Hi All.
I am new to blynk and needed a simple scheduler for my home irrigation system using 4 relay device (sonoff 4ch pro).
The device receives for each relay, duration time (V16…V19), and 4 optional start times (and active days) using the time input widget(V0…V3 for relay 0 V4…V7 for relay 1 … ) .
Also at the app for each relay I have a button (V20…V23) that enables activating the relay immediately (the relay will turn off after the configured duration time).
since I could not find BLYNK code that match my requirements I wrote one and am sharing it here if anyone finds it useful.
http://twitter.com/blynk_app
This example runs directly on ESP8266 chip.
Please be sure to select the right ESP8266 module
in the Tools -> Board menu!
#define WIFI_LED 13
#include <TimeLib.h>
#include <WidgetRTC.h>
char auth[] = "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx";
char ssid[] = "xxxxxx";
char pass[] = "xxxxxxxxxxxx";
byte switch_pins[] = {12 , 5 , 4 , 15}; // number of gpio to be used as switch/relay control
// this code can control up to 4 switches //
// for each switch up to 4 schedule start times can be configured //
// for each switch one duration is used (when schedule time is //
// reached the switch turns on for the duration) //
int start_time_sec[4][4]; // array of 4 start times (in seconds) for 4 switches [switch number][schedule timer number]
bool start_valid[4][4]; // is the start time valid ?
bool weekdays[4][4][8]; // array of 8 days (day 0 not used) for each schedule time
byte active_duration[4]; // duration per switch (in minuets)
bool wifi_led_status = false;
// when activating a switch a timer is set for the configured duration
// when the duration ends the switch is turned off by the timer
// the number of the timer is saved using end_timer_id
// if switch is manualy turned off the end_timer_id is used to stop the timer.
int end_timer_id[4] = {32, 32, 32, 32};
// timer object declaration
// this code use Real Time Clock widget in the blynk app to keep the clock updated from net
WidgetRTC rtc;
BLYNK_CONNECTED() {
// Synchronize time on connection
rtc.begin();
Blynk.syncAll();
// get schedual parameters from App //
void set_time(BlynkParam param, byte switch_no, byte time_no){
TimeInputParam t(param);
// Process start time
if (t.hasStartTime())
Serial.println(String("Start: ") +
t.getStartHour() + ":" +
t.getStartMinute() + ":" +
t.getStartSecond());
Serial.println(String("Start in sec: ") + param[0].asLong() + String(" for switch") + switch_no + String(" time_no: ") + time_no);
start_time_sec[switch_no][time_no]= param[0].asLong();
start_valid[switch_no][time_no] = true;
// Do nothing
Serial.println(String("No Start Time Given for switch: ") + switch_no + String(" time_no: ") + time_no);
start_valid[switch_no][time_no] = false;
// Process weekdays (1. Mon, 2. Tue, 3. Wed, ...)
for (int i = 1; i <= 7; i++) {
if (t.isWeekdaySelected(i)) {
Serial.println(String("Day ") + i + " is selected");
weekdays[switch_no][time_no][i] = true;
else {
weekdays[switch_no][time_no][i] = false;
Serial.println();
BLYNK_WRITE(V0) { set_time(param, 0,0); }
BLYNK_WRITE(V1) { set_time(param, 0,1); }
BLYNK_WRITE(V2) { set_time(param, 0,2); }
BLYNK_WRITE(V3) { set_time(param, 0,3); }
BLYNK_WRITE(V4) { set_time(param, 1,0); }
BLYNK_WRITE(V5) { set_time(param, 1,1); }
BLYNK_WRITE(V6) { set_time(param, 1,2); }
BLYNK_WRITE(V7) { set_time(param, 1,3); }
BLYNK_WRITE(V8) { set_time(param, 2,0); }
BLYNK_WRITE(V9) { set_time(param, 2,1); }
BLYNK_WRITE(V10) { set_time(param, 2,2); }
BLYNK_WRITE(V11) { set_time(param, 2,3); }
BLYNK_WRITE(V12) { set_time(param, 3,0); }
BLYNK_WRITE(V13) { set_time(param, 3,1); }
BLYNK_WRITE(V14) { set_time(param, 3,2); }
BLYNK_WRITE(V15) { set_time(param, 3,3); }
BLYNK_WRITE(V16) { active_duration[0] = param.asInt(); }
BLYNK_WRITE(V17) { active_duration[1] = param.asInt(); }
BLYNK_WRITE(V18) { active_duration[2] = param.asInt(); }
BLYNK_WRITE(V19) { active_duration[3] = param.asInt(); }
// Handle switch events (from app or from scheduler ) //
// turn off switch after active duration ends
void turn_off_switch_no_0(){ turn_on_off(0,0); Blynk.virtualWrite(V20,0); Serial.println(String("timer turn off switch 0 ") );}
void turn_off_switch_no_1(){ turn_on_off(0,1); Blynk.virtualWrite(V21,0); Serial.println(String("timer turn off switch 1 ") );}
void turn_off_switch_no_2(){ turn_on_off(0,2); Blynk.virtualWrite(V22,0); Serial.println(String("timer turn off switch 2 ") );}
void turn_off_switch_no_3(){ turn_on_off(0,3); Blynk.virtualWrite(V23,0); Serial.println(String("timer turn off switch 3 ") );}
// handle switch state
void turn_on_off(int on_off, byte switch_no){
if (on_off==1)
digitalWrite(switch_pins[switch_no],HIGH);
long active_duration_ms = ((long)active_duration[switch_no])*60000;
switch (switch_no) {
case 0:
Blynk.virtualWrite(V20,1);
end_timer_id[0]=timer.setTimeout(active_duration_ms, turn_off_switch_no_0);
break;
case 1:
Blynk.virtualWrite(V21,1);
end_timer_id[1]=timer.setTimeout(active_duration_ms, turn_off_switch_no_1);
break;
case 2:
Blynk.virtualWrite(V22,1);
end_timer_id[2]=timer.setTimeout(active_duration_ms, turn_off_switch_no_2);
break;
case 3:
Blynk.virtualWrite(V23,1);
end_timer_id[3]=timer.setTimeout(active_duration_ms, turn_off_switch_no_3);
break;
Serial.println(String("turn ON switch: ") + switch_no);
digitalWrite(switch_pins[switch_no],LOW);
timer.deleteTimer(end_timer_id[switch_no]);
end_timer_id[switch_no]=32;
Serial.println(String("turn OFF switch: ") + switch_no);
// set switch state from APP
BLYNK_WRITE(V20) { turn_on_off(param.asInt(),0); }
BLYNK_WRITE(V21) { turn_on_off(param.asInt(),1); }
BLYNK_WRITE(V22) { turn_on_off(param.asInt(),2); }
BLYNK_WRITE(V23) { turn_on_off(param.asInt(),3); }
// schedual events handling
void activetoday(){ // check if schedule #1 should run today
if(Blynk.connected())
digitalWrite(WIFI_LED,LOW);
wifi_led_status =!wifi_led_status;
digitalWrite(WIFI_LED,wifi_led_status);
if(year() != 1970){
unsigned int nowseconds = ((hour() * 3600) + (minute() * 60) + second());
int dayadjustment = -1;
if(weekday() == 1){
dayadjustment = 6; // needed for Sunday Time library is day 1 and Blynk is day 7
for (int switch_cnt = 0; switch_cnt<= 3; switch_cnt++) {
for (int timer_cnt = 0; timer_cnt<= 3; timer_cnt++) {
if (start_valid[switch_cnt][timer_cnt] == true) {
if (weekdays[switch_cnt][timer_cnt][weekday() + dayadjustment]==true){
if (nowseconds >= start_time_sec[switch_cnt][timer_cnt]){
if(nowseconds < start_time_sec[switch_cnt][timer_cnt]+90){
turn_on_off(1,switch_cnt);
Serial.println(String("turn ON switch: ") + switch_cnt);
// BLYNK
for (int i = 0; i<4 ; i++){
pinMode(switch_pins[i], OUTPUT);
pinMode(WIFI_LED, OUTPUT);
timer.setInterval(60000L, activetoday); // check every 60s if ON / OFF trigger time has been reached
setSyncInterval(10 * 60); // Sync interval in seconds (10 minutes)
