I inserted the image of such a tiny wifi camera into the blynk as a weather image. For the time being, only on a temporary basis.
UPDATE: Confirmed the noise on the cable . . . it runs very close to 240V light cable in my garage . . . triggered by PIR sensor . . . everytime the light switches on/off there is a random spike in rain value. I’ve tested this by adjusting the sensor time to a few seconds, then deliberating triggering it, this causes a corresponding increase in rainfall . . .
I’ve moved the sensor cables as far away from the power cable, it has helped but still getting RFI . . . I have ordered a shield for the cable . . . ZUJ . . .
cul
billd
Greetings Blynk specialists, tell me how to install beautiful widgets like in your weather station project ??
Приветствую специалистов Blynk , подскажите как установить красивые виджеты как в вашем проекте метеостанции??
You have to use image widget, have a look here
Does anyone have like a tutorial how to do it. I have all the components and I really want to do it but Im not an expert on this so im missing a lot of information
Thanks a lot
exactly what should help, electronics or program upload?
both where to connect the sensors and how to programe blynk
It has so modified that I use the 32 port instead of the 14th instead of the precipitation.
nice well work, i want realize a project similar, can you share more? your scheme and software, tnx
There’s quite a melting pot of weather station stuff in this topic, and it includes quite a few code examples, some of which are better than others.
There’s certainly enough resources to point you in the right direction if you’re wanting to develop your own solution, but asking:
without directing this request towards anyone in particular probably isn’t going to get you anything that you can simply copy and get working without any development of your own.
If you have more specific questions about particular posts within this topic then it would be better to ask them.
my code changed a lot and in the meantime I rewrote it to thingspeak, so I can no longer show blynk code.
you’re right, i have pressed the wrong reply arrow
i see the project of Bill_Donnelly and i ask as him
tnx
nice well work, i want realize a project similar, i need only rain gauge and temperature
