[SOLVED] Blynk and BLE using HM10 module (OK+CONN problem)
Dear HM10 users,
You might have experienced big problems using BLE, more specifically using the HM10 module. Although there are some fundamental problems (the lack of sync-bytes and connection restore functionality in the Blynk protocol), there is also a HM10-specific problem.
One of the problems is that some HM10 modules send a string OK+CONN when connection is set up and OK+LOST when connection is lost in the serial stream. This totally confuses the serial protocol of Blynk.
I realised that this is caused by the fact that I used a HM10 test tool that sets baudrate, name, … of HM10 module, but at the end it sends AT+NOTI1 to the module. This is what actually caused the OK+CONN and OK+LOST string.
To check if your module also has this problem, check with AT+NOTI? which should return 0. If this returns 1, you will have problems with Blynk and other apps such as RemoteXY.
In order to fix this issue, you have to send AT+NOTI0 to the module, which solves at least this problem.
thanks for the info. i’m not working right now with ble or bluetooth, buth will keep in mind this issue.
@federicobusero Thank you for this info. But there is no need to post links to all those old posts just to reference this one. Please refrain from spamming posts like that. Thank you.
In case you don’t know how to send AT+NOTI0 to a HM10 module, you can run following code. You only have to do this once. It is a modified version of some code you can find on the internet. You can use the program to change baudrate, name of the module and also send the AT+NOTI0 for fixing the OK+CONN problem. The version you see here doesn’t change the baud rate of name, it just changes the NOTI bit.
  Arduino BLE Shield (HM-10) Testing Sketch
  by JP Liew http://jpliew.com
  Changes by FedericoBusero
  This program is free software: you can redistribute it and/or modify
  it under the terms of the GNU General Public License as published by
  the Free Software Foundation, either version 3 of the License, or
  (at your option) any later version.
  This program is distributed in the hope that it will be useful,
  but WITHOUT ANY WARRANTY; without even the implied warranty of
  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
  GNU General Public License for more details.
  You should have received a copy of the GNU General Public License
  along with this program.  If not, see <http://www.gnu.org/licenses/>.
#define BUFFER_LENGTH 100
SoftwareSerial ble(2, 3);       // For Uno, HM10 TX pin to Arduino Uno pin D2, HM10 RX pin to Arduino Uno pin D3
//SoftwareSerial ble(10,11);      // For Mega 2560, HM10 TX pin to Arduino Mega 2650 pin D10, HM10 RX pin to Arduino Mega 2560 pin D11
char buffer[BUFFER_LENGTH];       // Buffer to store response
int timeout = 800;          // Wait 800ms each time for BLE to response, depending on your application, adjust this value accordingly
long bauds[] = {9600, 57600, 115200, 38400, 2400, 4800, 19200}; // common baud rates, when using HM-10 module with SoftwareSerial, try not to go over 57600
long BLEAutoBaud() {
  int baudcount = sizeof(bauds) / sizeof(long);
  for (int i = 0; i < baudcount; i++) {
    for (int x = 0; x < 3; x++) { // test at least 3 times for each baud
      Serial.print("Testing baud ");
      Serial.println(bauds[i]);
      ble.begin(bauds[i]);
      if (BLEIsReady()) {
        return bauds[i];
  return -1;
boolean BLEIsReady() {
  BLECmd(timeout, "AT" , buffer);   // Send AT and store response to buffer
  if (strcmp(buffer, "OK") == 0) {
    return true;
    return false;
boolean BLECmd(long timeout, char* command, char* temp) {
  long endtime;
  boolean found = false;
  endtime = millis() + timeout; //
  memset(temp, 0, 100);       // clear buffer
  found = true;
  Serial.print("Arduino send = ");
  Serial.println(command);
  ble.print(command);
  // The loop below wait till either a response is received or timeout
  // The problem with this BLE Shield is most of the HM-10 modules do not response with CR LF at the end of the response,
  // so a timeout is required to detect end of response and also prevent the loop locking up.
  while (!ble.available()) {
    if (millis() > endtime) {   // timeout, break
      found = false;
      break;
  if (found) {            // response is available
    int i = 0;
    while (ble.available()) {   // loop and read the data
      char a = ble.read();
      // Serial.print((char)a); // Uncomment this to see raw data from BLE
      temp[i] = a;        // save data to buffer
      i++;
      if (i >= BUFFER_LENGTH) break; // prevent buffer overflow, need to break
      delay(1);           // give it a 2ms delay before reading next character
    Serial.print("BLE reply    = ");
    Serial.println(temp);
    while ((strlen(temp) > 0) && ((temp[strlen(temp) - 1] == 10) || (temp[strlen(temp) - 1] == 13)))
      temp[strlen(temp) - 1] = 0;
    return true;
    Serial.println("BLE timeout!");
    return false;
  pinMode(13, OUTPUT);
  digitalWrite(13, LOW);
  // If you see lots of BLE timeout on Serial Monitor after BLEAutoBaud completed, most likely your have a bad shield
  // Check if the shield JUMPER is correctly set to
  // HM10 TX to D2
  // HM10 RX to D3
  long baudrate = BLEAutoBaud();
  if (baudrate > 0) {
    Serial.print("Found BLE baud rate ");
    Serial.println(baudrate);
    Serial.println("No BLE detected.");
    while (1) {};         // No BLE found, just going to stop here
  // The following commands are just to demonstrate the shield is working properly,
  // in actual application, only call those that are needed by your application.
  // Check HM-10 datasheet for the description of the commands.
  BLECmd(timeout, "AT+NAME?", buffer);
  BLECmd(timeout, "AT+BAUD?", buffer);
  BLECmd(timeout, "AT+MODE?", buffer);
  BLECmd(timeout, "AT+PASS?", buffer);
  BLECmd(timeout, "AT+VERS?", buffer);
  BLECmd(timeout, "AT+RADD?", buffer);
  BLECmd(timeout, "AT+ADDR?", buffer);
  BLECmd(timeout, "AT+TYPE?", buffer);
  BLECmd(timeout, "AT+POWE?", buffer); // Show power (should be 2 or 3)
  BLECmd(timeout, "AT+NOTI?", buffer); // Check the current notification bit
  BLECmd(timeout, "AT+NOTI0", buffer); // Make sure the module doesn't send AT+CONNECT or AT+LOST on the serial line
  //  BLECmd(timeout,"AT+NAMEHM10",buffer); // Set the name of the module to HM10
  //  BLECmd(timeout,"AT+BAUD0",buffer); // Set baudrate to 9600
  //  BLECmd(timeout,"AT+BAUD1",buffer); // Set baudrate to 19200
  //  BLECmd(timeout,"AT+BAUD2",buffer); // Set baudrate to 38400
  //  BLECmd(timeout,"AT+BAUD3",buffer); // Set baudrate to 57600
  //  BLECmd(timeout,"AT+BAUD4",buffer); // Set baudrate to 115200
  Serial.println("----------------------");
  Serial.println("Waiting for remote connection...");
void printhex(unsigned char c)
  if (c < 0x10) {
    Serial.print("0");
  Serial.print(c, HEX);
  if (ble.available()) {
    char c = (char)ble.read();
    if (isPrintable(c))
      Serial.print(c);
      Serial.print("[");
      printhex(c);
      Serial.print("]");
    if (c == '1') digitalWrite(13, HIGH); // if received character 1 from BLE, set PIN 13 high
    if (c == '0') digitalWrite(13, LOW); // if received character 0 from BLE, set PIN 13 low
@federicobusero - that’s some impressive detective work!
So I’ve finally gotten around to checking out my adafruit feather BLE issue to see if it fixes things. Unfortunately it seems that this board uses an MDPT40 BLE modules, which is based off of a (https://cdn-shop.adafruit.com/product-files/2267/MDBT40-P256R.pdf) which itself is based off of a nRF51822 chip, so I don’t think this is the issue I’m having. :frowning:
@federicobusero - how did you debug this issue? Is there some way to investigate bluetooth comms?
In case you want to debug BLE issues, the starting point is
#define BLYNK_DEBUG
Afterwards you can add some additional prints in the Blynk library.
I didn’t check it for a while, but the 2 BLE issues that were not yet fixed some time ago:
  • BLE buffering/flushing issue in the Android app
  • Byte flushing not yet implemented in processInput (BlynkProtocol.h) in case of missing bytes : it should skip bytes until the start of a next frame
@federicobusero - ok thanks.
I checked with the latest stuff and my issue is still present so I’ve reopened it: Bluetooth BLE support for Adafruit Feather Bluefruit LE
Thanks for this, Federico. Great one for those that are not “experts” but still playing with Ardunio to “inoculate” this passion into our kids.
I applied it and worked with some minor changes.
Thank you / Gracias
