Hii,
I have been facing an issue of opposite readings of soil moisture sensors on a gauge in blynk. So, I checked the forum for similar problems and tried making some amends but I couldn’t resolve the issue. Any help would be really appreciated. Here’s my code -
#include <DHT.h>
#include <OneWire.h>
#define ONE_WIRE_BUS D2
char auth[] = "4pd1tQr1dAilNauRpvQQR0--wfNMaoDW";
char ssid[] = "KUMAR";
char pass[] = "SRAVENKY@861614";
#define sensorPin D3
int sensorState = 0;
int lastState = 0;
#define DHTPIN 2
#define DHTTYPE DHT11
DHT dht(DHTPIN, DHTTYPE);
void sendSensor()
float h = dht.readHumidity();
if (isnan(h) || isnan(t)) {
return;
Blynk.virtualWrite(V5, h); //V5 is for Humidity
Blynk.virtualWrite(V6, t); //V6 is for Temperature
pinMode(sensorPin, INPUT);
dht.begin();
timer.setInterval(10000L, sendSensor);
sensors.begin();
int sensor = A0;
void sendTemps()
sensor = analogRead(A0);
sensor = map (sensor, 0,1023,1023,0);
sensor = (sensor / 1023) * 100;
float temp = sensors.getTempCByIndex(0);
Serial.println(temp);
Serial.println(sensor);
Blynk.virtualWrite(V1, temp);
Blynk.virtualWrite(V2, sensor);
sendTemps();
sensorState = digitalRead(sensorPin);
Serial.println(sensorState);
if (sensorState == 1 && lastState == 0) {
Serial.println("needs water, send notification");
Blynk.notify("Water has been detected in the soil");
lastState = 1;
else if (sensorState == 1 && lastState == 1) {
//do nothing, has not been watered yet
Serial.println("has not been watered yet");
else {
//st
Serial.println("does not need water");
lastState = 0;
delay(100);
