Yeah, It makes sense, Jonas. Thank you so much for your explanation. The if-else statement is simply for a notification on the application which will be triggered if moisture is detected.
Yeah
it is a bit of a struggle really. I have made several projects with python and JS(software projects) but since I’m doing Arduino now, I have a bit of difficulty with cpp. But the sensor’s working pretty well now cuz I have been testing it for the past 3-4 days.
Okay, now my void loop is clean. I just have to get the value on a scale of 0-100 and for wet it should be more and for dry it should be less. Just help me with this one guys.
New code -
#include <DHT.h>
#include <OneWire.h>
#define ONE_WIRE_BUS D2
char auth[] = "4pd1tQr1dAilNauRpvQQR0--wfNMaoDW";
char ssid[] = "KUMAR";
char pass[] = "SRAVENKY@861614";
#define sensorPin D3
int sensorState = 0;
int lastState = 0;
#define DHTPIN 2
#define DHTTYPE DHT11
DHT dht(DHTPIN, DHTTYPE);
void sendSensor()
float h = dht.readHumidity();
if (isnan(h) || isnan(t)) {
return;
Blynk.virtualWrite(V5, h); //V5 is for Humidity
Blynk.virtualWrite(V6, t); //V6 is for Temperature
pinMode(sensorPin, INPUT);
dht.begin();
timer.setInterval(10000L, sendSensor);
sensors.begin();
int sensor = A0;
void sendTemps()
sensor = analogRead(A0);
float temp = sensors.getTempCByIndex(0);
Serial.println(temp);
Serial.println(sensor);
Blynk.virtualWrite(V1, temp);
Blynk.virtualWrite(V2, sensor);
in function sendTemps(), REMOVE the line:
in setup(), ADD the line:
timer.setInterval(10000L, sendTemps);
REMOVE the line:
int sensor = A0;
Replace it with these MODIFIED line in the sendTemps function:
int sensor = analogRead(A0);
To map A0 reading to a “percentage” value I BELIEVE you could do like this (I have not tested):
int blynkVal = map (sensor, 1023,0, 0,100); // map(value, fromLow, fromHigh, toLow, toHigh)
Blynk.virtualWrite(V2, blynkVal);
Note, I am not used to this map function, so I cannot guarantee it works as I believe when “inverse-mapping” like this.
It WORKED flamboyantly. Thank you so much Jonas for your time, effort, and expertise ![]()
You just made my day !
TBH, you’d be far better having one function which takes a reading from your DHT sensor and your analog pin and send the values to Blynk.
You need to use a Map command in your sketch, but I don’t think you understand the Map command syntax, which is…
Your original sketch used…
This means that an input of 0 would produce an output of 1023, and an input of 1023 would produce an output of 0 (thereby inverting the readings but not re-scaling them)
You actually want…
sensor = map (sensor,0,1023,0,100);
Thank you, Pete
I am working on an automatic soil watering system using blynk. I’ve made the app UI and have added a button that is connected to a 5v relay module which switches on and switches off the motor pump with the button. To make this more automatic I was thinking of adding an if-else statement that switches on and off the pump if the moisture content is low and if the conditions are dry and will switch it off if there is enough moisture. The parameter can be set as to when it should start automatically and when to stop. Here’s my code -
#include <DHT.h>
int lastState = 0;
#define DHTPIN 2
void sendSensor()
return;
dht.begin();
sensors.begin();
void sendTemps()
Is there any way I can achieve this task?
Your help will be greatly appreciated.
I’ve merged your new topic back into this one.
The latest code you posted has number of issues, which have already been discussed in this topic, and which you need to address before you go any further.
Please don’t create new topics to discuss what is basically the same issue.
Ok, sure.
You can achieve this in the sketch using if condition, and you can add a setpoint and change when to start/stop using a slider for example without modifying the sketch and reupload it, or you can use Automation which is the easiest way.
He’s using Legacy ![]()
Okay, sorry
Just ignore automation.
You can use eventor which is similar to automation
Koushai
One comment re your idea to switch motor on (WATER ON) when sensor is DRY and WATER OFF when sensor is WET.
There is a risk this will often/always end up in flooding (water all over the place…)
Why?
It depends, of course, on how much water you pump per time, i.e. the water flow. There is always a risk your water flow is “more” than your sensor system can detect - and if so - you would too late detect “oh, it is wet” and turn OFF the motor/water.
Either you have full or good control of this. Or you could instead use a different approach. (I would.)
loop
- When sensor is DRY - turn motor ON (water ON) - wait NN secs - turn motor OFF (water OFF).
- Wait some time (NN minutes)
You will have to learn your system of a “good” time period for WATERING and a good time period for PAUSING in between,
But I believe this would be a safer method.
Then, you should also try to find out whether the sensor system gives DRY or WET when it is “caput”. If it is DRY - that will always be a problem as it will tell your system “keep on watering”.
Try to make sure the system says WET when Caput (not working OK).
This is a systems design approach and not about programming.
// Others may have other ideas and not agree to this. This is just my way of design. Not necessarily the best.
The other issue is that this type of sensor corrodes very quickly when power is applied to it constantly (electrolysis effect).
A better approach is to switch the VCC supply to the sensor off when it’s not being read.
Your approach of taking an infrequent reading then turning on the pump for a short period works well when you do this.
Your code is worked? can you show me the last results?
@Koushal_B hasn’t visited the forum for over a year, so you may not get a response.
I’d suggest that you start a new topic explaining exactly which code you are trying to use and with which hardware, and what results you are getting.
This post should give you a good idea of the type of information you should be providing, and how it should be presented…
