Same problem here with tabs after update to the latest IOS version: I have a layout with four tabs but I can only access the first/main one. The other three tabs are not accessible. Closed and re-opened the app several times without success.
@hbierau like I said earlier, as a temporary workaround, scroll your project to the place where Tabs widget is located, then tap on a tab you want to go.
Not quite sure what you mean. When I open my app, I have the main panel of my project with the tabs already visible/accessible at the bottom of the screen. I do not have to scroll anywhere to access them or to have them visible. However, nothing happens when I tap on the other tabs, they are completely inactive (I cannot even edit them).
Styled Button on IOS does not work. Places on screen, is visible, but otherwise behaves as if it has not been placed. When the app is run again is disappears completely. Tried the same on an Android version and all is well.
