HM10 Blynk, keeps reconnecting after being ready for few seconds
My code:
#include <Blynk.h>
const int FSR_PIN = A0; // Pin connected to FSR/resistor divider
// Measure the voltage at 5V and resistance of your 3.3k resistor, and enter
// their value's below:
const float VCC = 3.94; // Measured voltage of Ardunio 5V line
const float R_DIV = 3000.0; // Measured resistance of 3.3k resistor
// You could use a spare Hardware Serial on boards that have it (like Mega)
#include <SoftwareSerial.h>
#include <BlynkSimpleSerialBLE.h>
SoftwareSerial SerialBLE(10, 11);
int steps = 0;
int pinValue;
BLYNK_WRITE(V3)
  pinValue = param.asInt(); // assigning incoming value from pin V3 to a variable
  // process received value
  if (pinValue == 1) {
    steps = 0;
    Blynk.virtualWrite(V2, 0);
char auth[] = "47ea30fe632b458485e9ebd69fa3d35e";
  // Blynk will work through Serial
  // Do not read or write this serial manually in your sketch
  SerialBLE.begin(9600);
  Blynk.begin(SerialBLE, auth);
  pinMode(7, INPUT);
int i = 0;
  int fsrADC = analogRead(FSR_PIN);
  if (fsrADC != 0) // If the analog reading is non-zero
    // Use ADC reading to calculate voltage:
    float fsrV = fsrADC * VCC / 1023.0;
    // Use voltage and static resistor value to
    // calculate FSR resistance:
    float fsrR = R_DIV * (VCC / fsrV - 1.0);
    // Guesstimate force based on slopes in figure 3 of
    // FSR datasheet:
    float force;
    float fsrG = 1.0 / fsrR; // Calculate conductance
    // Break parabolic curve down into two linear slopes:
    if (fsrR <= 600)
      force = (fsrG - 0.00075) / 0.00000032639;
      force =  fsrG / 0.000000642857;
    if (i % 5 == 0) {
      Blynk.virtualWrite(V1, force);
    i++;
    delay(100);
  if (digitalRead(7) == HIGH) {
    steps++;
    Blynk.virtualWrite(V2, steps);
    delay(100);
When I upload, blynk shows it the way i want. But i need to present in front of others my project which is a smart shoe that connects to bluetooth. The bluetooth disconnects like every few seconds. ON serial monitor it shows (ready ping) for a few seconds and it works on the app. then it keep looping reconnecting for like 20 seconds then again ready for only few seconds.
I need it to be steady ready for atleast a minute to be able to show my project!
please I need help ASAP im presenting on Saturday in NYC
