free sharing
Blynk.virtualWrite(Vx, 1);
Blynk.virtualWrite(Vx, 2);
free sharing
Yes I think it may be a cool idea - you also get an URL to that image that you can use, stored on the forum itself
Good idea. The forum link should be fairly stable as well. A bit much to type in, but copy/pasting while viewing on the phone might work.
GAUGE 1
upload with PNG format
PROGRESS BAR
I think it is best to convert to PNG with transparency.
it’s ok with PNG, thank you
This would be a logical next step of image widget:
Predefined Image Packs. We already have it noted to plans.
But there would be some serious censorship
alarrrrmmmmmaaaa
yes I missed these widgets
do you need green one ?
tell me what you need
ON/OFF
@Blynk_Coeur if you use Blynk color palette, your designs will look more organically.
We also use PF Din Display Pro font (in case you decide to use it)
Also, I don’t know which editor you use, but try using anti-aliasing for fonts. Otherwise these edges look terrible
Also, Blynk design is mostly flat, with no gradients and reflections (sometimes maybe)
I am using photoshop to create my widgets
PF Din Display Pro fonts are not include , I have to buy them …
however I can create Blynk color palette.
If it’s photoshop, make images at least 1000px wide and then save as optimized PNGs
Also, use vector shapes instead of raster layers
thank you so much
