Slider doesn't trigger event
I’m using a Fishino to control 2 sunblinds locally with physicall up/down buttons and remotely via 2 sliders on Blynk IOS App. All is working perfectly except one annoying case.
If I move to 0 the slider (extreme left of range 0…10) after a push from Arduino the event is not detected.
Any another action move to 1, move to right etc… works.
I don’t know if the problem is the IOS App or the public Blynk server but Arduino receive no event so very hard to troubleshoot from my side. I’m using v0.5.2 library and very last IOS App tested from both an iPhone and iPad.
Fla
code?
Herewith the code related to Blynk management.
Very basic with all events reported to serial.
blynkPush sync the Blynk Server with actual Motor position
void blynkPush()
  LOG("Blynk Push");
  Blynk.virtualWrite(V1, float(Motor1.position)/K);
  Blynk.virtualWrite(V2, float(Motor2.position)/K);
BLYNK_CONNECTED()
  LOG("Blynk Connected");
  blynkPush();
BLYNK_WRITE_DEFAULT()
  int pin = request.pin;
  int value = param.asInt();
  LOG("Blynk Pin: " + pin);
  LOG("Blynk Value: " + value);
  switch (pin) {
    case V1:
      if (!Motor1.run) Motor1.go(value*K);
      break;
    case V2:
      if (!Motor2.run) Motor2.go(value*K);
      break;
ok, so if I understand correctly: if you change the Vpin value to 0 then BLYNK_WRITE is not activated? Im rather new to this all as well, so I don’t see why as the value clearly changes. perhaps its a bug? Anyway have you tried setting the max slider value to 0.1-10 ?
another thing you can try is using BLYNK_WRITE(V1) directly and see if that works.
edit: by the way: thank you! You’ve inadvertently solved one of my problems. Before reading this post I wasn’t aware of blynk_write_default() and as I have 49 pins to manage I had 49 instances of blynk_write().
I’ve tried many changes but no luck. My feeling is it’s a bug I cannot troubleshoot because happening on App (IOS) and/or server side. I’m using this setup since 9 months without problems so maybe introduced with new Blynk versions
I’ve tested the status of V1 using the API
http://blynk-cloud.com/xxxxxxxxxxxxxxxxxxxxxxxx/get/V1
and it confirm the problem is on IOS App and/or server side
In that case either change the topic type from ‘need help’ to ‘report issue’ (if that is possible?)
If its not possible then create a new topic an give thorough explanation of what you did.
Fact btw that it all worked until a recent Blynk update is also a rather dead give away that a bug was introduced (although granted it is theoretically possible that at the same time a hardware bug initiated).
What exactly are you pushing? Pls check with logs
Does the value on server (you can check via http api) reflect the change from this push?
Does slider in the app reflect the change from this push?
With push I mean Blynk.virtualWrite
Yes
Yes
Yeah, I meant to show us logs with exact values…
I cannot provide logs about the App and Blynk I can provide my own logs:
void blynkPush()
LOG(“Blynk Push”);
LOG("V1 " + String(float(Motor1.position)/K));
LOG("V2 " + String(float(Motor2.position)/K));
199.67–>Go: 100
199.68–>Down: 15.00
202.07–>Stop delta: 23
202.07–>Blynk Push
202.07–>V1 2.30
202.08–>V2 0.00
202.20–>Stop: 23
204.77–>Go: 100
204.78–>Down: 25.00
207.63–>Stop delta: 14
207.63–>Blynk Push
207.64–>V1 2.30
207.64–>V2 1.40
207.81–>Stop: 14
The sliders are 0…10 and even if I change the 0 with 1 the behaviour is the same
So, you are saying, that after this push
  1. slider correctly shoes 1 (converted to int)
  2. server http api correctly returns 1.40
  3. if you change Slider value to zero the server value is unchanged (issue)
  4. if you change Slider value to a value greater than zero the server value is changed (correct)
Is that right?
I’ve completed my investigation installing also a local Blynk server for sniffing traffic and in my opinion there is a bug in the App (I tried IOS only) with slider widget
Summarizing:
When a Slider is set to send data on release only, it doesn’t send any change to Blynk server moving to the edges (0 or 255) after the Hardware has called a Blynk.virtualWrite.
I tried a lot of workarounds without success:
  • change from horizontal to vertical sliders
  • change borders from 0…10 to -10…0
  • disabling data mapping
Changing “send data on release only” to OFF it works but it requires some very bad code to process just the last value.
Now I cannot do more because no way to debug the App internals.
Hi, just upgraded the iOS App to new release 2.19.0 and the bug is still present!!
@Eugene please take a look
@piflav Slider on iOS converts values to integer. So you need to add proper converting of values sent from hardware.
P.S. Slider supporting float values should be available in next update.
I’ve tried with Android and the bug is not present.
Please have a look to this video
showing on the bottom Android App vs iOS in the middle.
Basically iOS doesn’t always trigger an event when the slider is moved to zero if the previous event is generated elsewhere.
Video Link:
https://drive.google.com/open?id=1bzLjuwyk2Vzqup49zxwWqOb5pOBmAjb0
@piflav please show your Slider settings screen.
