Serial console shows Connecting to blynk-cloud.com:8442
I am having the same issue. My serial console just constantly shows Connecting to blynk-cloud.com:8442
I used the following sketch:
        char auth[] = "xxx";
        char ssid[] = "xxx";
        char pass[] = "xxx";
I have moved you into your own topic as while the issues may seem similar it is best not to tack onto other topics.
Is this your first Blynk project and has it ever connected before?
What versions of Phone, App, Arduino and Blynk Library are you running?
You seem to have an ESP… what type exactly?
Have you confirmed that you are using the same Auth Code in both you app project and this sketch?
Is there anything unique about your home WiFi setup?
