I see one or two people have already got their google assistant working with IFTTT and the ESP8266. Anyone willing to share their code?
What do you want? Exactly i have all three working
Thanks for getting back to me. Actually, yesterday I manged to get it up and running using web hooks in IFTTT.
as you have mentioned that you will use it with IFTTT , any news about the delay??
Yes, there is a delay but it’s something I can live with for the moment. If someone knows how to do it without IFTTT, I’d be happy to hear from them.
@Falcon9 do you have an Android Smartphone in your pocket?
Press the Blynk button, no delay, problem solved
Except I don’t want to press any buttons. I want to issue a verbal command.
I want to issue a verbal command to Google Home that will activate a relay attached to an ESP8266. I found how to do it using IFTTT, but if you’ve got another method, I’d be delighted to hear about it.
Thanks,
Here’s how I did it with both IFTTT and the Amazon Echo / Alexa, by emulating a Wemo smart outlet. Since Google Home also controls the Wemo, I’d guess that you can use the same code.
