp.o"
"C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\variants\standard" "C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino\WMath.cpp" -o "C:\Users\JOOGAB~1\AppData\Local\Temp\arduino_build_869974\core\WMath.cpp.o"
"C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\variants\standard" "C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino\WString.cpp" -o "C:\Users\JOOGAB~1\AppData\Local\Temp\arduino_build_869974\core\WString.cpp.o"
"C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\variants\standard" "C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino\abi.cpp" -o "C:\Users\JOOGAB~1\AppData\Local\Temp\arduino_build_869974\core\abi.cpp.o"
"C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\variants\standard" "C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino\main.cpp" -o "C:\Users\JOOGAB~1\AppData\Local\Temp\arduino_build_869974\core\main.cpp.o"
"C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino" "-IC:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\variants\standard" "C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino\new.cpp" -o "C:\Users\JOOGAB~1\AppData\Local\Temp\arduino_build_869974\core\new.cpp.o"
"C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-gcc-ar" rcs "C:\Users\JOOGAB~1\AppData\Local\Temp\arduino_build_869974\core\core.a" "C:\Users\JOOGAB~1\AppData\Local\Temp\arduino_build_869974\core\wiring_pulse.S.o"
Error running c:\users\joão gabriel\appdata\local\arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2\bin\../lib/gcc/avr/4.9.2/../../../../avr/bin/ar.exe: CreateProcess
Using library SPI at version 1.0 in folder: C:\Users\João Gabriel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\libraries\SPI
Using library Ethernet at version 1.1.2 in folder: D:\Arquivos de Programas\Arduino\libraries\Ethernet
Using library Blynk at version 0.4.7 in folder: C:\Users\João Gabriel\Documents\Arduino\libraries\Blynk
Using library DHT_sensor_library at version 1.3.0 in folder: C:\Users\João Gabriel\Documents\Arduino\libraries\DHT_sensor_library
Using library Adafruit_Sensor at version 1.0.2 in folder: C:\Users\João Gabriel\Documents\Arduino\libraries\Adafruit_Sensor
exit status 1
console error return this
Costas
May 17, 2017, 10:29pm
20
Looks like you are missing some of the libraries.
