why not 4 or 6 LEDs instead of 2 ?
HI Paul !
do you need 4 displays like that or 4 digits in one display ?
4 displays = 4X10 pictures easy
1 display 4 digits = 10^4 pictures
I guess with a bit of effort the centre and right images could be made to line up with the top and bottom images. Unfortunately the dashboard only allows for 4 widgets across the screen and we would need 5 to include the left image of the display. Or Perhaps we forget the centre image.
if I understood, you want to superimpose the value widget into an image widget ?
it’s not yet supported by blynk image widget
may be @Pavlo could tell us if it is planned ?
it will be fine if we could reduce to one cell instead of 2
Ideally yes.
This is what I have so far. Imagine left and right images lines up with top and bottom images. I am going to try adding an extra horizontal image through the middle.
it is not possible because one image widget takes 2 cells
yes but it is not very beautiful
voltage need only 20 images 210 to 230 v
current needs 30 images 0 to 30 A
Photoshop to create image widgets
@Blynk_Coeur the Paintshop version serves a purpose because the original picture wasn’t taken at a true vertical to the Pzem display. I could have just taken a better picture but the Paintshop version chopped into 7 pieces now gives:
@Pavlo any chance of a third image type in addition to FIT and FILL, namely BORDERLESS?
We would need a method of nesting transparent widgets over images, or even other widgets, like how it is done in Virtuino and Nextion. But that may also require a finer resolution of widget placement.
new widget
