I WANT TO LEARN ABOUT INTEGRATION BETWEEN SERVO SG90 AND BLYNK. i WANT TO CREATE A SIMPLE IOT PROJECT WHICH THE SERVO SUPPOSEDLY MOVES ALONG WITH THE SLIDER MOVEMENTS. NOW THE PROBLEM IS THE SERVO KEEP SPINNING IN ONE DIRECTION WITHOUT STOPPING. CAN YOU GUYS GIVE ME ADVICE. HERE IS THE CODING I USED.
#include <ESP8266_Lib.h>
#include <Servo.h>
char auth[] = " 665ee52ea4b74ceb9eb7bab18f6c0f4b";
char ssid[] = "Jalur Sempit";
char pass[] = "*ser8423#";
//#define EspSerial Serial1
// Your ESP8266 baud rate:
#define ESP8266_BAUD 9600
ESP8266 wifi(&EspSerial);
Servo servo;
BLYNK_WRITE(V3)
servo.write(param.asInt());
// delay(10);
// Set ESP8266 baud rate
// delay(10);
servo.attach(9);
Not really a Blynk specific issue… but it sounds like you are using a modified continuous rotation servo… the constant spinning is normal for that type of servo until you adjust the slider back to the servos “neutral” position (usually midway on a typical servo range of 0-180).
Umm… because it is continuously rotating? A standard servo only moves within whatever arc range it is built for… typically 180 degrees. Google servos for more info.
sorry for troubling u? actually i want it to move 180 degrees back and forth by using slider in Blynk. i set the slider from 0 to 180. i know it is my code that cause the problem for continuous rotating. I show you two code here. can u tell me which one can do what i wanted.
BLYNK_WRITE(V3)
int SrvoPos = param.asInt(); // Get slider value
servo.write(SrvoPos); // Move servo to value
delay(50); // Set minimum delay for servo to reach desired position, keep as low as possible.
// Blynk.run();
Dear @Mus_Sopee,
If you have doubts regarding those codes…start using the “search” function in this site, you will find several examples about your project that will help you as example:
Check also below link for better understanding about for statement:
