Hey guys i need your help
So, i want to make a monitoring system using blynk app.
It can monitor soil moisture, air humidity and temperature.
But something wrong in my blynk app. It cant show the soil moisture sensor. I dont know if the code or the blynk app is wrong, please help guys.
Im using :
• Nodemcu ESP8266, DHT 22 Sensor, Soil Moisture sensor (im using the A0,VCC, and GND)
• Smartphone Android
• Blynk Library version
heres the code
#include <DHT.h>
char auth[] = "9wiBL8RDQjWOnIHOaCIn4Szb0Ekw_n2Z"; //Enter the Auth code which was send by Blink
char ssid[] = "GARPU_SIOMAY"; //Enter your WIFI Name
char pass[] = "katasandi"; //Enter your WIFI Password
#define DHTPIN 2 // Digital pin 4
const int sensorpin=A0;
int sensorvalue=0;
int outputvalue=0;
//#define DHTTYPE DHT11 // DHT 11
#define DHTTYPE DHT22 // DHT 22, AM2302, AM2321
//#define DHTTYPE DHT21 // DHT 21, AM2301
DHT dht(DHTPIN, DHTTYPE);
const int sensorPin = A0;
void sendSensor()
float h = dht.readHumidity();
if (isnan(h) || isnan(t)) {
return;
Blynk.virtualWrite(V5, h); //V5 is for Humidity
Blynk.virtualWrite(V6, t); //V6 is for Temperature
void sendSensor2()
int sensorvalue=analogRead(sensorpin);
outputvalue=map(sensorvalue,0,1023,0,100);
if(outputvalue>74)
Serial.println("water your plant");
Serial.print(outputvalue);
Blynk.notify("water your plant");
else if(outputvalue<45)
Serial.println("soil is wet enough to water");
Blynk.notify("soil is wet enough to water");
Blynk.virtualWrite(V1, outputvalue);
dht.begin();
