strange I doubled check now by copying from my post and it work on my side.
OK. Made some changes to add system disable button.
To disable the system you have to define number of days to disable (a slider on V33) ,
and press the disable button (V32).
If you set V33 to 1 the system will disable until midnight if you set it to 2 the system will disable until tomorrow midnight …
When pressing the disable button all switches are turned off.
The disable date will be presented on V32 button.
Again this is not fully tested (each iteration is several days to test) so please let me know if you find bugs.
enjoy.
http://twitter.com/blynk_app
This example runs directly on ESP8266 chip.
Please be sure to select the right ESP8266 module
in the Tools -> Board menu!
#define WIFI_LED 13
// define configuration (number of switches and number of timers)
#define SWITCH_CNT 4
#define TIME_CNT 4
#include <TimeLib.h>
#include <WidgetRTC.h>
char auth[] = "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx";
char ssid[] = "xxxxx";
char pass[] = "xxxxxxxxxxxxxxx";
//byte switch_pins[] = {12 , 5 , 4 , 15}; // number of gpio to be used as switch/relay control
byte switch_pins[] = {2 , 5 , 14 , 15}; // number of gpio to be used as switch/relay control
bool switch_default[] = {LOW,HIGH,LOW,HIGH};
// This code can control up to 4 switches //
// For each switch up to 4 schedule start and end times can be configured - (V0..V15) //
// A default duration can be defined per switch - (V16..V19)//
// If an end time is not defined at the app the default duration is used //
// default duration is also used when manually activating the switch - (V20..V23)//
// for each switch when start time is reached the switch turns on for the duration //
// maximum duration is used for safety (to limit activation time) - (V24..V27)//
int start_time_sec[SWITCH_CNT][TIME_CNT]; // array of 4 start times (in seconds) for 4 switches [switch number][schedual timer number]
bool start_valid[SWITCH_CNT][TIME_CNT]; // is the start time valid ?
bool weekdays[SWITCH_CNT][TIME_CNT][8]; // array of 8 days (day 0 not used) for each schedule time
int active_duration[SWITCH_CNT][TIME_CNT+1]; // duration per switch per time(in sec)
bool end_valid[SWITCH_CNT][TIME_CNT]; // is the end time valid ?
int max_duration[SWITCH_CNT]; // max duration per switch
// when activating a switch a timer is set for the configured duration
// when the duration ends the switch is turned off by the timer
// the id of the timer is saved using end_timer_id
// if switch is manually turned off the end_timer_id is used to stop the timer.
// end_timer_id is initialized to 32 (per entry) at the setup section
int end_timer_id[SWITCH_CNT];
// saves id of main timer
int main_timer_id;
// system disable parameters
int system_disable_days; // V33 defines days to disable the system (including today)
int disable_timer_id = 32; // when system is disabled a timer is set to wake the system disable_timer_id saves this timer ID
// timer object declaration
// this code use Real Time Clock widget in the blynk app to keep the clock updated from net
WidgetRTC rtc;
BLYNK_CONNECTED() {
// Synchronize time on connection
rtc.begin();
Blynk.syncAll();
// get schedual parameters from App //
// this function is called when ever a timer is set from the APP (V0..V15)
// it receive the start (and optionally end) time from the time input widget
// and saves them in the appropriate arrays
void set_time(BlynkParam param, byte switch_no, byte time_no){
TimeInputParam t(param);
// Process start time
if (t.hasStartTime())
Serial.println(String("Start: ") +
t.getStartHour() + ":" +
t.getStartMinute() + ":" +
t.getStartSecond());
Serial.println(String("Start in sec: ") + param[0].asLong() + String(" for switch") + switch_no + String(" time_no: ") + time_no);
start_time_sec[switch_no][time_no]= param[0].asLong();
start_valid[switch_no][time_no] = true;
// Do nothing
Serial.println(String("No Start Time Given for switch: ") + switch_no + String(" time_no: ") + time_no);
start_valid[switch_no][time_no] = false;
// check if end time is received convert and save it as day time in seconds //
if (t.hasStopTime())
Serial.println(String("Stop: ") +
t.getStopHour() + ":" +
t.getStopMinute() + ":" +
t.getStopSecond());
Serial.println(String("Stop in sec: ") + param[1].asLong() + String(" for switch") + switch_no + String(" time_no: ") + time_no);
active_duration[switch_no][time_no] = (param[1].asLong()-start_time_sec[switch_no][time_no]);
// if end time is smaller than start time this means end time is at next day
if (active_duration[switch_no][time_no]<0) active_duration[switch_no][time_no]=86400+active_duration[switch_no][time_no];
Serial.println(String("Stop duration: ") + active_duration[switch_no][time_no]);
end_valid[switch_no][time_no] = true;
else // if end time is not defined //
// Do nothing
Serial.println(String("No Stop Time Given for switch: ") + switch_no + String(" time_no: ") + time_no);
end_valid[switch_no][time_no] = false;
// Process weekdays (1. Mon, 2. Tue, 3. Wed, ...)
for (int i = 1; i <= 7; i++) {
if (t.isWeekdaySelected(i)) {
Serial.println(String("Day ") + i + " is selected");
weekdays[switch_no][time_no][i] = true;
else {
weekdays[switch_no][time_no][i] = false;
Serial.println();
// V0..V3 for switch 0, V4..V7 for switch 1 ...
BLYNK_WRITE(V0) { set_time(param, 0,0); }
BLYNK_WRITE(V1) { set_time(param, 0,1); }
BLYNK_WRITE(V2) { set_time(param, 0,2); }
BLYNK_WRITE(V3) { set_time(param, 0,3); }
BLYNK_WRITE(V4) { set_time(param, 1,0); }
BLYNK_WRITE(V5) { set_time(param, 1,1); }
BLYNK_WRITE(V6) { set_time(param, 1,2); }
BLYNK_WRITE(V7) { set_time(param, 1,3); }
BLYNK_WRITE(V8) { set_time(param, 2,0); }
BLYNK_WRITE(V9) { set_time(param, 2,1); }
BLYNK_WRITE(V10) { set_time(param, 2,2); }
BLYNK_WRITE(V11) { set_time(param, 2,3); }
BLYNK_WRITE(V12) { set_time(param, 3,0); }
BLYNK_WRITE(V13) { set_time(param, 3,1); }
BLYNK_WRITE(V14) { set_time(param, 3,2); }
BLYNK_WRITE(V15) { set_time(param, 3,3); }
// use a slider to define default activation duration (slider count in minute)
BLYNK_WRITE(V16) { active_duration[0][TIME_CNT] = param.asInt()*60; }
BLYNK_WRITE(V17) { active_duration[1][TIME_CNT] = param.asInt()*60; }
BLYNK_WRITE(V18) { active_duration[2][TIME_CNT] = param.asInt()*60; }
BLYNK_WRITE(V19) { active_duration[3][TIME_CNT] = param.asInt()*60; }
// use a slider to define default max duration (slider count in minute)
BLYNK_WRITE(V24) { max_duration[0] = param.asInt()*60; }
BLYNK_WRITE(V25) { max_duration[1] = param.asInt()*60; }
BLYNK_WRITE(V26) { max_duration[2] = param.asInt()*60; }
BLYNK_WRITE(V27) { max_duration[3] = param.asInt()*60; }
// Handle switch events (from app or from scheduler ) //
// turn off switch after active duration ends
// duration number is not important here
void turn_off_switch_no_0(){ turn_on_off(0,0,0); Blynk.virtualWrite(V20,0); Serial.println(String("timer turn off switch 0 ") );}
void turn_off_switch_no_1(){ turn_on_off(0,1,0); Blynk.virtualWrite(V21,0); Serial.println(String("timer turn off switch 1 ") );}
void turn_off_switch_no_2(){ turn_on_off(0,2,0); Blynk.virtualWrite(V22,0); Serial.println(String("timer turn off switch 2 ") );}
void turn_off_switch_no_3(){ turn_on_off(0,3,0); Blynk.virtualWrite(V23,0); Serial.println(String("timer turn off switch 3 ") );}
// handle switch state
void turn_on_off(int on_off, byte switch_no , byte time_no){
long active_duration_ms ;
char Time_print[16];
if (on_off==1)
// create time as string to print on activation button
sprintf(Time_print, "%02d:%02d", hour(), minute());
// turn on the switch (or off if default is on)
digitalWrite(switch_pins[switch_no],!switch_default[switch_no]);
// if end time is valid use the active duration assigned to this time
// (change to msec will be done later)
if (end_valid[switch_no][time_no])
active_duration_ms = ((long)active_duration[switch_no][time_no]);
else // otherwise use the general time duration
active_duration_ms = ((long)active_duration[switch_no][TIME_CNT]);
// max duration smaller than two min is not valid
if ( (max_duration[switch_no]< 120) | (max_duration[switch_no]>active_duration_ms) )
active_duration_ms = active_duration_ms*1000;
active_duration_ms = ((long)max_duration[switch_no])*1000;
// if new timer is set before another one ended then disable previous timer
if (end_timer_id[switch_no]!=32) timer.deleteTimer(end_timer_id[switch_no]);
// turn on switch and set timer
switch (switch_no) {
case 0:
Blynk.setProperty(V20, "onLabel", String(Time_print));
Blynk.virtualWrite(V20,1);
end_timer_id[0]=timer.setTimeout(active_duration_ms, turn_off_switch_no_0);
break;
case 1:
Blynk.setProperty(V21, "onLabel", String(Time_print));
Blynk.virtualWrite(V21,1);
end_timer_id[1]=timer.setTimeout(active_duration_ms, turn_off_switch_no_1);
break;
case 2:
Blynk.setProperty(V22, "onLabel", String(Time_print));
Blynk.virtualWrite(V22,1);
end_timer_id[2]=timer.setTimeout(active_duration_ms, turn_off_switch_no_2);
break;
case 3:
Blynk.setProperty(V23, "onLabel", String(Time_print));
Blynk.virtualWrite(V23,1);
end_timer_id[3]=timer.setTimeout(active_duration_ms, turn_off_switch_no_3);
break;
Serial.println(String("turn ON switch: ") + switch_no + String(" for duration: ") + active_duration_ms/60000 + String("min "));
digitalWrite(switch_pins[switch_no],switch_default[switch_no]);
end_timer_id[switch_no]=32;
Serial.println(String("turn OFF switch: ") + switch_no);
// set switch state from APP
BLYNK_WRITE(V20) { turn_on_off(param.asInt(),0,TIME_CNT); }
BLYNK_WRITE(V21) { turn_on_off(param.asInt(),1,TIME_CNT); }
BLYNK_WRITE(V22) { turn_on_off(param.asInt(),2,TIME_CNT); }
BLYNK_WRITE(V23) { turn_on_off(param.asInt(),3,TIME_CNT); }
// System Disable //
// when V32 is set the system is entering sleep mode
// all switches are turned off and the system main time tick (the timer that calls activetoday function)
// is disabled
// following function is used to activate main time tick after disable days are over
void restart_system() {
timer.enable(main_timer_id);
Blynk.virtualWrite(V32,0);
// V33 is used to define number of days to disable
BLYNK_WRITE(V33) {system_disable_days = param.asInt()*86400000;}
// V32 is used to disable the system main time tick and to deactivate all switches
BLYNK_WRITE(V32) {
if (param.asInt()!=0)
if (system_disable_days!=0)
// save current time in msec. this is used to calculate msecs until end of today
unsigned int nowmseconds = ((hour() * 3600) + (minute() * 60) + second())*1000;
// current data is printed on V32 button when system is disabled
String currentDate = String(day()) + "\\" + month() + "\\" + year();
Serial.println(String("Disable all"));
// disable main time tick
timer.disable(main_timer_id);
// create a timer to wake the system up after system_disable_days are over
disable_timer_id = timer.setTimeout(system_disable_days-nowmseconds,restart_system);
// print current data on V32 button
Blynk.setProperty(V32, "onLabel", currentDate);
// if system_disable_days is zero then do nothing
// turn off all switches regardless of system_disable_days
turn_off_switch_no_0();
turn_off_switch_no_1();
turn_off_switch_no_2();
turn_off_switch_no_3();
// if system is manually enabled delete disable timer and enable system time tick
timer.deleteTimer(disable_timer_id);
// the following function is called every 60 seconds by a timer //
// the function checks if a start time is reached and if yes it will call //
// the turn_on_off function (to turn on the switch and set timer for turning off switch) //
void activetoday(){ // check if schedule #1 should run today
if(Blynk.connected()) // set wifi led if no connection
digitalWrite(WIFI_LED,LOW);
digitalWrite(WIFI_LED,HIGH);
if(year() != 1970){
unsigned int nowseconds = ((hour() * 3600) + (minute() * 60) + second());
int dayadjustment = -1;
if(weekday() == 1){
dayadjustment = 6; // needed for Sunday Time library is day 1 and Blynk is day 7
for (int switch_cnt = 0; switch_cnt< SWITCH_CNT; switch_cnt++) {
for (int timer_cnt = 0; timer_cnt< TIME_CNT; timer_cnt++) {
if (start_valid[switch_cnt][timer_cnt] == true) {
if (weekdays[switch_cnt][timer_cnt][weekday() + dayadjustment]==true){
if (nowseconds >= start_time_sec[switch_cnt][timer_cnt]){
if(nowseconds < start_time_sec[switch_cnt][timer_cnt]+90){
turn_on_off(1,switch_cnt,timer_cnt);
Serial.println(String("turn ON switch: ") + switch_cnt);
// BLYNK
// reset output pins used and system variables
for (int i = 0; i<SWITCH_CNT ; i++){
pinMode(switch_pins[i], OUTPUT); // reset output pins
digitalWrite(switch_pins[i],switch_default[i]); // set switch to default
end_timer_id[i] = 32; // reset end timer id's
for (int j = 0; j<TIME_CNT ; j++)
end_valid[i][j] = false; // reset end valid array
pinMode(WIFI_LED, OUTPUT);
main_timer_id = timer.setInterval(60000L, activetoday); // check every 60s if ON / OFF trigger time has been reached
setSyncInterval(10 * 60); // Sync interval in seconds (10 minutes)
good job @hagay
do you plan to include a “self-run” when no wifi signal is detected? (wifi modem router down)
As far as I know (and it seams to be working on my garden) the Blynk RTC will keep time when no wifi connection.
if no wifi you will not be able to change timers but everything that was configured during wifi up time will be maintained.
ok, I’will simulate that kind off issue , just down my local server and see what happens
many thanks
Thanks mate. This is a great addition to your project @hagay. I’ve almost finished running my irrigation hoses and have the sprinkler heads in place. Hopefully by the end of next week it should all be done.
Hagay—Thanks again. This new version works great. Solves the issue I was having with using multiple times. I like the efficiency of the code. I really like the way you write the button label with the start time.
I know you said you did not fully test this. I did notice that when I cycle thru the two time cycles the button label will pickup the wrong start time every other start. Not a big deal. This only affects button label. The time cycle is still correct. Manually starting always labels button correctly.
I study your code and I am learning a lot. Thank you
I Like Your GUI!!
Can you post the QR code ?
About the label I think the problem is with the way activetoday checks current time.
There is a guard time of 90 sec that makes activetoday fire twice for every start time.
Solving it will require some changes (RTC time and active today calls are not sync since RTC may get some time aliments from the web).
I am currently making some big changes to the code to make number of switches and timers configurable using defines.
Not sure if I post the new code here or maybe open a new project (since it is no longer 4 relay and not so simple).
In any case the fix will be in the new code.
This is what I use to control my system. LinkNode R4. It is about $10. Uses ESP 8266 chip. I flash it with Node MCU to blow out the original “junk” programming. I adapted Hagay’s program to work with this device. It uses different GPIO and different LED settings
QRC. Please keep in mind my code is adapted from hagay’s code. I modified it to work with my relay board.
From code I can set timerInput in time use ok work. But can not choose a week. How to fix it to make choose a week it work.
#define RELAY_PIN D0 // R1 output pin
#define RELAY_PIN2 D1 // R2 output pin
//#include "DHT.h"
//#include <WiFi.h>
//#include <WiFiClient.h>
//********************* blobal variable ************************
char auth[] = "xxxxx";
char server[] = "xxxx";
char ssid[] = "xxxx";
char pass[] = "xxxx";
int port = 8080;
//BlynkTimer timer;
WidgetRTC rtc;
WidgetTerminal terminal(V1);
WidgetLED led1(V8);
WidgetLED led2(V7);
char _HIGH = LOW;
char _LOW = HIGH;
//********************* End blobal variable ************************
//********************* helper function ****************************
class TimeInterval{
public:
int Start = 0;
int End = 0;
int RelayID = 1;
TimeInterval t1;
TimeInterval t2;
TimeInterval t3;
TimeInterval t4;
TimeInterval checkTimes[] = {t1,t2,t3,t4};
void requestTime() {
Blynk.sendInternal("rtc", "sync");
bool curState = false;
bool curState2 = false;
int selectedMode = 1; // manual
bool after1stCycle = false;
// Check current time with timer array value
bool IsONTIME(int id, int cTime)
TimeInterval t = checkTimes[id];
bool ret = (t.Start <= cTime)&&(cTime <= t.End);
return ret;
//Display rtc time to label widget
void ShowTimeFromRTC()
String currentDate = String(day()) + "/" + month() + "/" + year();
String v = currentDate + " " + currentTime;
Blynk.virtualWrite(V3, v);
// validate current time with timers
void validateTimer()
checkRelayState();
after1stCycle = true;
ShowTimeFromRTC();
if(selectedMode == 2){return;} // not allow to change state in manual mode
int hnow = (hour() * 60) + minute();
bool nState = false;
Serial.print("Time =: ");
Serial.print(hnow);
int relay = 0;
for (int i = 0; i < 4; i++)
if(IsONTIME(i, hnow))
// present time is inside checkTimes[i] interval
nState = true;
Serial.print(" Valid to timer ");
Serial.print(i);
relay = checkTimes[i].RelayID;
break;
// present time is not inside checkTimes[i] interval
if(!nState)
// no timer active at this time then reset all output relay
Serial.print(" not Valid to any timer ");
Serial.println(" ->OFF time");
digitalWrite(RELAY_PIN, _LOW); //send active low to OFF relay
//Blynk.virtualWrite(V8, 0);
led1.off();
digitalWrite(RELAY_PIN2, _LOW); //send active low to OFF relay
//Blynk.virtualWrite(V7, 0);
led2.off();
//Some timer active at this time
Serial.print(" ->ON time");
Serial.print(" ->Relay ");
Serial.print(relay);
if(relay == 1)
Serial.print(" -> current state [");
Serial.print(curState);
Serial.print("] ");
if(nState != curState)
Serial.println(" state Changed.");
curState = nState;
if(nState)
digitalWrite(RELAY_PIN, _HIGH); //send active high to ON relay
//Blynk.virtualWrite(V1, 1);
Blynk.virtualWrite(V8, 1);
led1.on();
//Blynk.virtualWrite(V1, 0);
led1.off();
Serial.println(" state not Change.");
else if(relay == 2)
Serial.print(curState2);
Serial.print("] ");
if(nState != curState2)
curState2 = nState;
if(nState)
digitalWrite(RELAY_PIN2, _HIGH); //send active high to ON relay
//Blynk.virtualWrite(V2, 1);
Blynk.virtualWrite(V7, 1);
led2.on();
//Blynk.virtualWrite(V2, 0);
led2.off();
// Check output pins state and update to LED widget
void checkRelayState()
boolean pressed = (digitalRead(RELAY_PIN) == _HIGH);
if (pressed) {
led1.on();
led1.off();
curState = pressed;
boolean pressed2 = (digitalRead(RELAY_PIN2) == _HIGH);
if (pressed2) {
led2.on();
led2.off();
curState2 = pressed2;
// initial timers interval
void SetTimeIntervals()
checkTimes[0].Start = 1 *60;
checkTimes[0].End = 4 * 60;
checkTimes[1].Start = 7 *60;
checkTimes[1].End = 10 * 60;
checkTimes[2].Start = 13 *60;
checkTimes[2].End = 16 * 60;
checkTimes[2].RelayID = 2;
checkTimes[3].Start = 19 *60;
checkTimes[3].End = 22 * 60;
checkTimes[3].RelayID = 2;
//*********************** Blynk Handler********************************
BLYNK_CONNECTED() {
Blynk.syncAll();
rtc.begin();
int tStart = 0;
int tEnd = 0;
int timerID = 0;
int relayID = 1;
// You can send commands from Terminal to your hardware. Just use
// the same Virtual Pin as your Terminal Widget
// Terminal widget
BLYNK_WRITE(V0)
// if you type "Marco" into Terminal Widget - it will respond: "Polo:"
if (String("Marco") == param.asStr())
terminal.println("You said: 'Marco'") ;
terminal.println("I said: 'Polo'") ;
// Send it back
terminal.print("You said:");
terminal.write(param.getBuffer(), param.getLength());
terminal.println();
// Ensure everything is sent
//terminal.flush();
//Button Widget for Relay1
BLYNK_WRITE(V1)
if(selectedMode == 1){return;} // not allow to change state in auto mode
int s = param.asInt();
curState = s > 0;
if(curState)
led1.on();
terminal.print("Relay 1 On by user in manual mode");
led1.off();
terminal.print("Relay 1 Off by user in manual mode");
//Button Widget for relay2
BLYNK_WRITE(V2)
curState2 = s > 0;
if(curState2)
led2.on();
terminal.print("Relay 2 On by user in manual mode");
led2.off();
terminal.print("Relay 2 Off by user in manual mode");
// Menu Widget for mode select
BLYNK_WRITE(V9)
//if(!after1stCycle){return;}
switch (param.asInt())
case 1: // Item 1
selectedMode = 1;
Serial.println("Mode = Auto");
terminal.println("Mode = Auto") ;
break;
case 2: // Item 2
selectedMode = 2;
Serial.println("Mode = Manual");
terminal.println("Mode = Manual") ;
break;
default:
selectedMode = -1;
Serial.println("Mode = N/A");
terminal.println("Mode = N/A") ;
String tz = "";
//Time Input widget
BLYNK_WRITE(V10)
// handle start end time
tStart = (t.getStartHour() * 60) + t.getStartMinute();
tEnd = (t.getStopHour() * 60) + t.getStopMinute();
tz = t.getTZ();
Serial.println(tz);
Serial.println(tStart);
Serial.println(tEnd);
// Menu Widget for relay selection
BLYNK_WRITE(V11)
case 1: // Item 1
relayID = 1;
Serial.println("Relay select = R1");
terminal.println("Relay select = R1");
break;
case 2: // Item 2
relayID = 2;
Serial.println("Relay select = R2");
terminal.println("Relay select = R2");
break;
default:
selectedMode = -1;
Serial.println("Relay select = None");
terminal.println("Relay select = None") ;
// Menu Widget for timer selection
BLYNK_WRITE(V12)
case 1: // Item 1
timerID = 0;
Serial.println("Timer 0 selected");
terminal.println("Timer 0 selected") ;
Blynk.setProperty(V13, "label", "Set Timer0");
Blynk.virtualWrite(V10, checkTimes[0].Start * 60, checkTimes[0].Start * 60, tz);
Blynk.virtualWrite(V11, checkTimes[0].RelayID);
break;
case 2: // Item 2
timerID = 1;
Serial.println("Timer 1 selected");
terminal.println("Timer 1 selected") ;
Blynk.setProperty(V13, "label", "Set Timer1");
Blynk.virtualWrite(V10, checkTimes[1].Start * 60, checkTimes[1].Start * 60, tz);
Blynk.virtualWrite(V11, checkTimes[1].RelayID);
break;
case 3: // Item 3
timerID = 2;
Serial.println("Timer 2 selected");
terminal.println("Timer 2 selected") ;
Blynk.setProperty(V13, "label", "Set Timer2");
Blynk.virtualWrite(V10, checkTimes[2].Start * 60, checkTimes[2].Start * 60, tz);
Blynk.virtualWrite(V11, checkTimes[2].RelayID);
break;
case 4: // Item 3
timerID =3;
Serial.println("Timer 3 selected");
terminal.println("Timer 3 selected") ;
Blynk.setProperty(V13, "label", "Set Timer3");
Blynk.virtualWrite(V10, checkTimes[3].Start * 60, checkTimes[3].Start * 60, tz);
Blynk.virtualWrite(V11, checkTimes[3].RelayID);
break;
default:
timerID = -1;
Serial.println("No Timer selected");
terminal.println("No Timer selected") ;
Blynk.setProperty(V13, "label", "Set Timer");
// Button widget for Set Timer value
BLYNK_WRITE(V13)
if(!after1stCycle){return;} // not update timer when blynk sync at begin
if(timerID < 0){return;} // if timer id < 0, not update
if(s == 1)
checkTimes[timerID].Start = tStart;
checkTimes[timerID].End = tEnd;
checkTimes[timerID].RelayID = relayID;
String s = "Timer " + String(timerID) + ".Start = " + String(checkTimes[timerID].Start) + " .End = " + String(checkTimes[timerID].End) + " .Relay = " + String(checkTimes[timerID].RelayID);
Serial.println(s);
Serial.println("Connecting to Blynk Server");
WiFi.begin(ssid, pass);
Blynk.config(auth, server, port);
Blynk.connect();
Serial.println("\Starting");
int mytimeout = millis() / 1000;
while (Blynk.connect() == false) { // try to connect to server for 10 seconds
if((millis() / 1000) > mytimeout + 8){ // try local server if not connected within 9 seconds
break;
//Blynk.begin(auth, ssid, pass); // Blynk Server
//Blynk.begin(auth, ssid, pass,IPAddress(XX,XX,XX,XX), 8080); // Local Server
SetTimeIntervals();
// check hour segment every 10 seconds
timer.setInterval(1000L, validateTimer);
pinMode(RELAY_PIN, OUTPUT); // set pin as output to relay R1
pinMode(RELAY_PIN2, OUTPUT); // set pin as output to relay R2
// Display current setting time interval in combination of ( hour * 60 + minute)
for(int i = 0; i < 4; i++)
String s = "Timer " + String(i) + ".Start = " + String(checkTimes[i].Start) + " .End = " + String(checkTimes[i].End)+ " .Relay = " + String(checkTimes[timerID].RelayID);
Serial.println(s);
checkRelayState();
//ShowTimeFromRTC();
if (Blynk.connected()) {
what do you mean ?
do you need to program a full week or a paticular week in the year ?
I mean choose days of week
such as choose a Sun, Tue, Thu and Sat Timer On Reray But Mon, Wed and Fri Timer not work.
I need add choose days of week to my code
you have to use isWeekdaySelected function
//**************** TIMER 1 ***********************
BLYNK_WRITE(V10) { // Scheduler #1 Time Input widget
Serial.println("*******************************************");
Serial.println("timers");
Serial.println("");
startseconds = (t.getStartHour() * 3600) + (t.getStartMinute() * 60);
stopseconds = (t.getStopHour() * 3600) + (t.getStopMinute() * 60);
if (t.isWeekdaySelected((weekday() + dayadjustment))) {
//Schedule is ACTIVE today
if (nowseconds >= startseconds && nowseconds <= stopseconds) {
Timer1 = true;
Blynk.virtualWrite(Vx, 255); // turn on virtual LED
else {
Timer1 = false;
Blynk.virtualWrite(Vx, 0); // turn OFF virtual LED
else {
Timer1 = false;
int relay = 0;
nState = true;
Serial.print(i);
break;
@hagay I need add a isWeekdaySelected function to save a value “Weekday” to array type.
such as
else {
It seems correct
I really like this code and system, but cannot seem to get it to verify. I keep getting this:
Users/craig/Documents/Arduino/fona_4valve-v3/fona_4valve-v3.ino: In function 'void restart_system()':
fona_4valve-v3:326: error: 'V32' was not declared in this scope
/Users/craig/Documents/Arduino/fona_4valve-v3/fona_4valve-v3.ino: In function 'void BlynkWidgetWriteV32(BlynkReq&, const BlynkParam&)':
fona_4valve-v3:351: error: 'V32' was not declared in this scope
fona_4valve-v3:356: error: 'V32' was not declared in this scope
exit status 1
