I created a virtual button on android side.
My question : is it possible to send a mqtt message when i click on that button ?
i would like the standalone server to manage that mqtt message without using esp8266 level ?
thanks in advance
thanks in advance
Not really.
Normally, you’d use something like Mosquitto and Node-Red on a local server, and the Blynk plug-in for Node-Red. In that situation, pressing a widget button attached to a virtual pin will allow you to send an MQTT message from Node-Red without the need for any additional hardware.
thanks now node-red installed and plugin as well
Do you know which port is the webhook port of Blynk localserver ?
hi-again
here is the version : 0.0.3
blynk-websockets-client is grey , does it means that it is not installed ?
regards
That’s not the Blynk plugin that I use.
I would un-install that and install the node-red-contrib-blynk-ws version 1.04 instead.
This is available in the palette manager.
If youre new to Node-Red then you might find this useful…
Yes, that’s to indicate that this isn’t a node that will appear in list of nodes on the left hand side of the screen because it’s the core background process for the contrib.
ok good the last !
i did that kind of test
Try to click on a button (Virtual V0) on my android and receive information in the nodered debug window
but even if i received that kind of information in the node-red-cli when i click on the button
22 Oct 20:47:34 - [info] [blynk-ws-client:test] writeEvent: -> cmd {“type”:20,“typeString”:“HW”,“msgId”:21,“len”:6,“msgLength”:11,“body”:“vw\u00000\u00001”,“operation”:“vw”,“pin”:“0”,“value”:“1”,“array”:[“1”]}
22 Oct 20:47:34 - [info] [blynk-ws-client:test] writeEvent: -> cmd {“type”:20,“typeString”:“HW”,“msgId”:22,“len”:6,“msgLength”:11,“body”:“vw\u00000\u00000”,“operation”:“vw”,“pin”:“0”,“value”:“0”,“array”:[“0”]}
nothing appears in the nodered debug window
do you know why ?
ok i find the solution
i replaced “readevent” node with “writeevent” node and it is ok
thx
